Hi, very long time Pegasus Mail user (since 1999!). Love it!
I've moved to Linux since Win8 but taken my trusted PMail with me, and it has worked just fine under Wine till v.4.73 (included).
On v.4.80 and 4.91 all text is literally a letter salad: Usually all letters are bunched together at the start of each line, sometimes they are randomly scattered all over the window (including on menu and title bars). The default folder view and the mail subjects inside show normally, the problem only happens when reading a message, trying to write a new one, or in Help...
What has changed between 4.73 and the following versions which could create such a mess?
It has to be the part responsible for showing text both in messages and in the program's Help pages.
(FTR I did try both updates and clean installs of both 4.80 and 4.91, but finally I had to go back to 4.73 since is the last one which works.)
Thanks for reading.
Hi, _very_ long time Pegasus Mail user (since 1999!). Love it! I've moved to Linux since Win8 but taken my trusted PMail with me, and it has worked just fine under Wine till v.4.73 (included). **On v.4.80 and 4.91 all text is literally a letter salad**: Usually all letters are bunched together at the start of each line, sometimes they are randomly scattered all over the window (including on menu and title bars). The default folder view and the mail subjects inside show normally, the problem only happens when **reading a message**, trying to **write a new one**, or in **Help**... What has changed between 4.73 and the following versions which could create such a mess? It has to be the part responsible for showing text both in messages and in the program's Help pages. (FTR I did try both updates and clean installs of both 4.80 and 4.91, but finally I had to go back to 4.73 since is the last one which works.) Thanks for reading.
The module being used in the locations you list is a third party module which has been updated several times since 4.73, but we never heard about such an issue before. Since the number of Linux users running Pegasus Mail is certainly pretty low we have no idea so far about what could be causing this. Since there's an experienced Linux user (@msetzerii) frequently participating in forum discussions he might be able and willing to look into this.
[quote="pid:59164, uid:36421"]What has changed between 4.73 and the following versions which could create such a mess?[/quote] The module being used in the locations you list is a third party module which has been updated several times since 4.73, but we never heard about such an issue before. Since the number of Linux users running Pegasus Mail is certainly pretty low we have no idea so far about what could be causing this. Since there's an experienced Linux user (@msetzerii) frequently participating in forum discussions he might be able and willing to look into this.
edited Oct 4 at 4:04 pm
Thanks.
It's surprising, since it sounds like a pretty basic function to me (not a developer!). I don't understand how it can break that much, he must be doing something in a truly peculiar way.
Besides it must be a rather rarely used module, because I'm still using a lot of Windows programs and none of them has a similar problem (it really doesn't go unnoticed...).
For the record, Ubuntu using Wine v11 (straight, no DLL overrides).
Well, let's hope @msetzerii notices this and has a solution.
Thanks. It's surprising, since it sounds like a pretty basic function to me (not a developer!). I don't understand how it can break _that_ much, he must be doing something in a truly peculiar way. Besides it must be a rather rarely used module, because I'm still using a lot of Windows programs and none of them has a similar problem (it really doesn't go unnoticed...). For the record, Ubuntu using Wine v11 (straight, no DLL overrides). Well, let's hope @msetzerii notices this and has a solution.
Meanwhile you may try something that's known to cause trouble but not the way it looks for you: The editor and default reader module's font handling depends on a printer driver being available, i.e. there must be a default Windows (in your case in Wine, I assume) printer being installed for working properly, it's not required to be active, it's sufficient to use a virtual printer such as a PDF printer.
edited Oct 6 at 10:25 am
6ac442ad98171
6ac443bde1202
6ac443d2dd385
Use the standard linux printer.
I use Fedora 43 on this notebook, but has worked for many versions.
WinPMail version: Version v4.91.1746, 11 Aug 2025 18:19:07, build ID 1746
wine-devel-11.19-1.1.x86_64
winehq-devel-11.19-1.1.x86_64
Printer is local on network.
ipp://Canon%20MX430%20series._ipp._tcp.local/
![6ac442ad98171](serve/attachment&path=6ac442ad98171) ![6ac443bde1202](serve/attachment&path=6ac443bde1202) ![6ac443d2dd385](serve/attachment&path=6ac443d2dd385) Use the standard linux printer. I use Fedora 43 on this notebook, but has worked for many versions. WinPMail version: Version v4.91.1746, 11 Aug 2025 18:19:07, build ID 1746 Language resources: Standard UK English resources (EN,0,LL) Extension Manager version: 1.14 wine-devel-11.19-1.1.x86_64 winehq-devel-11.19-1.1.x86_64 Printer is local on network. ipp://Canon%20MX430%20series._ipp._tcp.local/
Thanks guys. Well, I would have to try it with the actual 4.91, but normally there is already a printer declared on my system (even two):
When I open any email message (in Pegasus 4.73) and chose "print", the "Print to" points to "specific printer - HL-L2310D-series". Given I have never printed an email and it's the system-wide default printer setting, I assume it should also appear in 4.91.
I'll check it out later in the day, I'll also try if changing to the other printer (I also have an old S900 installed) might alleviate the problem. Maybe this infamous text module doesn't like Brother Laser printers?...
So you're telling me that for you it works normally? That's encouraging, I was fearing I'd be stuck with 4.73 for the next 20 years.
Thanks guys. Well, I would have to try it with the actual 4.91, but normally there is already a printer declared on my system (even two): When I open any email message (in Pegasus 4.73) and chose "print", the "Print to" points to "specific printer - HL-L2310D-series". Given I have never printed an email and it's the system-wide default printer setting, I assume it should also appear in 4.91. I'll check it out later in the day, I'll also try if changing to the _other_ printer (I also have an old S900 installed) might alleviate the problem. Maybe this infamous text module doesn't like Brother Laser printers?... [quote="pid:59169, uid:2546"]WinPMail version: Version v4.91.1746, 11 Aug 2025 18:19:07, build ID 1746 [...] winehq-devel-11.19-1.1.x86_64[/quote] So you're telling me that for you it works normally? That's encouraging, I was fearing I'd be stuck with 4.73 for the next 20 years.
