P-Mail on Verizon problems - again
The most likely answer is that they fixed it.
The initial error suggested the problem was temporary/transitory (a 4xx code) and that the issue was with a remote server rather than Pmail.
Hope it remains fixed.
<p>The most likely answer is that they fixed it.</p><p>The initial error suggested the problem was temporary/transitory (a 4xx code) and that the issue was with a remote server rather than Pmail.</p><p>Hope it remains fixed. </p>
RE:  P-Mail v4.71.565
Verizon bought AOL's email system.  They have switched over to their email infrastructure this week.  I can receive email in P-Mail but I can't send email in P-Mail.  I can send email using MS Outlook.
I  do not know if the problem is transitory or permanent.  Verizon indicated the issue was to be fixed on Friday, 2/12/'16 ~0945 hrs.  P-Mail seems to be the problem now.[:(]
 7:52:00.479: Connect to 'smtp.verizon.net', timeout 240 seconds.
07:52:01.549: [*] SSL/TLS session established
07:52:01.549: [*] ECDHE-RSA-AES256-GCM-SHA384, TLSv1.2, Kx=ECDH, Au=RSA, Enc=AESGCM(256), Mac=AEAD
07:52:01.549: [*] Peer's certificate name is '/C=US/ST=Texas/L=Irving/O=Verizon Data Services LLC/OU=VZAO/CN=smtp.verizon.net'.
07:52:05.598: >> 220 vz-proxy-l004.mx.aol.com ESMTP ready
07:52:05.599: << EHLO [192.168.1.10]
07:52:05.615: >> 250-vz-proxy-l004.mx.aol.com
07:52:05.615: >> 250-SIZE 36700160
07:52:05.615: >> 250-ENHANCEDSTATUSCODES
07:52:05.615: >> 250-8BITMIME
07:52:05.615: >> 250-DSN
07:52:05.615: >> 250 AUTH PLAIN LOGIN
07:52:05.615: << AUTH LOGIN
07:52:05.630: >> 334 ######
07:52:05.630: << #####
07:52:05.645: >> 334 ####
07:52:05.645: << ####
07:53:06.031: >> 451 4.3.2 Internal server error
07:53:26.044: << RSET
07:53:26.044: 26: SSL_read returned zero (socket was closed)
07:53:26.044: >>
I have again implemented rednoise' suggestion of using STunnel.
http://rednoise.vacau.com/pmail-stunnel/
&lt;p&gt;&lt;u&gt;RE:&amp;nbsp; P-Mail v4.71.565 &lt;/u&gt; &lt;/p&gt;&lt;p&gt;Verizon bought AOL&#039;s email system.&amp;nbsp; They have switched over to their email infrastructure this week.&amp;nbsp; I can receive email in P-Mail but I can&#039;t send email in P-Mail.&amp;nbsp; I can send email using MS Outlook.&lt;/p&gt;&lt;p&gt;I&amp;nbsp; do not know if the problem is transitory or permanent.&amp;nbsp; Verizon indicated the issue was to be fixed on Friday, 2/12/&#039;16 ~0945 hrs.&amp;nbsp; P-Mail seems to be the problem now.[:(] &lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;&amp;nbsp;7:52:00.479: Connect to &#039;smtp.verizon.net&#039;, timeout 240 seconds. 07:52:01.549: [*] SSL/TLS session established 07:52:01.549: [*] ECDHE-RSA-AES256-GCM-SHA384, TLSv1.2, Kx=ECDH, Au=RSA, Enc=AESGCM(256), Mac=AEAD 07:52:01.549: [*] Peer&#039;s certificate name is &#039;/C=US/ST=Texas/L=Irving/O=Verizon Data Services LLC/OU=VZAO/CN=smtp.verizon.net&#039;. 07:52:05.598: &amp;gt;&amp;gt; 220 vz-proxy-l004.mx.aol.com ESMTP ready 07:52:05.599: &amp;lt;&amp;lt; EHLO [192.168.1.10] 07:52:05.615: &amp;gt;&amp;gt; 250-vz-proxy-l004.mx.aol.com 07:52:05.615: &amp;gt;&amp;gt; 250-SIZE 36700160 07:52:05.615: &amp;gt;&amp;gt; 250-ENHANCEDSTATUSCODES 07:52:05.615: &amp;gt;&amp;gt; 250-8BITMIME 07:52:05.615: &amp;gt;&amp;gt; 250-DSN 07:52:05.615: &amp;gt;&amp;gt; 250 AUTH PLAIN LOGIN 07:52:05.615: &amp;lt;&amp;lt; AUTH LOGIN 07:52:05.630: &amp;gt;&amp;gt; 334 ###### 07:52:05.630: &amp;lt;&amp;lt; ##### 07:52:05.645: &amp;gt;&amp;gt; 334 #### 07:52:05.645: &amp;lt;&amp;lt; #### 07:53:06.031: &amp;gt;&amp;gt; 451 4.3.2 Internal server error 07:53:26.044: &amp;lt;&amp;lt; RSET 07:53:26.044: 26: SSL_read returned zero (socket was closed) 07:53:26.044: &amp;gt;&amp;gt; &amp;nbsp; &lt;/p&gt;&lt;p&gt;I have again implemented &lt;a href=&quot;http://community.pmail.com/members/rednoise.aspx&quot;&gt;rednoise&lt;/a&gt;&#039; suggestion of using STunnel.&lt;/p&gt;&lt;p&gt;&lt;a href=&quot;http://rednoise.vacau.com/pmail-stunnel/ &quot; title=&quot;STunnel&quot; target=&quot;_blank&quot; mce_href=&quot;http://rednoise.vacau.com/pmail-stunnel/ &quot;&gt;http://rednoise.vacau.com/pmail-stunnel/ &lt;/a&gt; &lt;/p&gt;
No to TCP port 587 'cause Verizon requires port 465.
