Configuring Pegasus for use with WildBlue - now a problem with sending
Firstly - when you wrote your instructions for SMTP, you gave (b)
for STARTTLS, and (c) SMTP via TLS.  I assumed that I would do either
one or the other, and chose to do (b) STARTTLS.  Am I OK there?
Correct.
Next - your answer about turning on ESTMP authorization in the
security tab of my SMTP setup -- I cannot find anything about ESMTP in
Pegasus' security tab on the SMTP setup.  Where would I get to this?
Use Tools | Internet Options | Sending (SMTP) and edit the POP3 definition.  Select the "Security" tab and select one of the options  for authorization and enter tyhe username and password or rthe POp3 definition.
<blockquote><p>Firstly - when you wrote your instructions for SMTP, you gave (b) for STARTTLS, and (c) SMTP via TLS.  I assumed that I would do either one or the other, and chose to do (b) STARTTLS.  Am I OK there? </p></blockquote><p>Correct.</p><p> </p><blockquote><p>Next - your answer about turning on ESTMP authorization in the security tab of my SMTP setup -- I cannot find anything about ESMTP in Pegasus' security tab on the SMTP setup.  Where would I get to this?</p></blockquote><p>Use Tools | Internet Options | Sending (SMTP) and edit the POP3 definition.  Select the "Security" tab and select one of the options  for authorization and enter tyhe username and password or rthe POp3 definition. </p><blockquote><p> </p></blockquote><blockquote><p> </p></blockquote>
We've been using Pegasus Mail for several years, but we recently had to change internet service providers. Now we have WildBlue internet service, and I've been trying to do network configuration in Pegasus to work with WildBlue's email server. NO SUCCESS YET.
Does anyone have any guidance on how to do this?
I have enabled WildBlue for POP3; then I went into Pegasus, specified the new email address, specified WildBlue's POP3 mail server (pop.gmail.com), specified WildBlue's SMTP mail server (smtp.gmail.com), and specified my username and password. Saved, then told Pegasus to check POP3 host for mail.  The message in lower left said it was connecting to pop.gmail.com, then said Done -- and no mail brought in.
 What am I doing wrong?
Tom G
<P>We've been using Pegasus Mail for several years, but we recently had to change internet service providers. Now we have WildBlue internet service, and I've been trying to do network configuration in Pegasus to work with WildBlue's email server. NO SUCCESS YET.</P> <P>Does anyone have any guidance on how to do this?</P> <P>I have enabled WildBlue for POP3; then I went into Pegasus, specified the new email address, specified WildBlue's POP3 mail server (pop.gmail.com), specified WildBlue's SMTP mail server (smtp.gmail.com), and specified my username and password. Saved, then told Pegasus to check POP3 host for mail.  The message in lower left said it was connecting to pop.gmail.com, then said Done -- and no mail brought in.</P> <P> What am I doing wrong?</P> <P>Tom G</P>
> brought in.
If these server names are correct it looks like they are really GMail servers.
(a) -POP3-
  Server host name: pop.gmail.com
  User name: <your_user_name>@gmail.com
  Password: <your_password>
  Server TCP/IP port: 995
  SSL/TLS: via direct SSL connect
  Enable server certificate fingerprint tracking: checked
(b) -SMTP STARTTLS -
  Server TCP/IP port: 587
  SSL/TLS: via STARTTLS
  SMTP Authentication: Login to the SMTP server using POP3
  username/password (the GMAIL-POP3-definition has been chosen)
(c) - SMTP via SSL -
  Server TCP/IP port: 465
  Enable server certificate fingerprint tracking: unchecked
> Tom G