I use a Brother laser printer, but I don't run on Linux. Testing with the system default printer set to a pdf printer is my suggestion.
@Al345, do you have IER (IE Renderer) disabled?
Back to you @msetzerii. smile
[quote="pid:59170, uid:36421"]Maybe this infamous text module doesn't like Brother Laser printers?...[/quote] I use a Brother laser printer, but I don't run on Linux. Testing with the system default printer set to a pdf printer is my suggestion. @Al345, do you have IER (IE Renderer) disabled? Back to you @msetzerii. :)
Don't know how I could do that in Linux, but I do also have an old Canon S900 Inkjet printer installed, and I tried that. Same problem.
It doesn't seem to be printer-related, unless I happen to have the two printer drivers which mess up the Pegasus text module...
It definitely isn't a IE Renderer problem since it already happens inside the installer, before you install Pegasus:
Launch a (clean) installation, the little "Pegasus Mail Setup" window pops up. In it click on the "Help" button, all text characters are bunched together...
No need to actually install the program to see this happening.
[quote="pid:59171, uid:28772"]Testing with the system default printer set to a pdf printer is my suggestion.[/quote] Don't know how I could do that in Linux, but I do also have an old Canon S900 Inkjet printer installed, and I tried that. Same problem. It doesn't seem to be printer-related, unless I happen to have the two printer drivers which mess up the Pegasus text module... [quote="pid:59171, uid:28772"]@Al345, do you have IER (IE Renderer) disabled?[/quote] It definitely isn't a IE Renderer problem since **it already happens inside the installer, _before_ you install Pegasus**: Launch a (clean) installation, the little "**Pegasus Mail Setup**" window pops up. In it click on the "Help" button, all text characters are bunched together... No need to actually install the program to see this happening.
edited Oct 6 at 6:48 pm
My bad. I thought the problem was in reading messages.
v4.80 introduced support for higher DPI systems. AFAIK, there is no way to control its behavior. The only way I know to test whether this is indeed the cause is to modify DPI then test. Why this would be Linux specific though is beyond me. AFAIK, there haven't been reports of similar from Windows users.
Another thought, the font of the configuration windows and help content is fixed which make me wonder if perhaps the support for higher DPI included a font change that doesn't exist on your Linux. I don't know what the font is though I'm just posting my thoughts.
[quote="pid:59172, uid:36421"]It definitely isn't a IE Renderer problem since it already happens inside the installer, before you install Pegasus: Launch a (clean) installation, the little "Pegasus Mail Setup" window pops up. In it click on the "Help" button, all text characters are bunched together...[/quote] My bad. I thought the problem was in reading messages. v4.80 introduced support for higher DPI systems. AFAIK, there is no way to control its behavior. The only way I know to test whether this is indeed the cause is to modify DPI then test. Why this would be Linux specific though is beyond me. AFAIK, there haven't been reports of similar from Windows users. Another thought, the font of the configuration windows and help content is fixed which make me wonder if perhaps the support for higher DPI included a font change that doesn't exist on your Linux. I don't know what the font is though I'm just posting my thoughts.
A couple of things. The various versions of the Pegasus Installer do all install IERenderer. So Sometimes the installer itself will fail since wine does not support the IERenderer that is included.
So, one can usually run the installer, and if it fails or even it it goes thru OK and opens Pegasus if you open an email that call IERenderer you get a crash.
Gernerally close Pegasus, go the the PMAIL/Programs direcectory and run the IERenderer uninstall program and it will uninstall it, an Pegasus will run and not load the IERenderer.
Had a few of the installers not work, and ended up doing install on a windows machine and copying the contents of PMAIL/Programs and run the uninstaller.
Contents of my PMAIL/Programs directory is
10713 Oct 29 1995 MLMRGE32.HLP
138 Jul 21 1996 PMDICT3.PMH
449 Dec 14 1996 ORDER.FRM
3884 May 11 1998 TPHONE32.FFF
3275 May 11 1998 MLMRGE32.FFF
68096 Jan 5 2000 TPHONE32.DLL
70144 Jan 20 2000 MLMRGE32.DLL
20675 Aug 28 2001 AUTORPLC.PM
597 Nov 2 2001 VIEWER.PM
574 Nov 8 2002 WINPM-32.EXE.MANIFEST
10049 Mar 31 2003 ORDER32.HLP
136 Apr 22 2004 PREDIS.TXT
628 Apr 22 2004 PR2DIS.TXT
27412 May 17 2005 LIBICONV.TXT
5329 Jul 1 2005 WSSETUP.HLP
17577 Apr 18 2006 FREEIMAGE-LICENSE.TXT
1520279 Aug 5 2008 MANUAL.PDF
577 Sep 1 2008 MBXMAINT_UI.EXE.MANIFEST
3403 Sep 1 2008 ORDER32.FFF
575 Aug 6 2010 LIMITS.EXE.MANIFEST
591 Feb 8 2011 WSSETUP.EXE.MANIFEST
180736 Apr 17 2011 MBXMAINT_UI.EXE
169472 Apr 17 2011 MBXMAINT.EXE
198144 Aug 4 2011 ORDER32.DLL
60600 Dec 21 2011 SETREG.EXE
122552 Dec 21 2011 WSSETUP.EXE
74936 Dec 21 2011 WSENDTO.EXE
337 Jan 6 2012 WSSETUP.DAT
381032 Jan 23 2014 LIBHUNSPELL.DLL
668 Jan 29 2014 README.TXT
35239 Feb 14 2014 WELCOME.DMI
121552 Feb 25 2014 LIMITS.EXE
58576 Feb 25 2014 DESETUP2.EXE
317952 Mar 26 2014 MAPIPM.DLL
109056 Feb 5 2015 DESETUP.EXE
347648 Nov 18 2015 PCONFIG32.EXE
470216 Apr 28 2018 SETPMDEFAULT.EXE
6018560 Jul 31 2018 FREEIMAGE.DLL
978432 Mar 7 2021 ICONV.DLL
453312 Apr 26 2021 SHOWHELP.EXE
122880 Jul 12 2021 SSGP.DLL
766464 Nov 9 2021 HTS32.DLL
4096 Dec 25 2021 DEFAULTS
555240 Dec 25 2021 PMHELP.DLL
11644 Mar 3 2022 WPMSETUP.LOG
94208 Mar 22 2022 TXML2.DLL
4096 Mar 22 2022 RESOURCE
2951680 Mar 24 2022 TER32.DLL
906 Oct 16 2022 MIME-MAP.PM
52155 Apr 2 2024 DEFAULT.DHS
506128 Jul 16 2024 OAUTH2.DLL
4096 Jul 18 2024 DICTS
8617 Sep 9 2024 FILETYPE.PM
464896 Mar 26 2025 HS.EXE
1625248 Mar 26 2025 DHUI.DLL
1024 Jun 5 2025 PMAIL.CFG
134917 Jun 5 2025 WINPM-32.DAT
480256 Jun 11 2025 DICT.RLO
2951296 Jul 3 2025 TCPIP.DLL
1960104 Jul 4 2025 WPM32_EN_0_LL.DLL
1960616 Jul 4 2025 WPM32_EN_1_LL.DLL
601232 Jul 14 2025 TEXTEDIT.DLL
1366176 Jul 28 2025 BASELIB.DLL
2904704 Aug 11 2025 WINPM-32.EXE
1566404 Aug 25 2025 WINPM-32.PHC
4096 Sep 4 2025 PNG
Generally, the files with 2025 are the only once that changed in the 4.91.
