Well, that's part of the weirdness - Sometimes it happens, sometimes it doesn't. The only time I manually change the sort order is when it gets set other than reverse by date. I looked and "Remember and apply each folder's sorting mode separately" was unchecked, so I enabled it. I always exit properly, etc., so I'll see what different that changes makes.
Thanks.
<p>Well, that's part of the weirdness - Sometimes it happens, sometimes it doesn't. The only time I manually change the sort order is when it gets set other than reverse by date. I looked and "Remember and apply each folder's sorting mode separately" was unchecked, so I enabled it. I always exit properly, etc., so I'll see what different that changes makes.</p><p>Thanks.
&nbsp;</p>
