Hi all,
I have a new laptop with windows 10. I installed Pegasus 4.72 and moved mailboxes over to the new machine and all works well, except for the display.
At first the display, only in Pegasus, was very fuzzy. I tried the fix disabling display scaling as mentioned here:
https://support.microsoft.com/en-us/help/2900023/some-desktop-applications-may-appear-blurred-on-high-dpi-displays
That made the font nice and crisp, but also tiny and difficult to read.
I also tried the second fix, and while I can scale up the font, it is very fuzzy.
Seems the choices are bigger and fuzzy or crisp and small.
Anyone else having these problems? Any work around?
Thanks!
<p>Hi all, </p><p>I have a new laptop with windows 10. I installed Pegasus 4.72 and moved mailboxes over to the new machine and all works well, except for the display.&nbsp;</p><p>At first the display, only in Pegasus, was very fuzzy. I tried the fix disabling display scaling as mentioned here:</p><p><a mce_href="https://support.microsoft.com/en-us/help/2900023/some-desktop-applications-may-appear-blurred-on-high-dpi-displays" href="https://support.microsoft.com/en-us/help/2900023/some-desktop-applications-may-appear-blurred-on-high-dpi-displays">https://support.microsoft.com/en-us/help/2900023/some-desktop-applications-may-appear-blurred-on-high-dpi-displays</a></p><p>That made the font nice and crisp, but also tiny and difficult to read. &nbsp; </p><p>I also tried the second fix, and while I can scale up the font, it is very fuzzy.</p><p>Seems the choices are bigger and fuzzy or crisp and small.&nbsp;</p><p>Anyone else having these problems? Any work around?&nbsp;</p><p>Thanks!
