Msgs not sent / reason not shown
All I get is "message not successfully sent."
Is there a way of finding out why? Without this, it becomes rather impossible to debugg & fix.
If you turn on session logging in Configuration | MercuryS then each TCP/IP transaction will be logged in a TCP[4 hex digits].MS  Point the session logging to drive:\mercury\logs\mercuryS and then make sure the directory exists.
Am I supposed to do some set-up work first?
1.    Verify that mercury/32 is properly setup to receive the mail via MercuryS.
2.    Read up a bit on SMTP transfers to ensure you can tell a good TCP/IP session from a bad one.
3.    Read the Mercury manual to figure out how it's supposed to be configured.
<blockquote>All I get is "message not successfully sent." Is there a way of finding out why? Without this, it becomes rather impossible to debugg & fix. </blockquote>If you turn on session logging in Configuration | MercuryS then each TCP/IP transaction will be logged in a TCP[4 hex digits].MS  Point the session logging to drive:\mercury\logs\mercuryS and then make sure the directory exists. <blockquote>Am I supposed to do some set-up work first? </blockquote><p>1.    Verify that mercury/32 is properly setup to receive the mail via MercuryS. </p><p>2.    Read up a bit on SMTP transfers to ensure you can tell a good TCP/IP session from a bad one.  </p><p>3.    Read the Mercury manual to figure out how it's supposed to be configured. </p>
I'm developing a site on my PC using MS-XP & XAMPP.
I'm trying to get my application to send e-mails to my workers but I end up with a message saying "unable to connect to Port 25".
Trying to debug this problem has led me to Mercury Mail.
In XAMPP, using Mercury Mail, I tried to send the test e-mail messages recomended.
To: admin@localhost
Subject: Test
Msg: This is my test msg.
Thank you,
I'm developing a site on my PC using MS-XP & XAMPP. I'm trying to get my application to send e-mails to my workers but I end up with a message saying "unable to connect to Port 25". Trying to debug this problem has led me to Mercury Mail. In XAMPP, using Mercury Mail, I tried to send the test e-mail messages recomended. From: postmaster@localhost To: admin@localhost Subject: Test Msg: This is my test msg. All I get is "message not successfully sent." Is there a way of finding out why? Without this, it becomes rather impossible to debugg & fix. Am I supposed to do some set-up work first? Thank you, Michael
