[quote user="Ron Mitchell"]
I've run into problems every way I turn, trying to upgrade my wife's computer so that she has the Spamhalter feature. In the past I upgraded simply by downloading the new version, which replaced the old, usually it picked up the mailbox too.
Every time I attempted to download 4.41, it said Pegasus was running & blew the install away - it wasn't running at all. In the end, the only solution I came up with was to remove 4,3, then my troubles started. It wasn't in the "Program" list, so couldn't be removed cleanly. All I could do was to delete it, so I did, just the Program folder, leaving the Mail folder intact (I also saved a Mail backup copy elsewhere).
Are you sure the program was not running in the background? Did you use Windows Task Manager to verify it was not running? to close it?
4.41 then downloaded cleanly but, although the Mail & Program folders are in the same place as before, Pegasus doesn't see the mail files.
Can anyone tell me how to link the mail to the programme?
1. Use Help | About Pegasus Mail | Info and note the mail directories. I'm going to assume that these are c:\pmail for the programs and c:\pmail\mail\admin for the HOME and NEW mail directory.
2. Use "My Computer" and find the location of the old HOME and NEW mail directories. Since this is an old installation I'm going to assume it's c:\pmail\mail.
3. Exit WinPMail, very important.
4. Move all the files from c:\pmail\mail EXCEPT pmail.ini to the c:\pmail\mail\admin directory.
Now when you run WinPMail you should see all of the old files and folders.
[quote user="Ron Mitchell"]<blockquote><p>I've run into problems every way I turn, trying to upgrade my wife's computer so that she has the Spamhalter feature. In the past I upgraded simply by downloading the new version, which replaced the old, usually it picked up the mailbox too.</p><p>Every time I attempted to download 4.41, it said Pegasus was running &amp; blew the install away - it wasn't running at all. In the end, the only solution I came up with was to remove 4,3, then my troubles started. It wasn't in the "Program" list, so couldn't be removed cleanly. All I could do was to delete it, so I did, just the Program folder, leaving the Mail folder intact (I also saved a Mail backup copy elsewhere).</p></blockquote><p>Are you sure the program was not running in the background?&nbsp; Did you use Windows Task Manager to verify it was not running? to close it?
<blockquote><p>4.41 then downloaded cleanly but, although the Mail &amp; Program folders are in the same place as before, Pegasus doesn't see the mail files.</p></blockquote>
<blockquote><p>Can anyone tell me how to link the mail to the programme?&nbsp;</p></blockquote><p>1.&nbsp; Use Help | About Pegasus Mail | Info and note the mail directories.&nbsp; I'm going to assume that these are c:\pmail for the programs and c:\pmail\mail\admin for the HOME and NEW mail directory.</p><p>2.&nbsp; Use "My Computer" and find the location of the old HOME and NEW mail directories.&nbsp; Since this is an old installation I'm going to assume it's c:\pmail\mail.</p><p>3.&nbsp; <i><b>Exit WinPMail, very important.</b></i></p><p>4.&nbsp; Move all the files from c:\pmail\mail <i><b>EXCEPT pmail.ini</b></i> to the c:\pmail\mail\admin directory.&nbsp; </p><p>Now when you run WinPMail you should see all of the old files and folders.</p>&nbsp;
