Hello:
@ AI345:
There has been an update at WineHQ Bugzilla for your report (60506).
Still unconfirmed, its has been downgraded from [P2 blocker] to [P2 normal].
Best,
S.
Hello: [quote="pid:59243, uid:36421"] Done: https://bugs.winehq.org/show_bug.cgi?id=60506 [/quote] @ AI345: There has been an [update](https://bugs.winehq.org/show_activity.cgi?id=60506) at WineHQ Bugzilla for your report (60506). Still unconfirmed, its has been downgraded from [P2 blocker] to [P2 normal]. Best, S.
edited Nov 14 at 7:38 am
Think this tread has lots of conflicting info.
What I see is this:
Linux Devuan Daedalus+Wine-8+Pegasus Mail 4.73 -> works
Linux Devuan Daedalus+Wine-8+Pegasus Mail 4.80 -> does not work
Linux Devuan Daedalus+Wine-8+Pegasus Mail 4.81 -> does not work
Linux Devuan Daedalus+Wine-8+Pegasus Mail 4.91 -> does not work
*Debian 8.0~repack-4 from the Devuan Linux repositories
Don't know anything of this release of Linux or why it is showing Wine-8?
Wine is at version 11 not 8.
I tried the steps listed in Bug report and I see text just fine.
Fedora 44 currently running Wine 11.22 development, but also works with the 11 stable.
rpm -qa | grep wine
wine-filesystem-11.20-1.fc44.noarch
wine-tahoma-winefonts-11.20-1.fc44.noarch
wine-times-new-roman-winefonts-11.20-1.fc44.noarch
wine-wingdings-winefonts-11.20-1.fc44.noarch
wine-webdings-winefonts-11.20-1.fc44.noarch
wine-system-winefonts-11.20-1.fc44.noarch
wine-symbol-winefonts-11.20-1.fc44.noarch
wine-small-winefonts-11.20-1.fc44.noarch
wine-ms-sans-serif-winefonts-11.20-1.fc44.noarch
wine-marlett-winefonts-11.20-1.fc44.noarch
wine-fixedsys-winefonts-11.20-1.fc44.noarch
wine-courier-winefonts-11.20-1.fc44.noarch
wine-arial-winefonts-11.20-1.fc44.noarch
wine-winefonts-11.20-1.fc44.noarch
wine-wingdings-fonts-system-11.20-1.fc44.noarch
wine-times-new-roman-fonts-system-11.20-1.fc44.noarch
wine-tahoma-fonts-system-11.20-1.fc44.noarch
wine-mono-11.3.0-1.fc44.noarch
wine-systemd-11.20-1.fc44.noarch
wine-devel-11.22-1.1.x86_64
winehq-devel-11.22-1.1.x86_64
So, don't know exactly what wine is suppose to do. If this release is locked in a 3 major versions old release of wine.
I get
uname -a
Linux setzcodell.dyndns.org 7.3.4-200.fc44.x86_64 #1 SMP PREEMPT_DYNAMIC Tue Nov 10 22:45:35 UTC 2026 x86_64 GNU/Linux
What does the distro with the problem showing?
What is the CPU.
Fedora uses dnf5 is this distro use apt or other package manager.
Have done some bugzilla reports and the issues were resolved, but don't see enough info to see exactly what the issue falls under.
Good Luck.
