problem with pop
thanx alot ................ using username instead of username@localhost works ...
i was stuck with this prob a while ...
thanx alot
<p>thanx alot ................ using username instead of username@localhost works ...</p><p>i was stuck with this prob a while ...</p><p>thanx alot </p>
hi guys i'v recently installed Mercury...
i’v wriitin a code in c# for sending/retrieving mails to/from mercury mail server.The sending(smtp) part works perfectly fine but have a prob with retrieving(pop).
Connection wit the server is established , the username (honey@localhost) also matches but there is problem with the password, get an error that password is incorrect/invalid … any idea y is this happenein ????
its urgent plz help me
<p>hi guys i'v recently installed Mercury... </p><p> i’v wriitin a code in c# for sending/retrieving mails to/from mercury mail server.The sending(smtp) part works perfectly fine but have a prob with retrieving(pop). Connection wit the server is established , the username (honey@localhost) also matches but there is problem with the password, get an error that password is incorrect/invalid … any idea y is this happenein ???? its urgent plz help me</p>