&amp;gt; We&#039;ve been using Pegasus Mail for several years, but we recently had to &amp;gt; change internet service providers. Now we have WildBlue internet &amp;gt; service, and I&#039;ve been trying to do network configuration in Pegasus to &amp;gt; work with WildBlue&#039;s email server. NO SUCCESS YET. &amp;gt; &amp;gt; Does anyone have any guidance on how to do this? &amp;gt; &amp;gt; I have enabled WildBlue for POP3; then I went into Pegasus, specified &amp;gt; the new email address, specified&amp;nbsp;WildBlue&#039;s POP3 mail server &amp;gt; (pop.gmail.com), specified WildBlue&#039;s SMTP mail server &amp;gt; (smtp.gmail.com), and specified my username and password. Saved, then &amp;gt; told Pegasus to check POP3 host&amp;nbsp;for mail.&amp;nbsp; The message in lower left &amp;gt; said it was connecting to pop.gmail.com, then said Done -- and no mail &amp;gt; brought in. If these server names are correct it looks like they are really GMail servers. (a) -POP3- &amp;nbsp; Server host name: pop.gmail.com &amp;nbsp; User name: &amp;lt;your_user_name&amp;gt;@gmail.com &amp;nbsp; Password: &amp;lt;your_password&amp;gt; &amp;nbsp; Server TCP/IP port: 995 &amp;nbsp; SSL/TLS: via direct SSL connect &amp;nbsp; Enable server certificate fingerprint tracking: checked (b) -SMTP STARTTLS - &amp;nbsp; Server host name: smtp.gmail.com &amp;nbsp; Server TCP/IP port: 587 &amp;nbsp; SSL/TLS: via STARTTLS &amp;nbsp; Enable server certificate fingerprint tracking: checked &amp;nbsp; SMTP Authentication: Login to the SMTP server using POP3 &amp;nbsp; username/password (the GMAIL-POP3-definition has been chosen) (c) - SMTP via SSL - &amp;nbsp; Server host name: smtp.gmail.com &amp;nbsp; Server TCP/IP port: 465 &amp;nbsp; SSL/TLS: via direct ssl connection &amp;nbsp; Enable server certificate fingerprint tracking: unchecked &amp;nbsp; SMTP Authentication: Login to the SMTP server using POP3 &amp;nbsp; username/password (the GMAIL-POP3-definition has been chosen) &amp;gt; &amp;gt; &amp;nbsp;What am I doing wrong? &amp;gt; &amp;gt; Tom G
Thanks, Robert.  Yes, WildBlue mail uses Google's Gmail servers and their user interface on webmail looks just like Gmail's except for the WildBlue customization.
 Anyways, thanks for the config info.  Looks complicated, I'll give it a try.  Is everything you list above editable under the Network Configuration option window?
Thanks,  TomG
&lt;P&gt;Thanks, Robert.&amp;nbsp; Yes, WildBlue mail uses Google&#039;s Gmail servers and their user interface on webmail looks just like Gmail&#039;s except for the WildBlue customization.&lt;/P&gt; &lt;P&gt;&amp;nbsp;Anyways, thanks for the config info.&amp;nbsp; Looks complicated, I&#039;ll give it a try.&amp;nbsp; Is everything you list above editable under the Network Configuration option window?&lt;/P&gt; &lt;P mce_keep=&quot;true&quot;&gt;&amp;nbsp;&lt;/P&gt; &lt;P&gt;Thanks,&amp;nbsp; TomG&lt;/P&gt;
Robert -
 I just tried it, had to fuss with it a bit, and got it to work after a few tries -- THANK YOU!
The only thing I had to do differently was to make my user name girotti@wildblue.net (my regular email address, instead of girotti@gmail.com).
Thanks again!
tg
&lt;P&gt;Robert -&lt;/P&gt; &lt;P&gt;&amp;nbsp;I just tried it, had to fuss with it a bit, and got it to work after a few tries -- THANK YOU!&lt;/P&gt; &lt;P&gt;The only thing I had to do differently was to make my user name &lt;A href=&quot;mailto:girotti@wildblue.net&quot;&gt;girotti@wildblue.net&lt;/A&gt; (my regular email address, instead of &lt;A href=&quot;mailto:girotti@gmail.com&quot;&gt;girotti@gmail.com&lt;/A&gt;).&lt;/P&gt; &lt;P mce_keep=&quot;true&quot;&gt;&amp;nbsp;&lt;/P&gt; &lt;P&gt;Thanks again!&lt;/P&gt; &lt;P&gt;tg&lt;/P&gt;
Robert -
Retrieving mail went fine, but the first time I tried to send, I got a mail delivery failure message, and below is what came up in the window>  Sounds like it wants some kind of authentication?