Think this tread has lots of conflicting info. What I see is this: Linux Devuan Daedalus+Wine-8+Pegasus Mail 4.73 -> works Linux Devuan Daedalus+Wine-8+Pegasus Mail 4.80 -> does not work Linux Devuan Daedalus+Wine-8+Pegasus Mail 4.81 -> does not work Linux Devuan Daedalus+Wine-8+Pegasus Mail 4.91 -> does not work *Debian 8.0~repack-4 from the Devuan Linux repositories Don't know anything of this release of Linux or why it is showing Wine-8? Wine is at version 11 not 8. I tried the steps listed in Bug report and I see text just fine. Fedora 44 currently running Wine 11.22 development, but also works with the 11 stable. rpm -qa | grep wine wine-filesystem-11.20-1.fc44.noarch wine-tahoma-winefonts-11.20-1.fc44.noarch wine-times-new-roman-winefonts-11.20-1.fc44.noarch wine-wingdings-winefonts-11.20-1.fc44.noarch wine-webdings-winefonts-11.20-1.fc44.noarch wine-system-winefonts-11.20-1.fc44.noarch wine-symbol-winefonts-11.20-1.fc44.noarch wine-small-winefonts-11.20-1.fc44.noarch wine-ms-sans-serif-winefonts-11.20-1.fc44.noarch wine-marlett-winefonts-11.20-1.fc44.noarch wine-fixedsys-winefonts-11.20-1.fc44.noarch wine-courier-winefonts-11.20-1.fc44.noarch wine-arial-winefonts-11.20-1.fc44.noarch wine-winefonts-11.20-1.fc44.noarch wine-wingdings-fonts-system-11.20-1.fc44.noarch wine-times-new-roman-fonts-system-11.20-1.fc44.noarch wine-tahoma-fonts-system-11.20-1.fc44.noarch wine-mono-11.3.0-1.fc44.noarch wine-systemd-11.20-1.fc44.noarch wine-devel-11.22-1.1.x86_64 winehq-devel-11.22-1.1.x86_64 So, don't know exactly what wine is suppose to do. If this release is locked in a 3 major versions old release of wine. I get uname -a Linux setzcodell.dyndns.org 7.3.4-200.fc44.x86_64 #1 SMP PREEMPT_DYNAMIC Tue Nov 10 22:45:35 UTC 2026 x86_64 GNU/Linux What does the distro with the problem showing? What is the CPU. Fedora uses dnf5 is this distro use apt or other package manager. Have done some bugzilla reports and the issues were resolved, but don't see enough info to see exactly what the issue falls under. Good Luck.
Hello:
No.
It does not.
If you don't know in spite of having been explained to you both by me (at least once) and by AI345 (more that once), please take a breath and read the thread again.
That said, I would respectfully ask that you stop muddying the waters. 8^°
Best,
S.
Hello: [quote="pid:59353, uid:2546"] Think this tread has lots of conflicting info. [/quote] No. It does not. [/quote] [quote="pid:59353, uid:2546"] Don't know anything of this release of Linux or why it is showing Wine-8? [/quote] If you _don't know_ in spite of having been explained to you both by me (at least once) and by AI345 (more that once), please take a breath and read the thread again. That said, I would respectfully ask that you stop muddying the waters. 8^° Best, S.
Guess you are much smarter than me. Seems the locked in Wine8 for some reason, though the newer wine can be installed, but it then breaks whatever reason the locked at wine 8? So, good luck, but I don't think winehq will bother even looking at it. If you come out with solution would be interested.
Works perfectly on my system.
Guess you are much smarter than me. Seems the locked in Wine8 for some reason, though the newer wine can be installed, but it then breaks whatever reason the locked at wine 8? So, good luck, but I don't think winehq will bother even looking at it. If you come out with solution would be interested. Works perfectly on my system.
Translation: "We'll look into that, eventually..." :-(
No surprise since our resident Alzheimer case rushed to tell them there is actually no problem at all.
[quote="pid:59352, uid:28059"]There has been an update at WineHQ Bugzilla for your report (60506). Still unconfirmed, its has been downgraded from [P2 blocker] to [P2 normal].[/quote] Translation: "We'll look into that, _eventually_..." :-( No surprise since our resident Alzheimer case rushed to tell them there is actually no problem at all.
Hello:
Not necessarily so.
I think ...
Looking at the bug severity field list [WineHQ Bugzilla] has, I find these relevant definitions:
blocker     [Blocks development] and/or testing work
critical Critical problem that [prevents all applications] from working
major Major loss of functionality for a [wide range of applications]
normal For an [application] crash or [loss of functionality] ### <- this
I would think that our problem fits the WineHQ's 'normal' definition.
ie: does not affect any application (that we know of) other than Pegasus Mail from v4.80 onwards.
