Hello
For several days, I have problems to connect to an S MTP server - It seems to be an auth entification problem
Th e ISP gave me the following information :
Protocol Server -WEB- Port TLS SSL Authentication
IMAP imap.online.net 143 (recommend) Yes No Yes
IMAPS imap.online.net 993 No Yes Yes
POP3 pop.online.net 110 (recommend) Yes No Yes
POP3 pop.online.net 995 No Yes Yes
SMTP smtp.online.net 25 Yes No Yes
SMTP smtp.online.net 587 (recommend) Yes No Yes
SMTP smtp.online.net 2525 Yes No Yes
SMTPS smtp.online.net 465 No Yes Yes
my mail adress is achats@circus-photos.com
Let assume that my password is password
What should I check in the different panels for SMTP settings and what value should I enter (if needed)
Thanks everyone for any help you can provide
Have a good evening
