First, I good news: Pegasus is now running AOK on the new PC (Petra), with Inbox, folders and address books as they were at the last backup on the crashed PC (Katie). It has taken time (and a bit of experimentation).
Now for some findings that may be helpful to others.
I started from Han van den Bogaede's excellent A guide to Pegasus Mail filenames and file-extensions. I offer my quickie summary as a separate thread, Where files live in Pegasus.
The next step was to install Pegasus.
I downloaded w32_472.exe from the Pegasus website to H:\DL\Pegasus 4_72.
• I did Win+R w32_472.exe to run it. I accepted Security risk. Welcome showed.
• I clicked on Next. New installation details showed.
• I changed the destination from C:\PMAIL to F:\PMAIL
• I accepted:
• Create start menu/shortcuts for Pegasus Mail
• Enable Pegasus Mail for “mailto:”
• Create Pegasus Mail icon on the Desktop
• I unchecked:
• Pre-configure a user mailbox (Creates a mail directory and initial user called Admin).
• Roaming mode – good for running from USB stick. Doesn’t use a drive letter, but both program and mail box(es) have to be on same drive
• I clicked on Next. Ready to install showed.
• I clicked on Finish. A progress bar showed, then Setup has completed successfully.
• I ran Pegasus, and cancelled the Internet setup.
• I clicked on Exit.
Creating pmail.cfg by running pconfig.exe
I ran F:\PMAIL\Programs\pconfig32.exe . Configuration directory showed.
• In Configuration directory I entered nothing.
• I clicked on Next. Home mailbox directory showed. There is a ? button to the right of the input box (which I didn't see initially). For others who missed it, clicking on it showed:
Some fields allow you to use ‘substitutions’ or special character sequences starting with tilde (~) that are replaced with data by Pegasus Mail at runtime. The commonly-used substitutions are:
~D A single random four-digit number, used to build filenames
~A The directory where Pegasus is installed
~H The current Pegaus Mail user’s home mailbox directory
~N The ASCII username of the current user
~8 The first 8 characters of the current user’s username
~R The address to which replies to a message should be sent
~P The personal name of the current user, in its raw form
~O The personal name of the current user, 8-bit encoded
~%... A special form that inserts a Windows environment variable
~L... A special form that creates an address that can be replaced by an address synonym if the user has one defined
~~ Inserts a single tilde character (~) into the string
Click on any button to insert that substitution into the field, or click Close
• I entered G:\PMAIL\MAIL in Home mailbox directory
• I clicked on Save and Exit. This created PMAIL.CFG in F:\PMAIL\Programs.
I examined this pmail.cfg in TextPad. It showed G:\PMAIL\MAIL twice. This was unexpected, based on the note in the first pconfig32 window.
The backup of the crashed PC (Katie, 4.21c) showed G:\PMAIL\MAIL and G:\PmailLeny. (The paths on the hard drive on Petra are the same as they were on Katie.)
On my PC, Molly, examining pmail.cfg showed H:\PMAIL\MAIL and H:\PMailChris.
So the entry in the first input box,Configuration directory, appears to be irrelevant for a single user.
Restoring meta-data and data
I created G:\PMAIL\MAIL and G:\PmailLeny
I copied all files from the backups of these directories (of Katie) to them.
Running Pegasus
Katie, my crashed "friend", had been set to download emails automatically when she crashed. My wife and I share an email address.
• Running Pegasus for the first time
• I disconnected Petra from the LAN.
• I ran Pegasus. Welcome ... showed with Pegasus has detected that you have previously used an older version of Pegasus mail on this mailbox.
• I clicked on OK. Folders looked normal, as did Inbox and address books.
• In Tools > Internet Options > Receiving (POP3) GMail was enabled. I disabled it.
• I connected Petra to the LAN.
I hope this long post may help others who need to recover from a crashed PC. Backups saved my wife (and me!).
Comments, etc. are most welcome.
...chris
<p>First, I good news: Pegasus is now running AOK on the new PC (Petra), with Inbox, folders and address books as they were at the last backup on the crashed PC (Katie). It has taken time (and a bit of experimentation).</p><p>Now for some findings that may be helpful to others.</p><p>I started from Han van den Bogaede's&nbsp; excellent A guide to Pegasus Mail filenames and file-extensions. I offer my <b>quickie summary </b>as a separate thread, <b>Where files live in Pegasus</b>.</p><p>The next step was to install Pegasus.</p><p>&nbsp;&nbsp;&nbsp; I downloaded w32_472.exe from the Pegasus website to H:\DL\Pegasus 4_72.
•&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; I did Win+R w32_472.exe to run it. I accepted Security risk. Welcome showed.
&nbsp;&nbsp;&nbsp; •&nbsp;&nbsp;&nbsp; I clicked on Next. New installation details showed.
