Questions
Sorry to keep bothering people with problems but I guess things are difficult to understand the older I,m getting but recently I seem to be receiving messages okay but when sending it says message has failed and get the following:
10:39:57.339: >> 250-8BITMIME
10:39:57.339: >> 250-STARTTLS
10:39:57.339: >> 250 OK
10:39:57.343: << STARTTLS
10:39:57.414: >> 220 2.0.0 Ready to start TLS
10:39:58.612: [] SSL/TLS session established
10:39:58.612: [
] ECDHE-RSA-AES256-GCM-SHA384, TLSv1.2, Kx=ECDH, Au=RSA, Enc=AESGCM(256), Mac=AEAD
10:39:58.612: [*] Peer's certificate name is '/C=US/ST=Missouri/L=St. Louis/O=Charter Communications Operating, LLC/CN=mail.twc.com'.
10:39:58.613: << EHLO [192.168.0.188]
10:39:58.684: >> 250-p-impout007.msg.pkvw.co.charter.net hello [67.255.84.24], pleased to meet you
10:39:58.684: >> 250-AUTH LOGIN PLAIN
10:39:58.684: >> 250-SIZE 30000000
10:39:58.684: >> 250-ENHANCEDSTATUSCODES
10:39:58.684: >> 250-8BITMIME
10:39:58.684: >> 250 OK
10:39:58.684: << AUTH LOGIN
10:39:58.745: >> 334 VXNlcm5hbWU6
10:39:58.745: << ZHNnaWxsQHJvYWRydW5uZXIuY29t
10:39:58.812: >> 334 UGFzc3dvcmQ6
10:39:58.812: << MTlDTE1BNjA=
10:39:58.886: >> 535 5.7.0 ...authentication rejected
I've called a couple of people to see if msg is received and they seemed to have received ok so I'm wondering what gives. I find myself going to the Spectrum webmail in order to send
[2] Also on another matter I was asked if my renderer had latest version.....where do i go to check this?
[3] also I still want to raise my default print when reading and/or composing messages as my sight not that great and everything is so small to read.....never seemed that way before.
As mentioned before, i hate to bother people but I'd like to square these away
Sorry to keep bothering people with problems but I guess things are difficult to understand the older I,m getting but recently I seem to be receiving messages okay but when sending it says message has failed and get the following: 10:39:57.339: &gt;&gt; 250-8BITMIME 10:39:57.339: &gt;&gt; 250-STARTTLS 10:39:57.339: &gt;&gt; 250 OK 10:39:57.343: &lt;&lt; STARTTLS 10:39:57.414: &gt;&gt; 220 2.0.0 Ready to start TLS 10:39:58.612: [*] SSL/TLS session established 10:39:58.612: [*] ECDHE-RSA-AES256-GCM-SHA384, TLSv1.2, Kx=ECDH, Au=RSA, Enc=AESGCM(256), Mac=AEAD 10:39:58.612: [*] Peer&#039;s certificate name is &#039;/C=US/ST=Missouri/L=St. Louis/O=Charter Communications Operating, LLC/CN=mail.twc.com&#039;. 10:39:58.613: &lt;&lt; EHLO [192.168.0.188] 10:39:58.684: &gt;&gt; 250-p-impout007.msg.pkvw.co.charter.net hello [67.255.84.24], pleased to meet you 10:39:58.684: &gt;&gt; 250-AUTH LOGIN PLAIN 10:39:58.684: &gt;&gt; 250-SIZE 30000000 10:39:58.684: &gt;&gt; 250-ENHANCEDSTATUSCODES 10:39:58.684: &gt;&gt; 250-8BITMIME 10:39:58.684: &gt;&gt; 250 OK 10:39:58.684: &lt;&lt; AUTH LOGIN 10:39:58.745: &gt;&gt; 334 VXNlcm5hbWU6 10:39:58.745: &lt;&lt; ZHNnaWxsQHJvYWRydW5uZXIuY29t 10:39:58.812: &gt;&gt; 334 UGFzc3dvcmQ6 10:39:58.812: &lt;&lt; MTlDTE1BNjA= 10:39:58.886: &gt;&gt; 535 5.7.0 ...authentication rejected I&#039;ve called a couple of people to see if msg is received and they seemed to have received ok so I&#039;m wondering what gives. I find myself going to the Spectrum webmail in order to send [2] Also on another matter I was asked if my renderer had latest version.....where do i go to check this? [3] also I still want to raise my default print when reading and/or composing messages as my sight not that great and everything is so small to read.....never seemed that way before. As mentioned before, i hate to bother people but I&#039;d like to square these away
IMPORTANT: The log file you posted contains your authentication credentials in a form that is easily decrypted. I strongly suggest that you change your password.