Ihave remove some files that I don't use, and the IERenderer program is uninstalled.
The PMAIL.CFG might need to be adjusted if using Single or multi-user to sync with the PMAIL/MAIL/PMAIL.USR and PMAIL/MAIL directory structure.
On a multiuser setup
PMAIL/MAIL PMAIL.USR and user subdirectories.
total 12
drwxr-xr-x. 2 root root 4096 Aug 2 00:53 ADMIN
drwxr-xr-x. 2 root root 4096 May 28 05:48 JaneDoe
-rw-r--r--. 1 root root 47 Apr 15 08:15 PMAIL.USR
In a Single User PMAIL/MAIL with have the PMAIL.USR file and all the Single users files.
On mine it has 370 files instead of just PMAIL.USR and subdirectories.
Have to use PCONFIG32.EXE to modify PMAIL.CFG
With single users it looks like this with a regular linux type PMAIL.CFG
cat PMAIL.CFG
C:\PMAIL\MAILC:\PMAIL\MAIL
But the is misleading since it is a binary file with NULL characters.
Will generally be 512 or 1024 bytes. 1024 Jun 5 2025 PMAIL.CFG
On multi-user it shows.
cat PMAIL.CFG
C:\PMAIL\MAIL~NC:\PMAIL\MAIL~N
1024 Apr 3 2026 PMAIL.CFG
In my mail user directory have single user setup, and have test multiuser setup under root users.
I also using the latest winehq-devel version instead of distro version of wine.
Hope that helps, and doesn't cause confusion.
A couple of things. The various versions of the Pegasus Installer do all install IERenderer. So Sometimes the installer itself will fail since wine does not support the IERenderer that is included. So, one can usually run the installer, and if it fails or even it it goes thru OK and opens Pegasus if you open an email that call IERenderer you get a crash. Gernerally close Pegasus, go the the PMAIL/Programs direcectory and run the IERenderer uninstall program and it will uninstall it, an Pegasus will run and not load the IERenderer. Had a few of the installers not work, and ended up doing install on a windows machine and copying the contents of PMAIL/Programs and run the uninstaller. Contents of my PMAIL/Programs directory is 10713 Oct 29 1995 MLMRGE32.HLP 138 Jul 21 1996 PMDICT3.PMH 449 Dec 14 1996 ORDER.FRM 3884 May 11 1998 TPHONE32.FFF 3275 May 11 1998 MLMRGE32.FFF 68096 Jan 5 2000 TPHONE32.DLL 70144 Jan 20 2000 MLMRGE32.DLL 20675 Aug 28 2001 AUTORPLC.PM 358 Sep 21 2001 DEFAULT.BMP 597 Nov 2 2001 VIEWER.PM 574 Nov 8 2002 WINPM-32.EXE.MANIFEST 10049 Mar 31 2003 ORDER32.HLP 136 Apr 22 2004 PREDIS.TXT 628 Apr 22 2004 PR2DIS.TXT 27412 May 17 2005 LIBICONV.TXT 5329 Jul 1 2005 WSSETUP.HLP 17577 Apr 18 2006 FREEIMAGE-LICENSE.TXT 1520279 Aug 5 2008 MANUAL.PDF 577 Sep 1 2008 MBXMAINT_UI.EXE.MANIFEST 3403 Sep 1 2008 ORDER32.FFF 575 Aug 6 2010 LIMITS.EXE.MANIFEST 4086 Jan 30 2011 ORDER.BMP 2814 Jan 30 2011 TPHONE.BMP 591 Feb 8 2011 WSSETUP.EXE.MANIFEST 180736 Apr 17 2011 MBXMAINT_UI.EXE 169472 Apr 17 2011 MBXMAINT.EXE 198144 Aug 4 2011 ORDER32.DLL 60600 Dec 21 2011 SETREG.EXE 122552 Dec 21 2011 WSSETUP.EXE 74936 Dec 21 2011 WSENDTO.EXE 337 Jan 6 2012 WSSETUP.DAT 381032 Jan 23 2014 LIBHUNSPELL.DLL 668 Jan 29 2014 README.TXT 35239 Feb 14 2014 WELCOME.DMI 121552 Feb 25 2014 LIMITS.EXE 58576 Feb 25 2014 DESETUP2.EXE 317952 Mar 26 2014 MAPIPM.DLL 109056 Feb 5 2015 DESETUP.EXE 347648 Nov 18 2015 PCONFIG32.EXE 470216 Apr 28 2018 SETPMDEFAULT.EXE 6018560 Jul 31 2018 FREEIMAGE.DLL 978432 Mar 7 2021 ICONV.DLL 453312 Apr 26 2021 SHOWHELP.EXE 122880 Jul 12 2021 SSGP.DLL 766464 Nov 9 2021 HTS32.DLL 4096 Dec 25 2021 DEFAULTS 555240 Dec 25 2021 PMHELP.DLL 11644 Mar 3 2022 WPMSETUP.LOG 94208 Mar 22 2022 TXML2.DLL 4096 Mar 22 2022 RESOURCE 2951680 Mar 24 2022 TER32.DLL 18054 Apr 5 2022 smallphone.bmp 906 Oct 16 2022 MIME-MAP.PM 52155 Apr 2 2024 DEFAULT.DHS 506128 Jul 16 2024 OAUTH2.DLL 4096 Jul 18 2024 DICTS 8617 Sep 9 2024 FILETYPE.PM 464896 Mar 26 2025 HS.EXE 1625248 Mar 26 2025 DHUI.DLL 1024 Jun 5 2025 PMAIL.CFG 134917 Jun 5 2025 WINPM-32.DAT 480256 Jun 11 2025 DICT.RLO 2951296 Jul 3 2025 TCPIP.DLL 1960104 Jul 4 2025 WPM32_EN_0_LL.DLL 1960616 Jul 4 2025 WPM32_EN_1_LL.DLL 601232 Jul 14 2025 TEXTEDIT.DLL 1366176 Jul 28 2025 BASELIB.DLL 2904704 Aug 11 2025 WINPM-32.EXE 1566404 Aug 25 2025 WINPM-32.PHC 4096 Sep 4 2025 PNG Generally, the files with 2025 are the only once that changed in the 4.91. Ihave remove some files that I don't use, and the IERenderer program is uninstalled. The PMAIL.CFG might need to be adjusted if using Single or multi-user to sync with the PMAIL/MAIL/PMAIL.USR and PMAIL/MAIL directory structure. On a multiuser setup PMAIL/MAIL PMAIL.USR and user subdirectories. total 12 drwxr-xr-x. 2 root root 4096 Aug 2 00:53 ADMIN drwxr-xr-x. 2 root root 4096 May 28 05:48 JaneDoe -rw-r--r--. 