What now?
 tg
530-5.5.1 Authentication Required. Learn more at
[*] Connection established to 74.125.45.111
>> 0041 220 mx.google.com ESMTP 9sm9522174yxs.5
<< 0022 EHLO [192.168.1.101]
>> 0052 250-mx.google.com at your service, [70.41.127.106]
>> 0019 250-SIZE 28311552
>> 0014 250-8BITMIME
>> 0014 250-STARTTLS
>> 0025 250 ENHANCEDSTATUSCODES
<< 0010 STARTTLS
>> 0030 220 2.0.0 Ready to start TLS
>> 0014 250-8BITMIME
>> 0022 250-AUTH LOGIN PLAIN
<< 0043 MAIL FROM:<girotti@wildblue.net> SIZE=434
>> 0070 530-5.5.1 Authentication Required. Learn more at
>> 0085 530 5.5.1 http://mail.google.com/support/bin/answer.py?answer=14257 9sm9522174yxs.5
&lt;P&gt;Robert -&lt;/P&gt; &lt;P&gt;Retrieving mail went fine, but the first time I tried to send, I got a mail delivery failure message, and below is what came up in the window&amp;gt;&amp;nbsp; Sounds like it wants some kind of authentication?&lt;/P&gt; &lt;P&gt;What now?&lt;/P&gt; &lt;P&gt;&amp;nbsp;tg&amp;nbsp;&lt;/P&gt;&lt;FONT size=2&gt; &lt;P align=left&gt;Delivery has failed on the enclosed message for the following&lt;/P&gt; &lt;P align=left&gt;reasons reported either by the mail delivery system on the mail&lt;/P&gt; &lt;P align=left&gt;relay host or by the local TCP/IP transport module:&lt;/P&gt; &lt;P align=left mce_keep=&quot;true&quot;&gt;&amp;nbsp;&lt;/P&gt; &lt;P align=left&gt;530-5.5.1 Authentication Required. Learn more at &lt;/P&gt;&lt;/FONT&gt; &lt;P&gt;[*] Connection established to 74.125.45.111 &amp;gt;&amp;gt; 0041 220 mx.google.com ESMTP 9sm9522174yxs.5 &amp;lt;&amp;lt; 0022 EHLO [192.168.1.101] &amp;gt;&amp;gt; 0052 250-mx.google.com at your service, [70.41.127.106] &amp;gt;&amp;gt; 0019 250-SIZE 28311552 &amp;gt;&amp;gt; 0014 250-8BITMIME &amp;gt;&amp;gt; 0014 250-STARTTLS &amp;gt;&amp;gt; 0025 250 ENHANCEDSTATUSCODES &amp;lt;&amp;lt; 0010 STARTTLS &amp;gt;&amp;gt; 0030 220 2.0.0 Ready to start TLS &amp;lt;&amp;lt; 0022 EHLO [192.168.1.101] &amp;gt;&amp;gt; 0052 250-mx.google.com at your service, [70.41.127.106] &amp;gt;&amp;gt; 0019 250-SIZE 28311552 &amp;gt;&amp;gt; 0014 250-8BITMIME &amp;gt;&amp;gt; 0022 250-AUTH LOGIN PLAIN &amp;gt;&amp;gt; 0025 250 ENHANCEDSTATUSCODES &amp;lt;&amp;lt; 0043 MAIL FROM:&amp;lt;&lt;A href=&quot;mailto:girotti@wildblue.net&quot;&gt;girotti@wildblue.net&lt;/A&gt;&amp;gt; SIZE=434 &amp;gt;&amp;gt; 0070 530-5.5.1 Authentication Required. Learn more at&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;gt;&amp;gt; 0085 530 5.5.1 &lt;A href=&quot;http://mail.google.com/support/bin/answer.py?answer=14257&quot;&gt;http://mail.google.com/support/bin/answer.py?answer=14257&lt;/A&gt; 9sm9522174yxs.5 &lt;/P&gt;
>> 0085 530 5.5.1 http://mail.google.com/support/bin/answer.py?answer=14257 9sm9522174yxs.5(b)
You need to turn on the ESMTP Authorization in the security tab of yuo SMTP setup.
