Authentication problem
Thomas,
Thanks, I have chosen the first option under authentication. Options 2 & 3 did not help, so I'll see how #1 functions. I have also enabled session logging and will post it when I encounter any more problems.
Sincerely,
Bob Mulder
<P>Thomas,</P> <P mce_keep="true"> </P> <P>Thanks, I have chosen the first option under authentication. Options 2 & 3 did not help, so I'll see how #1 functions. I have also enabled session logging and will post it when I encounter any more problems.</P> <P mce_keep="true"> </P> <P>Sincerely,</P> <P mce_keep="true"> </P> <P>Bob Mulder</P>
Here is another error message I get back after sending an e-mail:
550 Please configure your mail client to use authentication.
How does one configure authentication?
Bob Mulder
<P>Here is another error message I get back after sending an e-mail:</P> <P mce_keep="true"> </P><FONT size=2> <P align=left>550 Please configure your mail client to use authentication.</P> <P align=left mce_keep="true"> </P> <P align=left>How does one configure authentication?</P> <P align=left mce_keep="true"> </P> <P align=left>Bob Mulder</P></FONT>
David Harris has implemented ESMTP AUTH CRAM-MD5 for WinPMail, Mercury and Mercury/32.  They do a SMTP authentication in accordance with RFCs 2554 and 2195.  Mercury and Mercury/32 also do the LOGIN and the strange MS AUTH=LOGIN.
Go to File | Network configuration | (Sending) SMTP, edit the SMTP setup, select the "Security" tab and select one of the 3 options for doing SMTP Authorization.
> Bob Mulder
> Here is another error message I get back after sending an e-mail: > > 550 Please configure your mail client to use authentication. > > How does one configure authentication? David Harris has implemented ESMTP AUTH CRAM-MD5 for WinPMail, Mercury and Mercury/32.  They do a SMTP authentication in accordance with RFCs 2554 and 2195.  Mercury and Mercury/32 also do the LOGIN and the strange MS AUTH=LOGIN. Go to File | Network configuration | (Sending) SMTP, edit the SMTP setup, select the "Security" tab and select one of the 3 options for doing SMTP Authorization. > >   > > Bob Mulder >