1 root root 47 Apr 15 08:15 PMAIL.USR In a Single User PMAIL/MAIL with have the PMAIL.USR file and all the Single users files. On mine it has 370 files instead of just PMAIL.USR and subdirectories. Have to use PCONFIG32.EXE to modify PMAIL.CFG With single users it looks like this with a regular linux type PMAIL.CFG cat PMAIL.CFG C:\PMAIL\MAILC:\PMAIL\MAIL But the is misleading since it is a binary file with NULL characters. Will generally be 512 or 1024 bytes. 1024 Jun 5 2025 PMAIL.CFG On multi-user it shows. cat PMAIL.CFG C:\PMAIL\MAIL\~NC:\PMAIL\MAIL\~N 1024 Apr 3 2026 PMAIL.CFG In my mail user directory have single user setup, and have test multiuser setup under root users. I also using the latest winehq-devel version instead of distro version of wine. wine-devel-11.19-1.1.x86_64 winehq-devel-11.19-1.1.x86_64 Hope that helps, and doesn't cause confusion.
That too. Actually all windows containing text boxes are garbled. And well before I even install Pegasus - The installer program already has that bug.
[quote="pid:59173, uid:28772"]My bad. I thought the problem was in reading messages.[/quote] That too. Actually all windows containing text boxes are garbled. And well before I even install Pegasus - The installer program already has that bug.
Yes, I had this problem in 4.73, and solved it by simply removing IERender.fff (or some such).
But here it can't be an IERender issue, unless the program's help is using IERender too. As I said above, even in the installer, before it drops any files anywhere, text is garbled (in Help)...
For memory: No Pegasus installed - I launch the installer, go to the installer's "Help", the text is already garbled. This means the problem is in the program itself. Since 4.80 the module it uses to display textboxes (anywhere in the program) is broken for me.
I did have the IERender issue, so I know about it, but this here must be a different one. It doesn't just prevent me from reading HTML mails, it actually garbles all text displayed anywhere in the program, except for menus.
And yes, I have an old-fashioned single-user setup, the kind with with a /MAIL folder inside /Programs (but in this case /MAIL it is on a different drive, my PMAIL.CFG simply points to it).
[quote="pid:59174, uid:2546"]So, one can usually run the installer, and if it fails or even it it goes thru OK and opens Pegasus if you open an email that call IERenderer you get a crash.[/quote] Yes, I had this problem in 4.73, and solved it by simply removing IERender.fff (or some such). But here it can't be an IERender issue, unless the program's help is using IERender too. As I said above, even in the installer, before it drops any files anywhere, text is garbled (in Help)... For memory: No Pegasus installed - I launch the installer, go to the installer's "Help", the text is already garbled. This means the problem is in the program itself. Since 4.80 the module it uses to display textboxes (anywhere in the program) is broken for me. I did have the IERender issue, so I know about it, but this here must be a different one. It doesn't just prevent me from reading HTML mails, it actually garbles _all text_ displayed _anywhere_ in the program, except for menus. And yes, I have an old-fashioned single-user setup, the kind with with a /MAIL folder inside /Programs (but in this case /MAIL it is on a different drive, my PMAIL.CFG simply points to it).
edited Oct 7 at 5:14 pm
Hello:
I have the same issue.
https://community.pmail.com/index.php?u=/topic/12495/IERenderer%20or%20BearHTML%20issue?
Tried to install Pmail to a VM running [XPSP3] but it will not install.
As it that was not enough (true MS fashion, no indication of what is going on is given) so the replacing of the PMAIL/Programs directory will not be possible.
