How do you exit Pegasus?
Believe that some things require using the file/exit option rather than the X in the upper right corner?
Not sure what options require that, or why it makes a difference. Since the time stamp isn't changing seems something is stopping changes from being saved.
Might also want to make sure the read-only attrib isn't set, and that the user has full rights to file.
Did you manually open the IERender.ini file, and check what it is showing for the option that you changed?
Had a copy of it in a test directory, but since it doesn't work with wine under linux, have to uninstall it completely.
Have checked it on windows 10, and 11, and seems nice, but I seldom using windows. Pegasus works well for me under Linux with native TER32 and HTS32 rather than with BEARHTML or IERender, but think it is a wine issue not fully supporting internet explorer, since firefox and other browsers work fine.
Good Luck.
Good Luck.