The good news is that it has been looked at and that all the information needed for them to understand what is going on is there.
Best,
S.
Hello: [quote=&quot;pid:59362, uid:36421&quot;] Translation: &quot;We&#039;ll look into that, eventually...&quot; :-( [/quote] Not necessarily so. I think ... Looking at the bug severity [field](https://bugs.winehq.org/page.cgi?id=fields.html#severity) list [WineHQ Bugzilla] has, I find these relevant definitions: ```` blocker [Blocks development] and/or testing work critical Critical problem that [prevents all applications] from working major Major loss of functionality for a [wide range of applications] normal For an [application] crash or [loss of functionality] ### &lt;- this ```` I would think that our problem fits the WineHQ&#039;s &#039;normal&#039; definition. ie: does not affect any application (that we know of) other than Pegasus Mail from v4.80 onwards. The good news is that it has been looked at and that all the information needed for them to understand what is going on is there. Best, S.
edited Nov 15 at 2:52 pm
Indeed. Well, that's good(-ish) news. All we can do is to wait anyway, and hope WineHQ will be able to allocate the resources to fix this before 4.73 becomes too outdated.
[quote=&quot;pid:59364, uid:28059&quot;]I would think that our problem fits the WineHQ&#039;s &#039;normal&#039; definition.[/quote] Indeed. Well, that&#039;s good(-ish) news. All we can do is to wait anyway, and hope WineHQ will be able to allocate the resources to fix this before 4.73 becomes too outdated.
Hello:
... good(-ish) news.
Quite so.
... and hope WineHQ will be able to allocate the resources ...
Well, I have been on v4.73 ever since it was released in June 2018.
As of today, over eight years ago and still doing fine.
That is, once you figured out the SSL thing affecting [GMX.de] email. 8^°
Not a bad run, by any standard and would not mind staying there as I am not sure that newer versions bring anything to the table, at least for me
The problem will be the occurrence of more disrupting horseshit.
Eventually a barebones [64bit XPSP3] on a VM could see us through, but it is not a given.
It will not be easy, maybe impossible, to find a suitable non-HTML stand alone email client to replace [PMail]. For one, I know of none with [Selective mail download], something I consider essential.
Best,
S.
Hello: [quote=&quot;pid:59365, uid:36421&quot;] ... good(-ish) news. [/quote] Quite so. [quote=&quot;pid:59365, uid:36421&quot;] ... and hope WineHQ will be able to allocate the resources ... [/quote] Well, I have been on v4.73 ever since it was released in June 2018. As of today, over eight years ago and still doing fine. That is, once _you_ figured out the SSL thing affecting [GMX.de] email. 8^&deg; Not a bad run, by any standard and would not mind staying there as I am not sure that newer versions bring anything to the table, at least *for me* The problem will be the occurrence of more disrupting horseshit. Eventually a barebones [64bit XPSP3] on a VM could see us through, but it is not a given. It will not be easy, maybe impossible, to find a suitable non-HTML stand alone email client to replace [PMail]. For one, I know of *none* with [Selective mail download], something I consider essential. Best, S.
Took me a while, since all the instructions you can find on the Internet (english, german, whatever) are wrong (outdated). I eventually stumbled upon a totally unrelated help page and since I already had a similar problem with GMail, I had the lightbulb moment. :-D
Unfortunately that would be too complicated for me, since I'm receiving work email at any time, and Pegasus has to work simultaneously on two computers thanks to a shared /MAIL (kind of local IMAP...).
But you're right, Pegasus Mail is one of a kind, totally outside the 2026 Zeitgeist where everything is dumbed down and everything is a "social media". It's a tool from a bygone era where people (mostly) knew what they were doing.