The latest [IERenderer] installer [IERenderer-2.7.4.0] will not install with Wine so that is also a no-go.
My box uses [CUPS] and I can print (seldom do) emails to the Windows default printer (Samsung_2020_M2020_Series). Changing to a specific or virtual printer does not change anything.
Is there any way around this?
ie: with v4.91 I simply cannot write any emails and many email I have already read cannot be read, even the mails header (From: Subject, etc.) are garbled.
6ac8e861a6990
6ac8e87527a4f
Thanks for your time and attention.
Best,
S.
Hello: I have the same issue. https://community.pmail.com/index.php?u=/topic/12495/IERenderer%20or%20BearHTML%20issue? Tried to install Pmail to a VM running [XPSP3] but it will not install. As it that was not enough (true MS fashion, no indication of what is going on is given) so the replacing of the PMAIL/Programs directory will not be possible. The latest [IERenderer] installer [IERenderer-2.7.4.0] will not install with Wine so that is also a no-go. My box uses [CUPS] and I can print (seldom do) emails to the Windows default printer (Samsung_2020_M2020_Series). Changing to a specific or virtual printer does not change anything. Is there any way around this? ie: with v4.91 I simply _cannot_ write any emails and many email I have already read cannot be read, even the mails header (From: Subject, etc.) are garbled. ![6ac8e861a6990](serve/attachment&path=6ac8e861a6990) ![6ac8e87527a4f](serve/attachment&path=6ac8e87527a4f) Thanks for your time and attention. Best, S.
Once again there are a number of issues that need to be addressed.
  1. The Programs Directory.If the installation program doesn't run on your setup, these are the latest files for the 4.91 Believe if you have 4.80 or later, copying these files are the files that changed for 4.91.
4096 Sep 4 2025 PNG (directory, think 1 file added?
Again, exactly what happens when you run install.
After install, wine does not work with IERenderer, so it needs to be uninstalled via it's uninstall program that is in directory.
A second thing 3 files need to be setup correctly depending if you have a single user or multi-user setup.
What your need.
Single User setup will have PMAIL/MAIL have a larger number of files
Multi-user will have a very small set of file.
Single users will see this cat PMAIL.CFG
cat PMAIL.CFG
But that is NOT the contents since it has NULLs, but is the easy way to check.
Multi-User setup will show something like this.
cat PMAIL.CFG
If these are not matched, Pegasus will look for mail in the wrong location.
PCONFIG32.EXE is program that is used to change it. Not an Editor.
In single user setup the PMAIL.INI file will have lines like this.
Working home mailbox location = C:\PMAIL\MAIL
New mailbox location = C:\PMAIL\MAIL
Multi-User will have lines like this.
Working home mailbox location = C:\PMAIL\MAIL\ADMIN
New mailbox location = C:\PMAIL\MAIL\ADMIN
If any of these are not correctly setup, you will not have Pegasus working correctly.
On my setup, I've remove IERenderer and BearHTML files, and use the Ter32.dll and HTS.dll file.
I also use the winehq-devel.
Rather than the Fedora's version of wine since it is much older.
Once again there are a number of issues that need to be addressed. 1. The Programs Directory. If the installation program doesn't run on your setup, these are the latest files for the 4.91 Believe if you have 4.80 or later, copying these files are the files that changed for 4.91. ```` 134917 Jun 5 2025 WINPM-32.DAT 480256 Jun 11 2025 DICT.RLO 2951296 Jul 3 2025 TCPIP.DLL 1960104 Jul 4 2025 WPM32_EN_0_LL.DLL 1960616 Jul 4 2025 WPM32_EN_1_LL.DLL 601232 Jul 14 2025 TEXTEDIT.DLL 1366176 Jul 28 2025 BASELIB.DLL 2904704 Aug 11 2025 WINPM-32.EXE 1566404 Aug 25 2025 WINPM-32.PHC 4096 Sep 4 2025 PNG (directory, think 1 file added? ```` Again, exactly what happens when you run install. After install, wine does not work with IERenderer, so it needs to be uninstalled via it's uninstall program that is in directory. A second thing 3 files need to be setup correctly depending if you have a single user or multi-user setup. 1024 Jun 5 2025 PMAIL.CFG What your need. Single User setup will have PMAIL/MAIL have a larger number of files Multi-user will have a very small set of file. drwxr-xr-x. 2 root root 4096 Aug 2 00:53 ADMIN drwxr-xr-x. 2 root root 4096 May 28 05:48 JaneDoe -rw-r--r--. 1 root root 47 Apr 15 08:15 PMAIL.USR Single users will see this cat PMAIL.CFG cat PMAIL.CFG C:\PMAIL\MAILC:\PMAIL\MAIL But that is NOT the contents since it has NULLs, but is the easy way to check. Multi-User setup will show something like this. cat PMAIL.CFG C:\PMAIL\MAIL\~NC:\PMAIL\MAIL\~N If these are not matched, Pegasus will look for mail in the wrong location. PCONFIG32.EXE is program that is used to change it. Not an Editor. In single user setup the PMAIL.INI file will have lines like this. Working home mailbox location = C:\PMAIL\MAIL New mailbox location = C:\PMAIL\MAIL Multi-User will have lines like this. Working home mailbox location = C:\PMAIL\MAIL\ADMIN New mailbox location = C:\PMAIL\MAIL\ADMIN If any of these are not correctly setup, you will not have Pegasus working correctly. On my setup, I've remove IERenderer and BearHTML files, and use the Ter32.dll and HTS.dll file. I also use the winehq-devel. wine-devel-11.19-1.1.x86_64 winehq-devel-11.19-1.1.x86_64 Rather than the Fedora's version of wine since it is much older.
Hello:
... number of issues that need to be addressed.
Right.
If the installation program doesn't run on your setup ...
But it does ...
It runs (apparently) exactly as it should.
The problem is the result of the installation.
Please see my other post here.