-SMTP STARTTLS -
&lt;blockquote&gt;&amp;gt;&amp;gt; 0070 530-5.5.1 Authentication Required. Learn more at&amp;nbsp; &amp;gt;&amp;gt; 0085 530 5.5.1 &lt;a href=&quot;http://mail.google.com/support/bin/answer.py?answer=14257&quot;&gt;http://mail.google.com/support/bin/answer.py?answer=14257&lt;/a&gt; 9sm9522174yxs.5(b)&lt;/blockquote&gt;&lt;p&gt;You need to turn on the ESMTP Authorization in the security tab of yuo SMTP setup.&lt;/p&gt;&lt;p&gt; -SMTP STARTTLS - &lt;/p&gt;&lt;p&gt;&amp;nbsp; Server host name: smtp.gmail.com &amp;nbsp; Server TCP/IP port: 587 &amp;nbsp; SSL/TLS: via STARTTLS &amp;nbsp; Enable server certificate fingerprint tracking: checked &amp;nbsp; SMTP Authentication: Login to the SMTP server using POP3 &amp;nbsp; username/password (the GMAIL-POP3-definition has been chosen) (c) - SMTP via SSL - &amp;nbsp; Server host name: smtp.gmail.com &amp;nbsp; Server TCP/IP port: 465 &amp;nbsp; SSL/TLS: via direct ssl connection &amp;nbsp; Enable server certificate fingerprint tracking: unchecked &amp;nbsp; SMTP Authentication: Login to the SMTP server using POP3 &amp;nbsp; username/password (the GMAIL-POP3-definition has been chosen)&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;
Sorry I'm such a dolt on this...
tg
&lt;P&gt;Sorry&amp;nbsp;I&#039;m such a dolt on this...&lt;/P&gt; &lt;P&gt;&amp;nbsp;Firstly - when you wrote your instructions for SMTP, you gave (b) for STARTTLS, and (c) SMTP via TLS.&amp;nbsp; I assumed that I would do either one or the other, and chose to do (b) STARTTLS.&amp;nbsp; Am I OK there?&lt;/P&gt; &lt;P&gt;Next - your answer about turning on ESTMP authorization in the security tab of my SMTP setup -- I cannot find anything about ESMTP in Pegasus&#039; security tab on the SMTP setup.&amp;nbsp; Where would I get to this?&lt;/P&gt; &lt;P&gt;tg&lt;/P&gt;
First Point: STARTTLS is ok.
Second Point: You have to enable SMTP Authentification.
Either with an existing POP3 account or your username and
password.
&lt;P&gt;First Point: STARTTLS is ok.&lt;/P&gt;&lt;P&gt;Second Point: You have to enable SMTP Authentification. &lt;/P&gt;&lt;P&gt;Either with an existing POP3 account or your username and &lt;/P&gt;&lt;P&gt;password.&lt;/P&gt;&lt;P&gt;&nbsp;&lt;/P&gt;
Thanks for responding, tigershark.
When I followed the previous suggestion for setting up SMTP, I had checked the box on the SMTP Security tab for:
However, I had not filled in the box for "From this POP definition:"
After your suggestion about using an existing POP3 account, I filled in the box, tried sending an email, and voila, it worked.
Thanks very much
tg
&lt;P&gt;Thanks for responding, tigershark.&lt;/P&gt; &lt;P&gt;When I followed the previous suggestion for setting up SMTP, I had checked the box on the SMTP Security tab for:&lt;/P&gt; &lt;P&gt;&lt;SPAN style=&quot;FONT-SIZE: 10pt; FONT-FAMILY: &#039;Times New Roman&#039;; mso-fareast-font-family: &#039;Times New Roman&#039;; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA&quot;&gt;SMTP Authentication: Login to the SMTP server using POP3&lt;/SPAN&gt;&lt;/P&gt; &lt;P&gt;&lt;SPAN style=&quot;FONT-SIZE: 10pt; FONT-FAMILY: &#039;Times New Roman&#039;; mso-fareast-font-family: &#039;Times New Roman&#039;; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA&quot;&gt;However, I had not filled in the box for &quot;From this POP definition:&quot;&lt;/SPAN&gt;&lt;/P&gt; &lt;P&gt;&lt;SPAN style=&quot;FONT-SIZE: 10pt; FONT-FAMILY: &#039;Times New Roman&#039;; mso-fareast-font-family: &#039;Times New Roman&#039;; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA&quot;&gt;After your suggestion about using an existing POP3 account, I filled in the box, tried sending an email, and voila, it worked.&lt;/SPAN&gt;&lt;/P&gt; &lt;P&gt;&lt;SPAN style=&quot;FONT-SIZE: 10pt; FONT-FAMILY: &#039;Times New Roman&#039;; mso-fareast-font-family: &#039;Times New Roman&#039;; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA&quot;&gt;Thanks very much&lt;/SPAN&gt;&lt;/P&gt; &lt;P&gt;&lt;SPAN style=&quot;FONT-SIZE: 10pt; FONT-FAMILY: &#039;Times New Roman&#039;; mso-fareast-font-family: &#039;Times New Roman&#039;; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA&quot;&gt;tg&lt;/SPAN&gt;&lt;/P&gt;
