hi...i'm a final year student in malaysia, trying to configure a connection using pegasus and mercury on my own computer.
i've downloaded both files...and cannot find step by step way to configure both.i've been trying to do this for almost a week, with no success...
i hope anyone can help me....
i've downloaded mercury 4.62 and pegasus 4.41..is there any other software i need..?do i need to run apache server..?
from what i did, i have error sending and recieving emails..with error such "15:peer connect failure....."
what module should i install for mercury..please help me...i'm lost...
thank you very much in advanced...may God bless u...
> connection using pegasus and mercury on my own computer. i've
> i hope anyone can help me.... i've downloaded mercury 4.62 and pegasus
> server..?
FWIW, the ISP may be doing port 25 blocking and as such yuo must use MercuryC for sending the mail using the ISPs SMTP host as a relay host.
1. Install WinPmail in the multiuser mode on the "server". Use c:\pmail
for the program; c:\pmail\mail for the mail directories.
2. Run PCONFIG.exe from the WinPMail program directory and change the HOME and
NEW mail directory specification to the \\server\vol\pmail\mail\~8
format.
3. Go to the remote workstations and install a shortcut to the common
program.
Ok, now you have the basic mail system setup. You can send mail to each other using Pegasus Mail.
4. Install Mercury/32 on this same server pointing to the Pegasus Mail
directory structure. Use MercuryD, MercuryS, MercuryC at least. Use
\\server\vol\mercury\queue for the mail spool directory.
5. Point MercuryD at all of your POP3 mailboxes to download the mail to
your Pegasus Mail user directories.
You now can send and receive Internet mail via Pegasus Mail. The mail is delivered to the Pegasus Mail directories automatically. You send mail simply but putting the output files into the Mercury/32 mail spool directory. This is accomplished automatically with a Pegasus Mail User Defined Gateway.
6. If you want to maintain other POP3/IMAP4 clients, point the client at
the at your Mercury/32 host as a POP3 and SMTP host using the Pegasus
Mail username and password to pickup the mail.
i'm sorry, but i cannot follow your instructions...
what i mean is..when i want to configure both pegasus and mercury to be working in localhost only..no need internet connection.
what is the right answer to put in these form...
and when installing mercury/32...these is the form..
ok..these is the form that i dont know what to fill in...sorry for your trouble..and thanx a lot for helping
A lot of these questions were answered in my first post, are you sure you read it?
If you do not need the internet connection parts do not use them. The process is simple, you install Pegasus Mail to c:\pmail as Multiuser using c:\pmail\mail as the mailbox location.
You install Mercury/32 to c:\mercury using the defaults and then point it at the Pegasus Mail program (c:\pmail\programs) and mailbox (c:\pmail\mail) locations during the install.
> installingnew copy
Pegasus Mail is installed to c:\pmail
> installation option
Multiuser and the mail directory is c:\pmail\mail
> email address
It's the local username and the domain you use when creating the users in Configuration | Manage local users. For example, if you use mydomain.com in the Configuration | Mercury core | Domains and create a user called Admin then the e-mail address is admin@mydomain.com. The Tools | Internet options | General entries are not required in a integrated setup.
> pop server
If on the same system as Mercury then use 127.0.0.1. The Tools | Internet options | (Receiving)POP3 is not required on an integrated setup.
The username is the name is the user you created in Mercury/32. The password is the password you gave the user.
> smtp
If on the same system as Mercury then use 127.0.0.1. The Tools | Internet options | (Sending) SMTP is not required on an integrated setup.
> where to install?
c:\mercury
> integration with pagsus
> mailbox directory
c:\pmail\mail\~n
> protocol to choose
> smtp client module
MercuryC is only required when sending off server to the internet and then you would use the name of the ISPs SMTP host.
> basic configurations
> queue location
c:\mercury\queue
> relay
