Hello everyone,
I'm currently trying to get the PM-PGP plugin working with Pegasus Mail 4.9.1. Gpg4win is installed and functioning properly, but since PM-PGP requires a classic PGP installation, I installed PGP Desktop 10.4. Didn't find an older version.
Unfortunately, the PM-PGP installer reports "Incorrect PGP version" and aborts. A manual installation of the plugin files also fails, as the PGP SDK Core Library appears to be missing.
Has anyone successfully used PM-PGP with newer PGP versions? Is there a way to bypass the version check or manually integrate the plugin?
Alternatively, does anyone have access to a working version of QDPGP that’s compatible with GnuPG from Gpg4win?
The links to QDPGP here are not working anymore.
Thanks in advance for any advice or workaround!
Best regards, Lothar.
Hello everyone,
edited Oct 28 '25 at 1:25 pm