TL;DR: the upgrade went through just fine, ready to go in under 5 minutes with no adjustments needed, everything picked up exactly where v4.73 left but with the new SSL version working properly.
The problem does not seem to be in PMail itself (mail can be retrieved, POP3 and IMAP work and I expect that SMTP also works). The problem seems to be with whatever is used to render, write/edit email text.
So ...
To avoid eventual problems stemming from my installation being from way back, I backed up the [PMAIL/MAIL] directory and nuked the rest (still have BiT backups).
I then installed the same WinPMail version, this time 'from scratch'.
ie: v4.91.1746, 11 Aug 2025 18:19:07, build ID 1746
Here are the screenshots showing what is happening:
  1. PMail open on the desktop with preview (which I do not use).6ac956f769bec
  2. Welcome message opened via double click 6ac957a1cdb93
  3. Welcome message ready to reply and after hitting a lot of keys at random.6ac95863b911e
  4. Window with a message (after hitting a lot of keys at random)6ac95909a45de
As you can see from the screenshots previously posted, these same issues can be observed in the upgraded v4.73.
I see no issues with the installation, like I mentioned above, the upgrade went as expected with all my email accounts.
This is some sort of rendering problem which (if I recall correctly) caused me to roll back the upgrade to v4.81. No problem with that because SSL was working properly, but with the old vesions (1.0 and 1.1) being deprecated that was no longer possible.
I had a similar problem with the [Xfw] application (X File Write text editor) from the [Xfe] suite: it would have severe issues when typing a text, albeit not as bad as what I am seeing here, possibly related to the FOX toolkit used.
That said, I cannot find anything IErenderer related in this installation:
~/.wine/drive_c/PMAIL/Programs$ ls | grep -i renderer
Let me know if you need any other information.
I will now go back to the working version and if needed I would install a second instance of PMail to test, but I would need a guide as to how itis done without affecting or compromising the working version.
Best,
S.
Hello: [quote="pid:59187, uid:2546"] ... number of issues that need to be addressed. [/quote] Right. [quote="pid:59187, uid:2546"] If the installation program doesn't run on your setup ... [/quote] But it does ... It runs (apparently) exactly as it should. The problem is the _result_ of the installation. Please see my other post [here](https://community.pmail.com/index.php?u=/topic/12495/ierenderer-or-bearhtml-issue/1#post-59185). TL;DR: the upgrade went through just fine, ready to go in under 5 minutes with no adjustments needed, everything picked up exactly where v4.73 left but with the new SSL version working properly. The problem does not seem to be in PMail _itself_ (mail can be retrieved, POP3 and IMAP work and I expect that SMTP also works). The problem seems to be with whatever is used to render, write/edit email text. So ... To avoid eventual problems stemming from my installation being from way back, I backed up the [PMAIL/MAIL] directory and nuked the rest (still have BiT backups). I then installed the same WinPMail version, this time 'from scratch'. ie: v4.91.1746, 11 Aug 2025 18:19:07, build ID 1746 Here are the screenshots showing what is happening: 1. PMail open on the desktop with preview (which I do not use). ![6ac956f769bec](serve/attachment&path=6ac956f769bec) 2. Welcome message opened via double click ![6ac957a1cdb93](serve/attachment&path=6ac957a1cdb93) 3. Welcome message ready to reply and after hitting a lot of keys at random. ![6ac95863b911e](serve/attachment&path=6ac95863b911e) 4. Window with a message (after hitting a lot of keys at random)![6ac95909a45de](serve/attachment&path=6ac95909a45de) As you can see from the screenshots previously posted, these same issues can be observed in the upgraded v4.73. I see no issues with the installation, like I mentioned above, the upgrade went as expected with all my email accounts. This is some sort of rendering problem which (if I recall correctly) caused me to roll back the upgrade to v4.81. No problem with that because SSL was working properly, but with the old vesions (1.0 and 1.1) being deprecated that was no longer possible. I had a similar problem with the [Xfw] application (X File Write text editor) from the [Xfe] suite: it would have severe issues when typing a text, albeit not as bad as what I am seeing here, possibly related to the FOX toolkit used. That said, I cannot find anything `IErenderer` related in this installation: ```` ~/.wine/drive_c/PMAIL/Programs$ ls | grep -i renderer ~/.wine/drive_c/PMAIL/Programs$ ```` Let me know if you need any other information. I will now go back to the working version and if needed I would install a second instance of PMail to test, but I would need a guide as to how itis done without affecting or compromising the working version. Thanks for your time and attention. Best, S.
edited Oct 12 at 4:45 am
Yes, this is clearly the same issue, that's what all text boxes (messages, read or write, and the program's help) look on my computer too.
So I'm not alone. (Would had wondered me too.)
Pegasus Mail version 4.73 works normally, all later versions are broken, so it's something which has changed since Pegasus 4.73.
Sorry, but focusing on PMAIL.CFG and "mail user setups" is totally out of topic: In my case it's just a simple upgrade, not a new installation. And for memory, I've been using Pegasus for a quarter of a century, I do know by now how to install, configure and tweak it. (I had even bought the manual, back then when this was still a thing... :-) )
The problem is clearly in the text display module used since v4.80.
If somebody please has some constructive suggestion on how to bypass this issue, please let us hear it.
[quote="pid:59186, uid:28059"]I have the same issue.[/quote] Yes, this is clearly the same issue, that's what all text boxes (messages, read or write, and the program's help) look on my computer too. So I'm not alone. (Would had wondered me too.) **Pegasus Mail version 4.73 works normally, all later versions are broken, so it's something which has changed since Pegasus 4.73.** Sorry, but focusing on PMAIL.CFG and "mail user setups" is totally out of topic: In my case it's just a simple upgrade, **not a new installation**. And for memory, I've been using Pegasus for a quarter of a century, I _do_ know by now how to install, configure and tweak it. (I had even bought the manual, back then when this was still a thing... :-) ) The problem is clearly in the text display module used since v4.80. If somebody please has some constructive suggestion on how to bypass this issue, please let us hear it.
edited Oct 10 at 7:19 am
Hello:
... clearly the same issue ...
