If MercuryE is working, I suspect the ASSP logs will show the outgoing mail is bypassing ASSP. That's not necessarily a big problem.
Your logs showed ASSP was on the same machine as Mercury - that's a setup I'm familiar with, and MercuryE will only forward through ASSP is you force all mta DNS queries to localhost and use another relay beyond ASSP.
The best place to understand more about ASSP is on its mailing list or via the wiki/forum at www.asspsmtp.org . There is a diagram if you follow the link to 'configuration'.
<P>If MercuryE is working, I suspect the ASSP logs will show the outgoing mail is bypassing ASSP.&nbsp; That's not necessarily a big problem.</P>
<P>Your logs showed ASSP was on the same machine as Mercury - that's a setup I'm familiar with, and MercuryE will only forward through ASSP is you force all mta DNS queries to localhost and use another relay beyond ASSP.</P>
<P>The best place to understand more about ASSP is on its mailing list or via the wiki/forum at <A href="http://www.asspsmtp.org/">www.asspsmtp.org</A>&nbsp;.&nbsp; There is a diagram if you follow the link to 'configuration'.</P>
<P mce_keep="true">&nbsp;</P>