However, I did check "Via STARTTLS" with TCP port 465,
Thank you.
&lt;p&gt;No to TCP port 587 &#039;cause Verizon requires port 465.&amp;nbsp; &lt;/p&gt;&lt;p&gt;However, I did check &quot;&lt;b&gt;Via STARTTLS&lt;/b&gt;&quot; with TCP port 465,&lt;/p&gt;&lt;p&gt;Thank you. &lt;/p&gt;
[quote user="David H. Lipman"]
And AOL?
[quote user=&quot;David H. Lipman&quot;]&lt;p&gt;No to TCP port 587 &#039;cause Verizon requires port 465.&amp;nbsp; &lt;/p&gt;&lt;p&gt;[/quote]&lt;/p&gt;&lt;p&gt;And AOL? &lt;/p&gt;
I don't have an AOL account.  I have a Verizon account with email on Verizon.Net
Verizon bought their email infrastructure and they, Verizon, did a switch-over earlier in the week.  It was relatively seamless, that is until Thursday.
&lt;p&gt;I don&#039;t have an AOL account.&amp;nbsp; I have a Verizon account with email on Verizon.Net&lt;/p&gt;&lt;p&gt;Verizon bought their email infrastructure and they, Verizon, did a switch-over earlier in the week.&amp;nbsp; It was relatively seamless, that is until Thursday.&amp;nbsp; &lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt; &lt;/p&gt;
I'm aware of that from your first post, but thought that some or all of AOL's infrastructure might be in use.
The reason I ask is that if I query Verizon's SMTP server on port 587 STARTTLS is listed in its capabilities.
&lt;p&gt;I&#039;m aware of that from your first post, but thought that some or all of AOL&#039;s infrastructure might be in use.&lt;/p&gt;&lt;p&gt;The reason I ask is that if I query Verizon&#039;s SMTP server on port 587 STARTTLS is listed in its capabilities. &amp;nbsp; &lt;/p&gt;
I setup a new Verizon SMTP Profile for TCP Port 587 using STARTTLS and It worked.
I tried the old Verizon SMTP Profile for TCP Port 465 using SSL and it too worked.
Maybe Verizon finally fixed the server ( which was supposed to have been fixed on Friday ) but it is an option that works.
Thanx !
So now I have 3 Verizon Profiles for SMTP.
  • TCP port 465 over SSL
  • TCP port 587 Via STARTTLS
  • STunnel Proxy
 I setup STunnel as a NT Service so all I have to do is enable it and set to start "Automatic" IFF needed.
&lt;p&gt;I setup a new Verizon SMTP Profile for TCP Port 587 using STARTTLS and It worked.&lt;/p&gt;&lt;p&gt;I tried the old Verizon SMTP Profile for TCP Port 465 using SSL and it too worked.&lt;/p&gt;&lt;p&gt;Maybe Verizon finally fixed the server ( &lt;i&gt;which was supposed to have been fixed on Friday&lt;/i&gt; ) but it is an option that works.&amp;nbsp; &lt;/p&gt;&lt;p&gt;&lt;font color=&quot;#009900&quot; size=&quot;4&quot;&gt;&lt;i&gt;&lt;b&gt;Thanx !&lt;/b&gt;&lt;/i&gt;&lt;/font&gt;&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;So now I have 3 Verizon Profiles for SMTP.&lt;/p&gt;&lt;ul&gt;&lt;li&gt;TCP port 465 over SSL &lt;/li&gt;&lt;li&gt;TCP port 587 Via STARTTLS &lt;/li&gt;&lt;li&gt;STunnel Proxy&lt;/li&gt;&lt;/ul&gt;&lt;p&gt;&amp;nbsp;I setup STunnel as a NT Service so all I have to do is enable it and set to start &quot;Automatic&quot; IFF needed. &lt;/p&gt;
