The certificate files are set by browsing from the Mercury configuration dialog and this works as expected. No, the files for MercuryS expression filtering and for MercuryI.ACL are not saved in the same directory as mercury.exe and i have to specify a path.
If you have the certs in the same directory of mercury.exe:
then
it works as expected
If you browse to a different directory for the certs:
then you have to specify the path:
But the directory for MercuryI.ACL is not configurable. This means
if you have saved your certs outside the directory with the mercury.exe
then the MercuryI.ACL and other files are saved in the cert folder.
PS: The forum software need really an update.
<p>The certificate files are set by browsing from the Mercury configuration dialog and this works as expected.&nbsp;<span style="font-size: 13.3333px;">No, the files for MercuryS expression filtering and for MercuryI.ACL are not saved in the same directory as mercury.exe and i have to specify a path.</span></p>
<p>&nbsp;</p>
<p>If you have the certs in the same directory of mercury.exe: <img src="http://xyzyx.pytalhost.net/Mercury32/1_MercuryS-SSL-intern.jpg" title="http://xyzyx.pytalhost.net/Mercury32/1_MercuryS-SSL-intern.jpg" alt="http://xyzyx.pytalhost.net/Mercury32/1_MercuryS-SSL-intern.jpg" mce_src="http://xyzyx.pytalhost.net/Mercury32/1_MercuryS-SSL-intern.jpg" height="300" width="200" align="top"> then
it works as expected <img src="http://xyzyx.pytalhost.net/Mercury32/2_MercuryS-SSL-intern.jpg" title="http://xyzyx.pytalhost.net/Mercury32/2_MercuryS-SSL-intern.jpg" alt="http://xyzyx.pytalhost.net/Mercury32/2_MercuryS-SSL-intern.jpg" mce_src="http://xyzyx.pytalhost.net/Mercury32/2_MercuryS-SSL-intern.jpg" height="300" width="200" align="top">
<p><span style="font-size: 10pt;">If you browse to a different directory for the certs:&nbsp;</span><img src="http://xyzyx.pytalhost.net/Mercury32/3_MercuryS-SSL-extern.jpg" title="http://xyzyx.pytalhost.net/Mercury32/3_MercuryS-SSL-extern.jpg" alt="http://xyzyx.pytalhost.net/Mercury32/3_MercuryS-SSL-extern.jpg" mce_src="http://xyzyx.pytalhost.net/Mercury32/3_MercuryS-SSL-extern.jpg" height="300" width="200" align="top"> <span style="font-size: 10pt;">then you have to specify the path:&nbsp;<img src="http://xyzyx.pytalhost.net/Mercury32/4_MercuryS-SSL-extern.jpg" title="http://xyzyx.pytalhost.net/Mercury32/4_MercuryS-SSL-extern.jpg" alt="http://xyzyx.pytalhost.net/Mercury32/4_MercuryS-SSL-extern.jpg" mce_src="http://xyzyx.pytalhost.net/Mercury32/4_MercuryS-SSL-extern.jpg" height="300" width="200" align="top"></span><span style="font-size: 10pt;">&nbsp;</span><span style="font-size: 10pt;"></span></p><p><span style="font-size: 10pt;"><span style="font-size: 10pt;">But the directory for MercuryI.ACL is not configurable. This </span>means
then the MercuryI.ACL and other files are saved in the cert folder.</span>
</p><p>&nbsp;</p><p>&nbsp;</p><p><a href="http://xyzyx.pytalhost.net/Mercury32/3_MercuryS-SSL-extern.jpg" mce_href="http://xyzyx.pytalhost.net/Mercury32/3_MercuryS-SSL-extern.jpg" style="font-size: 10pt;"></a></p>
<p>PS: The forum software need really an update.&nbsp;</p>
