hi
i experienced some troubles with clamwall: before and after reading community posts, trying many setups, i was not able to get mercury to self control clamd.exe. eventually i:
- downloaded clamav build from the site suggested by http://www.ararat.cz/eng/show.php?clamwall: http://hideout.ath.cx/clamav
- copied in bin (where clamd.exe and freshclam.exe are) the conf files suggested by http://www.ararat.cz/eng/show.php?clamwall: http://www.ararat.cz/download/clamself-config.zip
- wrote a simple batch to start, in order,  freshclam.exe (to update clam before starting clamd), then clamd.exe, and finally mercury.
- configured and enabled clamwall for this setup, obviously.
this works. it always works if you start clamd.exe externally.
my question are:
- there any other tricks to try out?
- i see from the logs that for each scan the sequence invoked is:
   20070831 120835.774 MG000010 From:sender@fiure.it <sender></sender>@figure.it>
<sender>   20070831 120835.774 MG000010 To: recipient@figure.it
</sender>
@figure.it>
<sender>C 20070831 120835.805 MG000010 ClamD version: ClamAV 0.91.2/4110/Fri Aug 31 01:49:40 2007
</sender>
@figure.it>
<sender>C 20070831 120835.805 MG000010 ClamD started
</sender>
@figure.it>
<sender>C 20070831 120835.805 MG000010 FreshClam started
</sender>
_ @figure.it>
<sender>   20070831 120835.946 MG000010 Done! (174)
</sender>
@figure.it>
<sender>now, what is the purpose of calling freshclam, after "starting" clamd..? does it update clam?
</sender>
if not, i have to reglarly (and manually i guess) update clam through freshclam... AT command i suppose.
@figure.it>
<sender>any better known way, folks?
</sender>
bye all!
@figure.it>
<p>hi
</p><p>- downloaded clamav build from the site suggested by http://www.ararat.cz/eng/show.php?clamwall: http://hideout.ath.cx/clamav
</p><p>- copied in bin (where clamd.exe and freshclam.exe are) the conf files suggested by http://www.ararat.cz/eng/show.php?clamwall: http://www.ararat.cz/download/clamself-config.zip
</p><p>- wrote a simple batch to start, in order,  freshclam.exe (to update clam before starting clamd), then clamd.exe, and finally mercury.
</p><p>- configured and enabled clamwall for this setup, obviously.
</p><p>my question are:
</p><p>- there any other tricks to try out?
</p><p>- i see from the logs that for each scan the sequence invoked is:
  </p><p>&nbsp;&nbsp; 20070831 120835.774 MG000010 From:sender@fiure.it <sender@figure.it></sender@figure.it></p><p><sender@figure.it>&nbsp;&nbsp; 20070831 120835.774 MG000010 To: recipient@figure.it
</sender@figure.it></p><p><sender@figure.it>C 20070831 120835.805 MG000010 ClamD version: ClamAV 0.91.2/4110/Fri Aug 31 01:49:40 2007
</sender@figure.it></p><p><sender@figure.it>C 20070831 120835.805 MG000010 ClamD started
</sender@figure.it></p><p><sender@figure.it>C 20070831 120835.805 MG000010 FreshClam started
_ </sender@figure.it></p><p><sender@figure.it>&nbsp;&nbsp; 20070831 120835.946 MG000010 Done! (174)
</sender@figure.it></p><p><sender@figure.it>now, what is the purpose of calling freshclam, after "starting" clamd..? does it update clam?
</sender@figure.it></p><p><sender@figure.it>any better known way, folks?
bye all!
