There's no immediate solution to this problem, sorry (other than using ASCII reductions like "ue" for "ü", which isn't really a solution at all). It should be straightforward to fix, though, and I'll try to get that done in the current beta testing cycle. Just so you know, when the correction is done, the proper format will be to use the basic Windows characters, not to attempt to UTF-8-encode the data. WinPMail will do the translation automatically as required (as it should).
-- David --
-- David --
