I recently upgraded IER from 2.6.5.17 to 2.6.5.18.
After sending a reply and returning to Pegasus in preview mode, the window with message text drops to a 1/4 of it's full size, complete with scroll bars horizontally and vertically.
It seems to only happen if the message that you are returning to after a reply, has html in it. All is ok if the message you are returning to is plain text.
When I select a different message or folder the message text window draws properly again.
When I downgrade IER to 2.6.5.17, the problem doesn't appear. So certainly seems to be an 2.6.5.18 issue.
![62edcc09360ae](serve/attachment&path=62edcc09360ae)
