[quote user="ivorygate"]
I hope there is something I am obviously doing wrong, but it appears that Pegasus Mail (v4.41) is not able to properly index a mbox (.MBX) folder? It seems that the index routine that scans through a mbox file counts any line that begins with "from " (of any case combination of those characters, from what I have been able to replicate in testing) as the start of a new message, not just lines that start with "From ???@???". Because of that, I have .mbx folders that are "hiding" messages that should show up in the folder and I also have some messages that do show up but without header information (the raw message view starts with say a line that says "from everything I've heard" or such).
I also found that in some instances, the end of previous message did
not get a CRLF, so that the "From ???@???" part wasn't at the beginning
of a new line and that then jumbles together two messages into one,
when viewed in Pegasus.
I understand this format was intended for conversion processes, but it is still useful to store messages for long term storage in a format that other utilities could easily import and I didn't realized there was a flaw that made it very unwise to use it for anything other than a step in a conversion process to a new e-mail application ???
And you have found the major problem with the MBOX format. Pegasus Mail does not munge the "From" in the first position of any line in the body of the message. If you want to use this as a storage format you will have to do that yourself while then are in the CNM form before moving them to the MBX type folders.
However a better method than using MBX to provide interoperability between Pegasus Mail and other mail applications is to setup Mercury/32 with Pegasus Mail. You can then use IMAP4 to allow the Pegasus Mail folders to be accessed from any IMAP4 application. Works quite well for me with Netscape, T-bird, Outlook, OE, Eudora, etc when testing mail clients.
[quote user="ivorygate"]<p>I hope there is something I am obviously doing wrong, but it appears that Pegasus Mail (v4.41) is not able to properly index a mbox (.MBX) folder?&nbsp; It seems that the index routine that scans through a mbox file counts any line that begins with "from " (of any case combination of those characters, from what I have been able to replicate in testing) as the start of a new message, <u><b>not</b></u> just lines that start with "From ???@???".&nbsp; Because of that, I have .mbx folders that are "hiding" messages that should show up in the folder and I also have some messages that do show up but without header information (the raw message view starts with say a line that says "from everything I've heard" or such).&nbsp; </p><p>I also found that in some instances, the end of previous message did
when viewed in Pegasus.</p><p>I understand this format was intended for conversion processes, but it is still useful to store messages for long term storage in a format that other utilities could easily import and I didn't realized there was a flaw that made it very unwise to use it for anything other than a step in a conversion process to a new e-mail application ???
</p><p>[/quote]</p><p>&nbsp;</p><p>And you have found the major problem with the&nbsp; MBOX format.&nbsp; Pegasus Mail does not munge the "From" in the first position of any line in the body of the message.&nbsp; If you want to use this as a storage format you will have to do that yourself while then are in the CNM form before moving them to the MBX type folders.
&nbsp;</p><p>However a better method than using MBX to&nbsp; provide interoperability between Pegasus Mail and other mail applications is to setup Mercury/32 with Pegasus Mail.&nbsp; You can then use IMAP4 to allow the Pegasus Mail folders to be accessed from any IMAP4 application.&nbsp; Works quite well for me with Netscape, T-bird, Outlook, OE, Eudora, etc when testing mail clients.
