Firstly - when you wrote your instructions for SMTP, you gave (b)
for STARTTLS, and (c) SMTP via TLS. I assumed that I would do either
one or the other, and chose to do (b) STARTTLS. Am I OK there?
Correct.
Next - your answer about turning on ESTMP authorization in the
security tab of my SMTP setup -- I cannot find anything about ESMTP in
Pegasus' security tab on the SMTP setup. Where would I get to this?
Use Tools | Internet Options | Sending (SMTP) and edit the POP3 definition. Select the "Security" tab and select one of the options for authorization and enter tyhe username and password or rthe POp3 definition.
<blockquote><p>Firstly - when you wrote your instructions for SMTP, you gave (b)
for STARTTLS, and (c) SMTP via TLS.&nbsp; I assumed that I would do either
one or the other, and chose to do (b) STARTTLS.&nbsp; Am I OK there?
</p></blockquote><p>Correct.</p><p>&nbsp;</p><blockquote><p>Next - your answer about turning on ESTMP authorization in the
Pegasus' security tab on the SMTP setup.&nbsp; Where would I get to this?</p></blockquote><p>Use Tools | Internet Options | Sending (SMTP) and edit the POP3 definition.&nbsp; Select the "Security" tab and select one of the options&nbsp; for authorization and enter tyhe username and password or rthe POp3 definition.
</p><blockquote><p>&nbsp;</p></blockquote><blockquote><p>&nbsp;</p></blockquote>
