[quote user="philherz"][quote user="caisson"]
Turn on session logging in Tools | Internet options and see what error message you are getting.
The log files are in your mail folder.(TCP log)
If you post the log remove your username and password. These might be Base64 encoded, but can be decided easily.
Here's Verizon:
11:27:02.170: --- 13 Apr 2018, 11:27:02.170 ---
11:27:02.173: Connect to 'pop.verizon.net', timeout 10 seconds.
11:27:13.228: 8: Socket read timeout
11:27:13.231: >>
11:27:13.234: --- Connection closed normally at 13 Apr 2018, 11:27:13.234. ---
11:27:13.236:
Here's one that worked:
11:27:41.250: --- 13 Apr 2018, 11:27:41.250 ---
11:27:41.253: Connect to 'discountsoccerjerseys.com', timeout 15 seconds.
11:27:42.257: >> +OK POP3 scorpio.tera-byte.com 2007b.104 server ready<cr><lf>
11:27:42.260: << USER XXXXXX<cr><lf>
11:27:42.349: >> +OK User name accepted, password please<cr><lf>
11:27:42.352: << PASS XXXXX<cr><lf>
11:27:42.447: >> +OK Mailbox open, 0 messages<cr><lf>
11:27:42.452: << STAT<cr><lf>
11:27:42.541: >> +OK 0 0<cr><lf>
11:27:42.544: << QUIT<cr><lf>
11:27:42.634: >> +OK Sayonara<cr><lf>
11:27:42.638: --- Connection closed normally at 13 Apr 2018, 11:27:42.638. ---
11:27:42.642:
Can you confirm that in your internet settings you have set port 995 and on the security page checked direct ssl?
[quote user="philherz"][quote user="caisson"]<p>Turn on session logging in Tools | Internet options and see what error message you are getting.</p><p>The log files are in your mail folder.(TCP log)
</p><p>If you post the log&nbsp; remove your username and password. These might be Base64 encoded, but can be decided easily.
</p><p>[/quote]</p><p>&nbsp;</p><p>Here's Verizon:</p><p>11:27:02.170: --- 13 Apr 2018, 11:27:02.170 ---
11:27:13.231: &gt;&gt;
11:27:13.236:&nbsp;
</p><p>&nbsp;</p><p>Here's one that worked:</p><p>&nbsp;11:27:41.250: --- 13 Apr 2018, 11:27:41.250 ---
11:27:42.257: &gt;&gt; +OK POP3 scorpio.tera-byte.com 2007b.104 server ready&lt;cr&gt;&lt;lf&gt;
11:27:42.260: &lt;&lt; USER XXXXXX&lt;cr&gt;&lt;lf&gt;
11:27:42.349: &gt;&gt; +OK User name accepted, password please&lt;cr&gt;&lt;lf&gt;
11:27:42.352: &lt;&lt; PASS XXXXX&lt;cr&gt;&lt;lf&gt;
11:27:42.447: &gt;&gt; +OK Mailbox open, 0 messages&lt;cr&gt;&lt;lf&gt;
11:27:42.452: &lt;&lt; STAT&lt;cr&gt;&lt;lf&gt;
11:27:42.541: &gt;&gt; +OK 0 0&lt;cr&gt;&lt;lf&gt;
11:27:42.544: &lt;&lt; QUIT&lt;cr&gt;&lt;lf&gt;
11:27:42.634: &gt;&gt; +OK Sayonara&lt;cr&gt;&lt;lf&gt;
11:27:42.642:
</p><p>[/quote]</p><p>Can you confirm that in your internet settings you have set port 995 and on the security page checked direct ssl?
</p><p>&nbsp;</p><p>&nbsp;</p>
