can I use Mercury to fix an MS Exchange problem?
You can't change the subject line, this filter only adds a header, it cannot replace a header.  With what you said you should have a new header in your message showing test: hallo.
You also cannot at this time move messages via filtering to a specific folder.  What you can do is add a specific header to the message like "SPAM: True" and then have Outlook filters looking for this specific header in the headers to move it to a folder.  This type of filtering is available in Outlook 2002 I assume this is available in your version of Outlook.
<p>You can't change the subject line, this filter only adds a header, it cannot replace a header.  With what you said you should have a new header in your message showing test: hallo.</p><p>You also cannot at this time move messages via filtering to a specific folder.  What you can do is add a specific header to the message like "SPAM: True" and then have Outlook filters looking for this specific header in the headers to move it to a folder.  This type of filtering is available in Outlook 2002 I assume this is available in your version of Outlook.</p><p> </p>
Hello all,
My company, heavily MS oriented, is running on MS exchange and MS outlook.
I would like to use a lot of filters to manage my incoming email better but unfortunately there is not enough space per user (apparently a system default) to use the amount of filters I require. Beside of that it's hard to create the right filters in outlook/exchange.
My idea is as follows:
Use an applicatin like Mercury/32 on my local cpmputer and gather all emails (and calendar) items to Mercury/32, process filters and rules and than pass the information to my local outlook2003 client. Vice versa email could be passed via Mercury/32 are directly passed into exchange.
As you might understand I have no support form the central IT department so it's a fully 'local sollution'
Would this work? If not do you have other ideas
Thanks Jan-Willem
<p>Hello all,</p><p> </p><p>My company, heavily MS oriented, is running on MS exchange and MS outlook. </p><p>I would like to use a lot of filters to manage my incoming email better but unfortunately there is not enough space per user (apparently a system default) to use the amount of filters I require. Beside of that it's hard to create the right filters in outlook/exchange.</p><p>My idea is as follows:</p><p>Use an applicatin like Mercury/32 on my local cpmputer and gather all emails (and calendar) items to Mercury/32, process filters and rules and than pass the information to my local outlook2003 client. Vice versa email could be passed via Mercury/32 are directly passed into exchange.</p><p> </p><p>As you might understand I have no support form the central IT department so it's a fully 'local sollution'  </p><p>Would this work? If not do you have other ideas  </p><p> </p><p>Thanks Jan-Willem </p>
Yes, should not be all that much of a problem.  You would download via POP3 from the Exchange host using MercuryD to a local Mercury/32 account and then connect to the account via Outlook using IMAP4.  You would be still connecting directly to your calendar as normal.  Mercury/32 would do the anti-spam via Spamhalter and Content Control.  You could send this off to another local account that you could also access via IMAP4.
<p>Yes, should not be all that much of a problem.  You would download via POP3 from the Exchange host using MercuryD to a local Mercury/32 account and then connect to the account via Outlook using IMAP4.  You would be still connecting directly to your calendar as normal.  Mercury/32 would do the anti-spam via Spamhalter and Content Control.  You could send this off to another local account that you could also access via IMAP4.</p><p> </p><p> </p><p> </p>
Hi Thomas,
That basicaly works: Thanks
I see the POP3 client poll my pop server and than than outlook conects to Mercury using IMAP.
Now something else (And I feel stupid to ask [:$])
I created a rule (Configuration>filtering rules>edit global rules>headers) and ticket "Subject" so it should just look in the subject. At [Contains this text] I entered "test".
The action I selected is: [Add a header to the message] and att [Parameter]  I set "test:hallo" (Also tried other combinations like ""test:hallo"" "test: this is a test")
When I send an email to myself I would expect that Mercury is replacing/adding "hallo" in the subject.[:(]  wrong... It doesn't
I know it's possible but appearntly I'm not clever enough to find out how [:S]. Can you help me on this?
Another issue I now stumble into is that when I reply to incoming mesages outlook tries to reply via my local running Mercury system and that was not expected.[:'(]
And one other questioin already further down the process: would it be able to place incoming messages based on subject and/or body to subfolders of the IMAP directly?
Keep in mind that the reason of trying this all is that I can not make the aquired number of rules in outlook itself.
Thanks Jan-Willem
<p>Hi Thomas,</p><p> </p><p>That basicaly works: Thanks</p><p>I see the POP3 client poll my pop server and than than outlook conects to Mercury using IMAP. </p><p> </p><p>Now something else (And I feel stupid to ask [:$])</p><p>I created a rule (Configuration>filtering rules>edit global rules>headers) and ticket "Subject" so it should just look in the subject. At [Contains this text] I entered "test".</p><p>The action I selected is: [Add a header to the message] and att [Parameter]  I set "test:hallo" (Also tried other combinations like ""test:hallo"" "test: this is a test") </p><p>  When I send an email to myself I would expect that Mercury is replacing/adding "hallo" in the subject.[:(]  wrong... It doesn't</p><p>I know it's possible but appearntly I'm not clever enough to find out how [:S]. Can you help me on this?</p><p> </p><p>Another issue I now stumble into is that when I reply to incoming mesages outlook tries to reply via my local running Mercury system and that was not expected.[:'(] </p><p> </p><p> </p><p>And one other questioin already further down the process: would it be able to place incoming messages based on subject and/or body to subfolders of the IMAP directly?</p><p>Keep in mind that the reason of trying this all is that I can not make the aquired number of rules in outlook itself.</p><p> </p><p>Thanks Jan-Willem  </p>