I'll be back after reviewing the rest of your post.
IMPORTANT: The log file you posted contains your authentication credentials in a form that is easily decrypted. I strongly suggest that you change your password. I&#039;ll be back after reviewing the rest of your post.
This log entry indicates that the login credentials are not what Spectrum expects so the message should not be getting sent. I suggest that after you change your password that you re-enter the username and password information in the SMTP host configuration.
Tools > Internet options > Sending (SMTP) tab
Select the host file listed then click the Edit button
You will also need to enter the new password in the POP3 host file located in the Receiving(POP3) tab.
To see the installed version number hover over the IERenderer icon located furthest right in the toolbar of the Pegasus Mail main window. The current version is 2.7.1.5.
You can specify the font to be used.
If you use Preview mode click the Font button (blue lowercase "f" ) in the main toolbar to access a configuration screen where you can specify the font for each pane.
When working in Pegasus Mail windows, the font for the active window can be set by using the same Font button so you would do it for the reader window, then for the composition window, and also for folder windows. This works for all Pegasus Mail child windows. It does not work for Help or for any configuration window. Note: There is a way to set a default for folder windows. That should be a separate discussion though.
Finally, you can not control the font used in the HTML content of messages but the IERenderer configuration options contains a zoom factor setting the may be valuable. To access that, click on the IERenderer toolbar button and select "Configure IERenderer". If is is greyed out, click on a message that contains HTML content then try again.
[quote=&quot;pid:56291, uid:30801&quot;]10:39:58.886: &gt;&gt; 535 5.7.0 ...authentication rejected[/quote] This log entry indicates that the login credentials are not what Spectrum expects so the message should not be getting sent. I suggest that after you change your password that you re-enter the username and password information in the SMTP host configuration. Tools &gt; Internet options &gt; Sending (SMTP) tab Select the host file listed then click the Edit button You will also need to enter the new password in the POP3 host file located in the Receiving(POP3) tab. [quote=&quot;pid:56291, uid:30801&quot;][2] Also on another matter I was asked if my renderer had latest version.....where do i go to check this?[/quote] To see the installed version number hover over the IERenderer icon located furthest right in the toolbar of the Pegasus Mail main window. The current version is 2.7.1.5. [quote=&quot;pid:56291, uid:30801&quot;][3] also I still want to raise my default print when reading and/or composing messages as my sight not that great and everything is so small to read.....never seemed that way before.[/quote] You can specify the font to be used. If you use Preview mode click the Font button (blue lowercase &quot;f&quot; ) in the main toolbar to access a configuration screen where you can specify the font for each pane. When working in Pegasus Mail windows, the font for the active window can be set by using the same Font button so you would do it for the reader window, then for the composition window, and also for folder windows. This works for all Pegasus Mail child windows. It does not work for Help or for any configuration window. Note: There is a way to set a default for folder windows. That should be a separate discussion though. Finally, you can not control the font used in the HTML content of messages but the IERenderer configuration options contains a zoom factor setting the may be valuable. To access that, click on the IERenderer toolbar button and select &quot;Configure IERenderer&quot;. If is is greyed out, click on a message that contains HTML content then try again.