Yes, I cannot but concurr.
Pegasus Mail version 4.73 works normally ...
Indeed.
Just today, when writing up my previous post did I rermember that I had (long ago, a couple of months after it came out) upgraded to v4.80 and rolled it back because of a similar(?) issue.
v4.73 has worked perfectly well from when I first upgraded to it and continued to do so over all the Linux distributions I have gone through from ca.2014 onwards. Were not for the deprecated [SSL1.0/1.1] versions, everything would be well enough.
... something which has changed since Pegasus 4.73.
Yes.
But what?
... just a simple upgrade, not a new installation.
I have tried both and can confirm that the problem exists in an upgrade from v4.73 or a new/clean installation.
... been using Pegasus for a quarter of a century ...
Same here: it has always worked properly.
... problem is clearly in the text display module used since v4.80.
I would have to agree but with the caveat that I have no knowledge of how that works.
What I can say is that the rest of PMail v4.91 works as intended.
... suggestion on how to bypass this issue, please let us hear it.
What you say makes me wonder:
Could v4.73 be somehow be made to use SSL1.2/1.3?
That would fix it for me.
All this said, we must bear in mind that Pegasus Mail is a heroic and decades long one-man operation run by David Harris in New Zealand and that his code, even through all the re-writing it has gone through, is probably huge, has the kinks 35+ year old code can have and that PMail's core editor is (as I remember it) proprietary software.
Thanks for your input.
S.
Hello: [quote="pid:59192, uid:36421"] ... clearly the same issue ... [/quote] Yes, I cannot but concurr. [quote="pid:59192, uid:36421"] Pegasus Mail version 4.73 works normally ... [/quote] Indeed. Just today, when writing up my previous post did I rermember that I had (long ago, a couple of months after it came out) upgraded to v4.80 and rolled it back because of a similar(?) issue. v4.73 has worked perfectly well from when I first upgraded to it and continued to do so over all the Linux distributions I have gone through from ca.2014 onwards. Were not for the deprecated [SSL1.0/1.1] versions, everything would be well enough. [quote="pid:59192, uid:36421"] ... something which has changed since Pegasus 4.73. [/quote] Yes. But what? [quote="pid:59192, uid:36421"] ... just a simple upgrade, not a new installation. [/quote] I have tried both and can confirm that the problem exists in an upgrade from v4.73 or a new/clean installation. [quote="pid:59192, uid:36421"] ... been using Pegasus for a quarter of a century ... [/quote] Same here: it has always worked properly. [quote="pid:59192, uid:36421"] ... problem is clearly in the text display module used since v4.80. [/quote] I would have to agree but with the caveat that I have no knowledge of how that works. What I _can_ say is that the rest of PMail v4.91 works as intended. [quote="pid:59191, uid:28059"]TL;DR: the upgrade went through just fine, ready to go in under 5 minutes with no adjustments needed, everything picked up exactly where v4.73 left but with the new SSL version working properly.[/quote] [quote="pid:59192, uid:36421"] ... suggestion on how to bypass this issue, please let us hear it. [/quote] What you say makes me wonder: Could v4.73 be somehow be made to use SSL1.2/1.3? That would fix it for me. All this said, we **must** bear in mind that Pegasus Mail is a heroic and decades long one-man operation run by David Harris in New Zealand and that his code, even through all the re-writing it has gone through, is probably huge, has the kinks 35+ year old code can have and that PMail's core editor is (as I remember it) proprietary software. Thanks for your input. S.
edited Oct 10 at 8:49 am
  • I know that that support for higher DPI system was introduced in v4.80. I believe this was intended to alleviate the problem of the Pegasus Mail system fixed fonts being extremely small on high DPI systems in versions 4.73 and earlier. I don't anything about Linux regarding whether testing at a different DPI is possible, but if it is, and someone is willing, it would be nice to know whether a DPI change affects the display of Pegasus Mail config windows and Help. There is also something tickling my brain about a change in the font as well. My attempts at trying to confirm that have failed so far, but I'm still working on it because I wonder if perhaps the font used in the 4.80+ versions of Pegasus Mail does not exist on some Linux system.
Installing a test instance of 4.91 would be a valuable test as a way to check whether a configuration setting stored in the current mailbox could be causing the problem. This is how I would do it:
  • Backup C:\PMAIL for safety.
  • Record your existing shortcut command line so you can restore if it changes (likely, that is if the installer creates shortcuts on Linux).
  • Rename C:\PMAIL_473.
  • Do a clean installation of 4.91 to C:\PMAIL. Do not worry about any additional configuration (eg: Internet options). All you want to do is get it to a point where you can start it up and access its configuration windows.
  • Once you reach the point where it starts up as expected, close it, then rename C:\PMAIL to C:\PMAIL_491.
  • Rename C:\PMAIL_473 back to C:\PMAIL
  • Restore your original shortcut command line if needed.
  • Create a new shortcut to the 4.91 test instance. Include the -O (oh, not zero) command line option to force it to start it in offline mode. (eg: C:\PMAIL_491\Programs\winpm-32.exe -O).
Keep in mind that in Windows, each time Pegasus Mail is run it records the last run instance in the registry which future installs and updates will use to pre-populate the path. I don't know whether this is a concern under Wine so keep it in mind.
