Confirmed OLATH2 ...
Posted "just for the record".
TCP Log from failed email send via comcast: File: TCP-221118-1417-0.smtp
14:17:38.272: --- 18 Nov 2022, 14:17:38.272 ---
<snip>
14:17:39.789: >> 250-AUTH LOGIN PLAIN XOAUTH2<cr><lf>
14:17:39.789: >> 250-SIZE 36700160<cr><lf>
14:17:39.789: >> 250-ENHANCEDSTATUSCODES<cr><lf>
14:17:39.789: >> 250-8BITMIME<cr><lf>
14:17:39.789: >> 250 OK<cr><lf>
<snip>
14:17:40.159: >> 235 2.7.0 ... Authentication succeeded<cr><lf>
<snip> (Oops- OLATH2 didn't like that authentication after all..)
14:18:00.302: << QUIT<cr><lf>
14:18:00.317: 26: SSL read returned zero (socket was closed)
14:18:00.317: >> (buh bye!)
14:18:00.317: [*] OpenSSL secure session normally terminated.
14:18:00.317: --- Connection closed at 18 Nov 2022, 14:18:00.317. ---
14:18:00.317:
successful send account log: File: TCP-221118-1422-1.smtp (apparently no OLATH2 implementation yet)
14:22:18.751: --- 18 Nov 2022, 14:22:18.751 ---
14:22:18.751: Connect to 'smtp.{redacted}', timeout 60 seconds.
14:22:19.932: [*] SSL/TLS session established
<snip>
14:22:20.456: >> 250-PIPELINING<cr><lf>
14:22:20.456: >> 250-PIPE_CONNECT<cr><lf>
14:22:20.456: >> 250-AUTH PLAIN LOGIN<cr><lf>
14:22:20.456: >> 250 HELP<cr><lf>
14:22:20.456: << AUTH LOGIN<cr><lf>
<snip>
14:22:20.704: >> 235 Authentication succeeded<cr><lf>
<snip> (and we're all good here..)
14:22:20.936: << X-mailer: Pegasus Mail for Windows (4.80.1028 )<cr><lf>
14:22:20.936: << Content-type: text/plain; charset=US-ASCII<cr><lf>
14:22:20.936: << Content-transfer-encoding: 7BIT<cr><lf>
14:22:20.936: << Content-description: Mail message body<cr><lf>
14:22:20.936: << <cr><lf>
14:22:20.936: << test<cr><lf>
14:22:20.936: << .<cr><lf>
14:22:21.058: >> 250 OK id=....... <cr><lf>
14:22:21.074: << QUIT<cr><lf>
14:22:21.407: >> 221 closing connection<cr><lf>
14:22:21.438: [*] OpenSSL secure session normally terminated.
14:22:21.438: --- Connection closed at 18 Nov 2022, 14:22:21.438. ---
14:22:21.438:
<snip>
14:17:39.789: >> 250-**AUTH LOGIN PLAIN XOAUTH2**<cr><lf>
<snip>
<snip> (_Oops- OLATH2 didn't like that authentication after all.._)
14:18:00.317: >> _ (buh bye!)_
14:18:00.317:
<snip>
<snip>
<snip> (_and we're all good here.._)
14:22:21.438:
