Make a suggestion. Include your distro and exact version of wine you are running. It is not one wine. distros have theirs, and winehq has theirs.
For Me, Fedora version is very dated, and there are bugs I and other found, and they have fixed in the devel version. Might be you are running older wine that doesn't have those patches/fixes.
Linux 7.2.9-100.fc43.x86_64 #1 SMP PREEMPT_DYNAMIC Sat Oct 3 18:35:12 UTC 2026 x86_64 GNU/Linux
wine-devel-11.19-1.1.x86_64
winehq-devel-11.19-1.1.x86_64
winehq shows.
Latest Releases
Stable: Wine 11.0
Development: Wine 11.19
The default Fedora repository provides Wine version 11.0 so it is older.
Sometime find a new development version has issues, but can just downgrade and report the problem. They have generally found issue, and fix shortly.
So, the problem might not be with 4.91, but with an issue in the wine others are running. But I've found 4.91 solid. with devel winehq.
I do have my winecfg set to 120dpi.
Can just say what works for me.
Under fedora winehq shows 3 options.
Stable branch sudo dnf install winehq-stable
Development branch sudo dnf install winehq-devel
Staging branch sudo dnf install winehq-staging
Don't recall exactly what staging is?
Good Luck to others.
