Add-ons for Pegasus Mail
IERenderer - General question
Will this below be an issue for IERenderer? Does it use any of Windows legacy web view components?
No, it only uses IE components. Edge is not involved in any kind (also see the annotations the installer provides about IE support).
[quote="pid:58027, uid:29380"]Will this below be an issue for IERenderer? Does it use any of Windows legacy web view components?[/quote] No, it only uses IE components. Edge is not involved in any kind (also see the annotations the installer provides about IE support).