- I know that that support for higher DPI system was introduced in v4.80. I believe this was intended to alleviate the problem of the Pegasus Mail system fixed fonts being extremely small on high DPI systems in versions 4.73 and earlier. I don't anything about Linux regarding whether testing at a different DPI is possible, but if it is, and someone is willing, it would be nice to know whether a DPI change affects the display of Pegasus Mail config windows and Help. There is also something tickling my brain about a change in the font as well. My attempts at trying to confirm that have failed so far, but I'm still working on it because I wonder if perhaps the font used in the 4.80+ versions of Pegasus Mail does not exist on some Linux system. [quote="pid:59191, uid:28059"]I will now go back to the working version and if needed I would install a second instance of PMail to test, but I would need a guide as to how itis done without affecting or compromising the working version.[/quote] Installing a test instance of 4.91 would be a valuable test as a way to check whether a configuration setting stored in the current mailbox could be causing the problem. This is how I would do it: - Backup C:\PMAIL for safety. - Record your existing shortcut command line so you can restore if it changes (likely, that is if the installer creates shortcuts on Linux). - Rename C:\PMAIL_473. - Do a clean installation of 4.91 to C:\PMAIL. Do not worry about any additional configuration (eg: Internet options). All you want to do is get it to a point where you can start it up and access its configuration windows. - Once you reach the point where it starts up as expected, close it, then rename C:\PMAIL to C:\PMAIL_491. - Rename C:\PMAIL_473 back to C:\PMAIL - Restore your original shortcut command line if needed. - Create a new shortcut to the 4.91 test instance. Include the -O (oh, not zero) command line option to force it to start it in offline mode. (eg: C:\PMAIL_491\Programs\winpm-32.exe -O). Keep in mind that in Windows, each time Pegasus Mail is run it records the last run instance in the registry which future installs and updates will use to pre-populate the path. I don't know whether this is a concern under Wine so keep it in mind.
Same here. That's why I still had 4.80 on my computer.
Obviously, since in both cases the result is the same: v4.91... :-D
I've tried both at first, just in case there was a bug in the update process. But there isn't, it's actually a feature.
When you create programs, you rarely make everything from scratch, you often use several prefabricated pieces doing a specific job to speed up things. In this case the module used to display text since 4.80 is apparently not Linux-compatible, it doesn't play nice with Wine.
No, that would mean rewrite 4.73. What might be easier is to fix 4.91's text module so it doesn't explode in Wine.
All this said, we must bear in mind that Pegasus Mail [...]
Definitely, but Pegasus Mail isn't the problem here, it works fine.
What does not work is the new textbox module under Wine.
[quote="pid:59194, uid:28059"]I rermember that I had (long ago, a couple of months after it came out) upgraded to v4.80 and rolled it back because of a similar(?) issue.[/quote] Same here. That's why I still had 4.80 on my computer. [quote="pid:59194, uid:28059"]I have tried both and can confirm that the problem exists in an upgrade from v4.73 or a new/clean installation.[/quote] Obviously, since in both cases the result is the same: v4.91... :-D I've tried both at first, just in case there was a bug in the update process. But there isn't, it's actually a feature. [quote="pid:59194, uid:28059"]I would have to agree but with the caveat that I have no knowledge of how that works.[/quote] When you create programs, you rarely make everything from scratch, you often use several prefabricated pieces doing a specific job to speed up things. In this case the module used to display text since 4.80 is apparently not Linux-compatible, it doesn't play nice with Wine. [quote="pid:59194, uid:28059"]What you say makes me wonder: Could v4.73 be somehow be made to use SSL1.2/1.3? That would fix it for me.[/quote] No, that would mean rewrite 4.73. What might be easier is to fix 4.91's text module so it doesn't explode in Wine. [quote="pid:59194, uid:28059"]All this said, we must bear in mind that Pegasus Mail [...][/quote] Definitely, but Pegasus Mail isn't the problem here, it works fine. What does _not_ work is the new textbox module _under Wine_.
edited Oct 10 at 6:29 pm
Which fonts are you talking about?
I don't think this is related, the exploding textboxes in the mail messages are using Window's fonts: Click "Font" and you can change it to any font installed in the system, and to any size you want.
You can't change Help font and size AFAIK, but you can do anything you want with the email reader/writer windows, including displaying them in hieroglyphs (if you have the fitting TTF)... :-D
That could be indeed, in this case the solution is simple, you just need to copy it over from a Windows box (I doubt though a missing font would result in the character salad you can see in sawbona's pictures, but who knows).
Tell me which font Pegasus >4.73 expects, and I'll try it tomorrow.
I've gotten very proficient at deleting/installing/re-deleting/reinstalling... Takes me 10 seconds in all. The fact my /MAIL folder lives on another drive does help, I just delete everything except "PMAIL.CFG" and install the new (old) version instead.
registry
Yes, Wine has a registry but it's like WinXP, not as finicky as Win10/11's one. I didn't have problems simply deleting the Pegasus files, reinstalling another version in the same spot, re-deleting, re-installing an older version, again and again. Everything goes.
Wine is actually much more user-friendly than Windows...
[quote="pid:59197, uid:28772"]Pegasus Mail system fixed fonts being extremely small on high DPI systems in versions 4.73 and earlier.[/quote] Which fonts are you talking about? I don't think this is related, the exploding textboxes in the mail messages are using Window's fonts: Click "Font" and you can change it to any font installed in the system, and to any size you want. You can't change Help font and size AFAIK, but you can do anything you want with the email reader/writer windows, including displaying them in hieroglyphs (if you have the fitting TTF)... :-D [quote="pid:59197, uid:28772"]I wonder if perhaps the font used in the 4.80+ versions of Pegasus Mail does not exist on some Linux system.[/quote] That could be indeed, in this case the solution is simple, you just need to copy it over from a Windows box (I doubt though a missing font would result in the character salad you can see in sawbona's pictures, but who knows). Tell me which font Pegasus >4.73 expects, and I'll try it tomorrow. I've gotten _very_ proficient at deleting/installing/re-deleting/reinstalling... Takes me 10 seconds in all. The fact my /MAIL folder lives on another drive does help, I just delete everything except "PMAIL.CFG" and install the new (old) version instead. [quote="pid:59197, uid:28772"]registry[/quote] Yes, Wine has a registry but it's like WinXP, not as finicky as Win10/11's one. I didn't have problems simply deleting the Pegasus files, reinstalling another version in the same spot, re-deleting, re-installing an older version, again and again. Everything goes. Wine is actually much more user-friendly than Windows...
1234 ... 5
