how to start up Mercury in SBS2003?
You need to use a service wrapper to run Mercury/32 as a service.  I use NT Wrapper to do this since it allows me to run the service as a specific user and still interact with the desktop. The NT Wrapper allows standard Win32 applications or scripts to be run as a Windows NT/2000/XP/2003 Service.
Features:
    ·    Easy configuration thru a GUI and simple INI files.
    ·    Prioritization of sub-processes.
    ·    Custom environments.
    ·    CPU binding
    ·    Redirecting of Stdout/Stderr to file
    ·    Logging to the event log and to disk.
    ·    The capability to run multiple applications in a
         single NT Wrapper service instance.
    ·    Monitoring of a service in the sys-tray.
http://www.duodata.de/ntwrapper/
<p>You need to use a service wrapper to run Mercury/32 as a service.  I use NT Wrapper to do this since it allows me to run the service as a specific user and still interact with the desktop. The NT Wrapper allows standard Win32 applications or scripts to be run as a Windows NT/2000/XP/2003 Service.  Features:     ·    Easy configuration thru a GUI and simple INI files.      ·    Prioritization of sub-processes.      ·    Custom environments.      ·    CPU binding      ·    Redirecting of Stdout/Stderr to file      ·    Logging to the event log and to disk.      ·    The capability to run multiple applications in a           single NT Wrapper service instance.      ·    Monitoring of a service in the sys-tray.  http://www.duodata.de/ntwrapper/ </p><p> </p><p> </p>
If the server SBS2003 startsup Mercury does not start up. Only when a user logs in, on the server itself.
Does anyone know -and wants to tell or write me- what I need to do
that Mercury (or any other program that I want) starts up, when the server starts up?
I will be very happy with answer, and will shout it froms the roofs........
pls let me know!!!
and I will grow!!
Wishing You a good day.
BART.
<P>If the server SBS2003 startsup Mercury does not start up. Only when a user logs in, on the server itself.</P> <P>Does anyone know -and wants to tell or write me- what I need to do</P> <P>that Mercury (or any other program that I want) starts up, when the server starts up?</P> <P mce_keep="true"> </P> <P>I will be very happy with answer, and will shout it froms the roofs........</P> <P>pls let me know!!!</P> <P mce_keep="true"> </P> <P>and I will grow!!</P> <P>Wishing You a good day.</P> <P mce_keep="true"> </P> <P>BART.</P>
You need to be running as a service using one of the service wrappers.  I prefer NT Wrapper since it allows me to run with the GUI interface as a specific user.
Features:
    ·    CPU binding
> If the server SBS2003 startsup Mercury does not start up. Only when a user logs in, on the server itself. > > Does anyone know -and wants to tell or write me- what I need to do > > that Mercury (or any other program that I want) starts up, when the server starts up? > > I will be very happy with answer, and will shout it froms the roofs........ You need to be running as a service using one of the service wrappers.  I prefer NT Wrapper since it allows me to run with the GUI interface as a specific user. The NT Wrapper allows standard Win32 applications or scripts to be run as a Windows NT/2000/XP/2003 Service.   Features:     ·    Easy configuration thru a GUI and simple INI files.       ·    Prioritization of sub-processes.       ·    Custom environments.       ·    CPU binding       ·    Redirecting of Stdout/Stderr to file       ·    Logging to the event log and to disk.       ·    The capability to run multiple applications in a                      single NT Wrapper service instance.       ·    Monitoring of a service in the sys-tray.   http://www.duodata.de/ntwrapper/
