It is solved. The solutions are:
1. Create an admin account for the Mercury Service: Create account 'Mercury Service'. Make this account member of the group 'Administrators'.
2. At the Mercury Service set this account for starting the service.
3. Restart service.
For Outlook:
When delete the folder use the key 'shift' and click with your right mouse button on the folder for deleting. Select 'Delete Folder'.
If you don't use the key 'shift' Outlook want to move the folder to 'Deleted Items' and that's failing.
Mat
<p>It is solved. The solutions are:</p><p>1. Create an admin account for the Mercury Service: Create account 'Mercury Service'. Make this account member of the group 'Administrators'. </p><p>2. At the Mercury Service set this account for starting the service.</p><p>3. Restart service.&nbsp;</p><p>For Outlook:</p><p>When delete the folder use the key 'shift' and click with your right mouse button on the folder for deleting. Select 'Delete Folder'.</p><p>If you don't use the key 'shift' Outlook want to move the folder to 'Deleted Items' and that's failing.</p><p>&nbsp;</p><p>Mat&nbsp;</p>
