Hello:
Edit:
It seems that I have the same issue as Al345.
I had made sure that the upgrade worked with the new SSL version requirements but had not sent any emails since the upgrade last night.
I will give it a thorough read and see what I can do.
In the meantime, please consider moving this post to that specific thread as it has the same issue.
https://community.pmail.com/index.php?u=/topic/12491/help-pegasus-on-linux-letter-salad-on-v4-80-and-later
ie: when typing an email all I get is garbage on the screen, even if I copy/cut paste from a *.txt file.
Long time PMail user, first time being on W3.11 after ditching the other option/s available, if my memory serves me right, Eudora Mail?.
Firm believer in the "if it works don't fix it" principle, up until yesterday I was running on v.4.73 but as one of my email providers ungraded the SSL version requirements (gmx.net) I finally decided to upgrade to the latest available version:
v4.91.1746, 11 Aug 2025 18:19:07, build ID 1746.
All this in my [Linux Devuan] box under [Wine 8.0], the latest available in the Debian/Devuan repositories.
In exemplary form, w32-491.exe upgraded without a hitch and I was up and running again in less than 5'.
Can't beat that ...
That said, while I am still having the issue of the very small and slightly readable legends/titles above the folder icons (ie: open, reply, forward, etc.) something else has come up.
This installation was upgraded (late) to v4.73 years ago and been transplanted to whatever Wine was running in the respective distribution installed in my box at the time for a number of years without issues and whatever I did with the IERenderer thing survived.
But it seems to have failed this time.
A number of emails that I could open and switch between views by hitting the View button if I needed now show jumbled trash in both options.
I have had a look at the files and it seems that (as instructed at the time) I renamed `IERenderer.fff¨.
Not wanting to screw up my installation, I'd appreciate instructions on how to deal with this as (as I mentioned) Pmail has always worked and I have had very little to do to keep it running.
Best,
S.
Hello:
**Edit:**
In exemplary form, `w32-491.exe` upgraded without a hitch and I was up and running again in less than 5'.
Can't beat that ...
This installation was upgraded (late) to v4.73 years ago and been _transplanted_ to whatever Wine was running in the respective distribution installed in my box at the time for a number of years without issues and whatever I did with the IERenderer thing survived.
A number of emails that I could open and switch between views by hitting the `View` button if I needed now show jumbled trash in both options.
Best,
S.
