Problem with Mercury
Assuming that gmx.de is the domain that this server is supposed to handle mail for you need to check the Local domains section in Mercury core configuration. Have a look at the help text to see how to do it.
If gmx.de is not your domain you are acting as an open relay, which is very bad. In that case go to MercuryS configuration, Connection control to correct it. Having the first two checkboxes checked (strict restrictions) is a good start; more information about the options are in Mercury help or the manual.
As for the error message, "555 5.5.2 Syntax error. j2sm5603868mue.4" doesn't look like a message from Mercury. Switch on session logging for the module in question to see what actually happens. (Remember to switch it off again, though.)
<p>Assuming that <span class="Apple-style-span" style="font-family: Tahoma; ">gmx.de is the domain that this server is supposed to handle mail for you need to check the Local domains section in Mercury core configuration. Have a look at the help text to see how to do it.</span></p><p>If <span class="Apple-style-span" style="font-family: Tahoma; ">gmx.de is not your domain you are acting as an open relay, which </span>is very bad. In that case go to MercuryS configuration, Connection control to correct it. Having the first two checkboxes checked (strict restrictions) is a good start; more information about the options are in Mercury help or the manual.</p><p>As for the error message, "<span class="Apple-style-span" style="font-family: Tahoma; ">555 5.5.2 Syntax error. j2sm5603868mue.4" <span class="Apple-style-span" style="font-family: Arial; ">doesn't look like a message from Mercury. Switch on session logging for the module in question to see what actually happens. (Remember to switch it off again, though.)</span></span></p><p><span class="Apple-style-span" style="font-family: Tahoma; "><span class="Apple-style-span" style="font-family: Arial; ">/Rolf </span></span></p>
<style></style>
Hi, I'm from Germany and my English isn't the best one. Today I installed
Mercury on my Computer. I also prepared a form in HTML which I wanted to send
with PHP and mercury. But while sending in Mercury, I got an error. I found out,
that it has to do with the "From" array in the header of the PHP
mail()-Function.
It looks like that:
     $from = '"My Name" <my@email.com>';
      $headers .=
"MIME-Version: 1.0\n";
      $headers .= "Content-type: text/html;
charset=iso-8859-1\n";
      $headers .= "From: $from\n";
      $headers
.= "Reply-To: ".$from."\n";
      $headers .= "X-Mailer: PHP/" .
phpversion(). "\n";
      $headers .= "X-Sender-IP: $REMOTE_ADDR\n";
$headers .= "Content-type: text/html\n";
But in Mercury I get the following error:
15 Nov 08 18:30, Servicing job MO00000F...  555 5.5.2 Syntax error.
j2sm5603868mue.4
and sometimes also this:
18:30:47: Job MG000026:  from  <********@gmx.de (non-local)
   To:
*****@freenet.de (non-local) (Job MO000027) -OK
I hope you understand my horrible English and you can help me!
&lt;style&gt;&lt;/style&gt;&lt;p&gt;Hi, I&#039;m from Germany and my English isn&#039;t the best one. Today I installed Mercury on my Computer. I also prepared a form in HTML which I wanted to send with PHP and mercury. But while sending in Mercury, I got an error. I found out, that it has to do with the &quot;From&quot; array in the header of the PHP mail()-Function.&lt;/p&gt; &lt;p&gt;&amp;nbsp;&lt;/p&gt; &lt;p&gt;It looks like that:&lt;/p&gt; &lt;p&gt;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; $from = &#039;&quot;My Name&quot; &amp;lt;my@email.com&amp;gt;&#039;; &amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; $headers .= &quot;MIME-Version: 1.0\n&quot;; &amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; $headers .= &quot;Content-type: text/html; charset=iso-8859-1\n&quot;; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp; $headers .= &quot;From: $from\n&quot;; &amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; $headers .= &quot;Reply-To: &quot;.$from.&quot;\n&quot;; &amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; $headers .= &quot;X-Mailer: PHP/&quot; . phpversion(). &quot;\n&quot;; &amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; $headers .= &quot;X-Sender-IP: $REMOTE_ADDR\n&quot;; &amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; $headers .= &quot;Content-type: text/html\n&quot;; &lt;/p&gt; &lt;p&gt;&amp;nbsp;&lt;/p&gt; &lt;p&gt;But in Mercury I get the following error:&lt;/p&gt; &lt;p&gt;15 Nov 08 18:30, Servicing job MO00000F...&amp;nbsp; 555 5.5.2 Syntax error. j2sm5603868mue.4 &lt;/p&gt; &lt;p&gt;and sometimes also this:&lt;/p&gt; &lt;p&gt;18:30:47: Job MG000026:&amp;nbsp; from&amp;nbsp; &amp;lt;********@gmx.de (non-local) &amp;nbsp;&amp;nbsp; To: *****@freenet.de (non-local) (Job MO000027) -OK&lt;/p&gt; &lt;p&gt;&amp;nbsp;&lt;/p&gt; &lt;p&gt;I hope you understand my horrible English and you can help me! &lt;/p&gt;
