Ok, its got weirder. This is was the info box says:
Copyright (C) 1992-2015, David Harris, all rights reserved
WinPMail version: Version 4.72.572, Feb 19 2016, build ID 572
User name and ID: Admin, 0
Windows version: 6.1
WINPMAIL.EXE directory: C:\deucharprogs\PMAIL\Programs
Home mailbox location: C:\DEUCHAR\MAILBOX
New mailbox location: C:\deucharprogs\PMAIL\MAIL\Admin
TMP environment variable: C:\Users\chrisd\AppData\Local\Temp
TEMP environment variable: C:\Users\chrisd\AppData\Local\Temp
- WINSOCK path: WSOCK32.DLL
Commandline: -roam -A
Active -Z options: 32768
PMR variable: (None)
PML variable: (None)
MAI variable: (None)
NB variable: (None)
Last new mail count: 0
You will see the line c:\deuchar\mailbox ? This has just appeared. Although a new mailbox has been created there, it is not where tools>options>mailbox thinks it is because that says E:\deuchar\mailbox !
This new c:\deuchar\mailbox folder wasn't there before but now I find that if I copy one of my .PML files from the E: drive mailbox to the C: drive one then I *can* see it - so some sort of progress is happening, however (quite correctly) all my messages are still on the E: drive. I just want the program to use the E: drive folder for lists etc too.
I do of course still have the C:\...Mail\admin folder version of some sort of mailbox - which I understand is the New Mail folder and cannot be moved? However, I would like to 'rationalise' the other two into one on the E: drive.
I take your point about the identities and will investigate that separately
Chris d
<p>Ok, its got weirder. This is was the info box says:</p><p>Pegasus Mail for Microsoft Windows
&nbsp; - WINSOCK version: WinSock 2.0
&nbsp; - WINSOCK path: WSOCK32.DLL
NB variable: (None)
</p><p>You will see the line c:\deuchar\mailbox ?&nbsp; This has just appeared. Although a new mailbox has been created there, it is not where tools&gt;options&gt;mailbox thinks it is because that says E:\deuchar\mailbox !</p><p>This new&nbsp; c:\deuchar\mailbox folder wasn't there before but now I find that if I copy one of my .PML files from the E: drive mailbox to the C: drive one then I *can* see it - so some sort of progress is happening, however (quite correctly) all my messages are still on the E: drive.&nbsp; I just want the program to use the E: drive folder for lists etc too.
</p><p>I do of course still have the C:\...Mail\admin folder version of some sort of mailbox - which I understand is the New Mail folder and cannot be moved?&nbsp; However, I would like to 'rationalise' the other two into one on the E: drive.
</p><p>I take your point about the identities and will investigate that separately </p><p>Thanks</p><p>&nbsp;Chris d</p><p>&nbsp;</p>
