I have Mercury 4.5 installed on my computer and I have protocols S, P and E active. My host name is Tyan. I have a local domain called Tyan.me and a user mark. I am able to send myself an email successfully with username mark, password xyz, Incoming mail server 192.168.1.16 and outgoing server 192.168.1.16. I am also able to receive this mail. So, Mercury appears to be installed and configured properly – at least for this simple task. The Mercury log file shows the following for the SMTP transaction:<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Connection from 192.168.1.16, Thu Mar 20 11:08:02 2008
EHLO TYAN
MAIL FROM: <mark@Tyan.me>
RCPT TO: <mark@Tyan.me>
DATA - 79 lines, 1941 bytes.
QUIT
2 sec. elapsed, connection closed Thu Mar 20 11:08:04 2008
I have an application installed on this box which emails a message to a specified address when a remote device senses motion. I know this application is setup and working because when configured to mail to my regular internet email address using my ISP’s incoming and outgoing, it works. But the process is too slow for my needs so I configured it to use the exact settings that worked for my email test above. (I have no access to view or modify the application’s source code.)
When I run the application it clearly is sending to my Mercury SMTP server but there is an error. The Mercury log shows this:
Connection from 192.168.1.16, Thu Mar 20 12:05:01 2008
EHLO localhost
auth login
QUIT
1 sec. elapsed, connection closed Mar 20 12:05:02 2008
The error in the session log is
501 Authentication failed - bad user or password.
I don’t know what this “localhost’ is about or where it’s coming from because my application is clearly set to the exact user, password, servers, etc. that my successful email test used.
How can I configure my Mercury server to accept mail from this application?
Anyone who can help me would surely be considered a scholar and a friend.
<P class=MsoNormal style="MARGIN: 0in 0in 0pt"><SPAN style="FONT-FAMILY: Arial"><FONT size=3>I have Mercury 4.5 installed on my computer and I have protocols <I style="mso-bidi-font-style: normal">S</I>, <I style="mso-bidi-font-style: normal">P</I> and <I style="mso-bidi-font-style: normal">E</I> active. My host name is <I style="mso-bidi-font-style: normal">Tyan</I>. I have a local domain called <I style="mso-bidi-font-style: normal">Tyan.me</I> and a user <I style="mso-bidi-font-style: normal">mark</I>. I am able to send myself an email successfully with username <I style="mso-bidi-font-style: normal">mark,</I> password <I style="mso-bidi-font-style: normal">xyz,</I> Incoming mail server 192.168.1.16 and outgoing server 192.168.1.16. I am also able to receive this mail. So, Mercury appears to be installed and configured properly – at least for this simple task. The Mercury log file shows the following for the SMTP transaction:<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0in 0in 0pt"><SPAN style="FONT-FAMILY: Arial"><o:p><FONT size=3>&nbsp;</FONT></o:p></SPAN></P>
<P class=MsoNormal style="MARGIN: 0in 0in 0pt 9pt; mso-layout-grid-align: none"><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">Connection from 192.168.1.16, Thu Mar 20 11:08:02 2008<o:p></o:p></SPAN></P>
<P class=MsoNormal style="MARGIN: 0in 0in 0pt 9pt; mso-layout-grid-align: none"><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">EHLO TYAN<o:p></o:p></SPAN></P>
<P class=MsoNormal style="MARGIN: 0in 0in 0pt 9pt; mso-layout-grid-align: none"><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">MAIL FROM: &lt;mark@Tyan.me&gt;<o:p></o:p></SPAN></P>
<P class=MsoNormal style="MARGIN: 0in 0in 0pt 9pt; mso-layout-grid-align: none"><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">RCPT TO: &lt;mark@Tyan.me&gt;<o:p></o:p></SPAN></P>
<P class=MsoNormal style="MARGIN: 0in 0in 0pt 9pt; mso-layout-grid-align: none"><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">DATA - 79 lines, 1941 bytes.<o:p></o:p></SPAN></P>
<P class=MsoNormal style="MARGIN: 0in 0in 0pt 9pt; mso-layout-grid-align: none"><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">QUIT<o:p></o:p></SPAN></P>
<P class=MsoNormal style="MARGIN: 0in 0in 0pt 9pt"><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">2 sec. elapsed, connection closed Thu Mar 20 11:08:04 2008<o:p></o:p></SPAN></P>
<P class=MsoNormal style="MARGIN: 0in 0in 0pt 9pt"><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><o:p>&nbsp;</o:p></SPAN></P>
<P class=MsoNormal style="MARGIN: 0in 0in 0pt"><SPAN style="FONT-FAMILY: Arial"><FONT size=3>I have an application installed on this box which emails a message to a specified address when a remote device senses motion. I know this application is setup and working because when configured to mail to my regular internet email address using my ISP’s incoming and outgoing, it works. But the process is too slow for my needs so I configured it to use the exact settings that worked for my email test above. (I have no access to view or modify the application’s source code.)<o:p></o:p></FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0in 0in 0pt"><SPAN style="FONT-FAMILY: Arial"><FONT size=3>When I run the application it clearly is sending to my Mercury SMTP server but there is an error. The Mercury log shows this:<o:p></o:p></FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0in 0in 0pt 9pt; mso-layout-grid-align: none"><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">Connection from 192.168.1.16, Thu Mar 20 12:05:01 2008<o:p></o:p></SPAN></P>
<P class=MsoNormal style="MARGIN: 0in 0in 0pt 9pt; mso-layout-grid-align: none"><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">EHLO <B style="mso-bidi-font-weight: normal">localhost</B><o:p></o:p></SPAN></P>
<P class=MsoNormal style="MARGIN: 0in 0in 0pt 9pt; mso-layout-grid-align: none"><B style="mso-bidi-font-weight: normal"><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">auth login<o:p></o:p></SPAN></B></P>
<P class=MsoNormal style="MARGIN: 0in 0in 0pt 9pt"><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">1 sec. elapsed, connection closed Mar 20 12:05:02 2008<o:p></o:p></SPAN></P>
<P class=MsoNormal style="MARGIN: 0in 0in 0pt"><SPAN style="FONT-FAMILY: Arial"><FONT size=3>The error in the session log is<o:p></o:p></FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0in 0in 0pt 9pt; mso-layout-grid-align: none"><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">501 Authentication failed - bad user or password.<o:p></o:p></SPAN></P>
<P class=MsoNormal style="MARGIN: 0in 0in 0pt"><SPAN style="FONT-FAMILY: Arial"><FONT size=3>I don’t know what this “localhost’ is about or where it’s coming from because my application is clearly set to the exact user, password, servers, etc. that my successful email test used.<o:p></o:p></FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0in 0in 0pt"><SPAN style="FONT-FAMILY: Arial"><FONT size=3>How can I configure my Mercury server to accept mail from this application?</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0in 0in 0pt"><SPAN style="FONT-FAMILY: Arial"><FONT size=3></FONT></SPAN>&nbsp;</P>
<P class=MsoNormal style="MARGIN: 0in 0in 0pt"><SPAN style="FONT-FAMILY: Arial"><FONT size=3>Anyone who can help me would surely be considered a scholar and a friend. </FONT></SPAN></P>