&nbsp;&nbsp;&nbsp; •&nbsp;&nbsp;&nbsp; I changed the destination from C:\PMAIL to F:\PMAIL
&nbsp;&nbsp;&nbsp; •&nbsp;&nbsp;&nbsp; I accepted:
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; •&nbsp;&nbsp;&nbsp; Create start menu/shortcuts for Pegasus Mail
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; •&nbsp;&nbsp;&nbsp; Enable Pegasus Mail for “mailto:”
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; •&nbsp;&nbsp;&nbsp; Create Pegasus Mail icon on the Desktop
&nbsp;&nbsp;&nbsp; •&nbsp;&nbsp;&nbsp; I unchecked:
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; •&nbsp;&nbsp;&nbsp; Pre-configure a user mailbox (Creates a mail directory and initial user called Admin).
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; •&nbsp;&nbsp;&nbsp; Roaming mode – good for running from USB stick. Doesn’t use a drive letter, but both program and mail box(es) have to be on same drive
&nbsp;&nbsp;&nbsp; •&nbsp;&nbsp;&nbsp; I clicked on Next. Ready to install showed.
&nbsp;&nbsp;&nbsp; •&nbsp;&nbsp;&nbsp; I clicked on Finish. A progress bar showed, then Setup has completed successfully.
&nbsp;&nbsp;&nbsp; •&nbsp;&nbsp;&nbsp; I ran Pegasus, and cancelled the Internet setup.
&nbsp;&nbsp;&nbsp; •&nbsp;&nbsp;&nbsp; I clicked on Exit.
&nbsp;</p><p><b>Creating pmail.cfg by running pconfig.exe</b>
</p><p>I ran F:\PMAIL\Programs\pconfig32.exe . Configuration directory showed.
•&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; In Configuration directory I entered nothing.
&nbsp;&nbsp;&nbsp; •&nbsp;&nbsp;&nbsp; I clicked on Next. Home mailbox directory showed. <b>There is a ? button to the right of the input box</b> (which I didn't see initially). For others who missed it, clicking on it showed:</p><p>
~D&nbsp;&nbsp;&nbsp; A single random four-digit number, used to build filenames
~A&nbsp;&nbsp;&nbsp; The directory where Pegasus is installed
~H&nbsp;&nbsp;&nbsp; The current Pegaus Mail user’s home mailbox directory
~N&nbsp;&nbsp;&nbsp; The ASCII username of the current user
~8&nbsp;&nbsp;&nbsp; The first 8 characters of the current user’s username
~R&nbsp;&nbsp;&nbsp; The address to which replies to a message should be sent
~P&nbsp;&nbsp;&nbsp; The personal name of the current user, in its raw form
~O&nbsp;&nbsp;&nbsp; The personal name of the current user, 8-bit encoded
~%...&nbsp;&nbsp;&nbsp; A special form that inserts a Windows environment variable
~L...&nbsp;&nbsp;&nbsp; A special form that creates an address that can be replaced by an address synonym if the user has one defined
~~&nbsp;&nbsp;&nbsp; Inserts a single tilde character (~) into the string
Click on any button to insert that substitution into the field, or click Close</p><p>
•&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; I entered G:\PMAIL\MAIL in Home mailbox directory
•&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;I clicked on Save and Exit. This created PMAIL.CFG in F:\PMAIL\Programs.</p><p>I examined this pmail.cfg in TextPad. It showed G:\PMAIL\MAIL twice. <b>This was unexpected, based on the note in the first pconfig32 window.</b>
</p><p>The backup of&nbsp; the crashed PC (Katie, 4.21c) showed G:\PMAIL\MAIL and G:\PmailLeny. (The paths on the hard drive on Petra are the same as they were on Katie.)</p><p>On my PC, Molly, examining pmail.cfg showed H:\PMAIL\MAIL and H:\PMailChris.</p><p>So the entry in the first input box,Configuration directory, appears to be irrelevant for a single user.</p><p><b>Restoring meta-data and data</b>
</p><p>I created G:\PMAIL\MAIL and&nbsp; G:\PmailLeny</p><p>I copied all files from the backups of these directories (of Katie)&nbsp; to&nbsp; them.</p><p><b>Running Pegasus</b>
</p><p>Katie, my crashed "friend", had been set to download emails automatically when she crashed. My wife and I share an email address.
</p><p>
•&nbsp;&nbsp; &nbsp;Running Pegasus for the first time
&nbsp;&nbsp;&nbsp; •&nbsp;&nbsp; &nbsp;I disconnected Petra from the LAN.
&nbsp;&nbsp;&nbsp; •&nbsp;&nbsp; &nbsp;I ran Pegasus. Welcome ... showed with Pegasus has detected that you have previously used an older version of Pegasus mail on this mailbox.
&nbsp;&nbsp;&nbsp; •&nbsp;&nbsp; &nbsp;I clicked on OK. Folders looked normal, as did Inbox and address books.
&nbsp;&nbsp;&nbsp; •&nbsp;&nbsp; &nbsp;In Tools &gt; Internet Options &gt; Receiving (POP3) GMail was enabled. I disabled it.
&nbsp;&nbsp;&nbsp; •&nbsp;&nbsp; &nbsp;I connected Petra to the LAN.
</p><p>I hope this long post may help others who need to recover from a crashed PC. Backups saved my wife (and me!).</p><p>&nbsp;</p><p>Comments, etc. are most welcome.&nbsp;</p><p>&nbsp;...chris