[quote=&quot;pid:59367, uid:28059&quot;]once you figured out the SSL thing affecting [GMX.de] email. 8^&deg;[/quote] Took me a while, since all the instructions you can find on the Internet (english, german, whatever) are wrong (outdated). I eventually stumbled upon a totally unrelated help page and since I already had a similar problem with GMail, I had the lightbulb moment. :-D [quote=&quot;pid:59367, uid:28059&quot;]Eventually a barebones [64bit XPSP3] on a VM could see us through, but it is not a given.[/quote] Unfortunately that would be too complicated for me, since I&#039;m receiving work email at any time, and Pegasus has to work simultaneously on two computers thanks to a shared /MAIL (kind of local IMAP...). But you&#039;re right, Pegasus Mail is one of a kind, totally outside the 2026 _Zeitgeist_ where everything is dumbed down and everything is a &quot;social media&quot;. It&#039;s a tool from a bygone era where people (mostly) knew what they were doing.
Hello:
since all the instructions you can find on the Internet (english, german, whatever) ...
Yes, the [GMX.de] are obviously all in German and translating the instructions is cumbersome and tiring. Fortunately you found the right page.
too complicated for me, since I'm receiving work email at any time ...
Fortunately, not my case. But it would still be complicated for me.
Pegasus Mail is one of a kind, totally outside the 2026 Zeitgeist ...
Indeed it is.
Another thing: I was wondering if it would be of use to upload the screen captures uploaded in one of my posts so that whoever eventually takes care of the problem has them at hand and not in a thread here.
It is your bug report, let me know if you consider it may help.
Best,
S.
Hello: [quote=&quot;pid:59369, uid:36421&quot;]since all the instructions you can find on the Internet (english, german, whatever) ...[/quote] Yes, the [GMX.de] are obviously all in German and translating the instructions is cumbersome and tiring. Fortunately you found the right page. [quote=&quot;pid:59369, uid:36421&quot;]too complicated for me, since I&#039;m receiving work email at any time ...[/quote] Fortunately, not my case. But it would still be complicated for me. [quote=&quot;pid:59369, uid:36421&quot;] Pegasus Mail is one of a kind, totally outside the 2026 Zeitgeist ...[/quote] Indeed it is. Another thing: I was wondering if it would be of use to upload the screen captures uploaded in one of my posts so that whoever eventually takes care of the problem has them at hand and not in a thread here. It is your bug report, let me know if you consider it may help. Best, S.
I'm quite sure I also found some in English, although I don't remember exactly. I'm fluent in German so I didn't really register the language...
Yes, I think that would help a lot, it kind of explains the problem at a single glance.
Right now the only screenshot they've got is that of a perfectly working Pegasus (now that sure is helpful!)...
So yes, please add a couple of your screen captures to the bug report.
[quote=&quot;pid:59370, uid:28059&quot;]Yes, the [GMX.de] are obviously all in German[/quote] I&#039;m quite sure I also found some in English, although I don&#039;t remember exactly. I&#039;m fluent in German so I didn&#039;t really register the language... [quote=&quot;pid:59370, uid:28059&quot;]I was wondering if it would be of use to upload the screen captures uploaded in one of my posts so that whoever eventually takes care of the problem has them at hand and not in a thread here.[/quote] Yes, I think that would help a lot, it kind of explains the problem at a single glance. Right now the only screenshot they&#039;ve got is that of a perfectly working Pegasus (now that sure is helpful!)... So yes, please add a couple of your screen captures to the bug report.
Hello:
... sure I also found some in English ...
I'm fluent in German ...
Well, that's what enabled me to continue using my PMail v4.73. 8^D
So, thanks again.
... think that would help ...
... explains the problem at a single glance.
My point exactly.
... please add a couple of your screen captures ...
Done.
Best,
S.
Hello: [quote=&quot;pid:59371, uid:36421&quot;] ... sure I also found some in English ... I&#039;m fluent in German ... [/quote] Well, _that&#039;s_ what enabled me to continue using my PMail v4.73. 8^D So, thanks again. [quote=&quot;pid:59371, uid:36421&quot;] ... think that would help ... ... explains the problem at a single glance. [/quote] My point exactly. [quote=&quot;pid:59371, uid:36421&quot;] ... please add a couple of your screen captures ... [/quote] Done. Best, S.
