SMTP problem with laptop on travels
Hi Thomas,
 Many thanks. It now works as I want it to. Your help is much appreciated.
Regards, Ron Hulme.
<P>Hi Thomas,</P> <P> Many thanks. It now works as I want it to. Your help is much appreciated.</P> <P>Regards, Ron Hulme.</P>
My e-mail ISP is DEMON.
In former times, using dial-up, Pegasus/TOOLS/INTERNET OPTIONS for RECEIVing and SENDing were specified as "pop3.demon.co.uk" and "post.demon.co.uk".
Then came broadband, and my broadband ISP (ntlworld) refused "post.demon.co.uk" for SENDing, and I have to use "smtp.ntlworld.com" instead.
Now I have a laptop, and "pop3.demon.co.uk" and "smtp.ntlworld.com" are accepted when I am in UK.
When I go out of country, however, "pop3.demon.co.uk" is still OK.  My problem is that, for SENDing, both "post.demon.co.uk" and "smtp.ntlworld.com" are rejected with the message "15: Peer connect failure (the host has refused the connection)". I am currently in Cyprus, using a wireless broadband network supplied by CYTANET, but I have tried SENDing via "smtp.cyta.com.cy" and still get the same error message.
Can you help me resolve this out-of-country SENDing problem, please? How should I specify SENDing parameters? And should I make a different local specificaton whenever I enter a new country?
I do not want to have to give up DEMON and/or PEGASUS (both of which are excellent facilities) and simply fall back onto HOTMAIL or something similar.
<P>My e-mail ISP is DEMON.</P> <P>In former times, using dial-up, Pegasus/TOOLS/INTERNET OPTIONS for RECEIVing and SENDing were specified as "pop3.demon.co.uk" and "post.demon.co.uk".</P> <P>Then came broadband, and my broadband ISP (ntlworld) refused "post.demon.co.uk" for SENDing, and I have to use "smtp.ntlworld.com" instead.</P> <P>Now I have a laptop, and "pop3.demon.co.uk" and "smtp.ntlworld.com" are accepted when I am in UK.</P> <P>When I go out of country, however, "pop3.demon.co.uk" is still OK.  My problem is that, for SENDing, both "post.demon.co.uk" and "smtp.ntlworld.com" are rejected with the message "15: Peer connect failure (the host has refused the connection)". I am currently in Cyprus, using a wireless broadband network supplied by CYTANET, but I have tried SENDing via "smtp.cyta.com.cy" and still get the same error message. </P> <P>Can you help me resolve this out-of-country SENDing problem, please? How should I specify SENDing parameters? And should I make a different local specificaton whenever I enter a new country? </P> <P>I do not want to have to give up DEMON and/or PEGASUS (both of which are excellent facilities) and simply fall back onto HOTMAIL or something similar.</P>
Try: mail-out.cytanet.com.cy in your 'Settings for sending mail (SMTP)'
For this circumstances you can use a GMail-account where you use smtp.gmail.com
Try: mail-out.cytanet.com.cy in your 'Settings for sending mail (SMTP)' For this circumstances you can use a GMail-account where you use smtp.gmail.com
Phons,
Many thanks.  --  "mail-out.cytanet.com.cy" worked fine here in Cyprus when I changed the setting as you suggested.
I do have a greater problem, though, and that is -- when in another country (for example, I shall be in Argentina next month) how do I find the equivalent SMTP setting for SENDing mail?
Once again, thank you for your speedy response,
Ron Hulme.
<P>Phons,</P> <P>Many thanks.  --  "mail-out.cytanet.com.cy" worked fine here in Cyprus when I changed the setting as you suggested.</P> <P>I do have a greater problem, though, and that is -- when in another country (for example, I shall be in Argentina next month) how do I find the equivalent SMTP setting for SENDing mail?</P> <P>Once again, thank you for your speedy response,</P> <P>Ron Hulme.</P>
Hello Ron,
As I wrote earlier you can get a free GMail-account, make a new SMTP-definition in Pegasus Mail (smtp.gmail.com) and you can overall the world use GMail's SMTP-server for sending your mail.
Take a look how to configure Pegasus Mail:
http://translate.google.com/translate?u=http%3A%2F%2Fwww.pegasusmail.nl%2Ftip42.php&hl=nl&ie=UTF-8&sl=nl&tl=en
under 'SMTP setting'.
Succes and have a nice trip.
<P>Hello Ron, As I wrote earlier you can get a free GMail-account, make a new SMTP-definition in Pegasus Mail (smtp.gmail.com) and you can overall the world use GMail's SMTP-server for sending your mail. Take a look how to configure Pegasus Mail: http://translate.google.com/translate?u=http%3A%2F%2Fwww.pegasusmail.nl%2Ftip42.php&hl=nl&ie=UTF-8&sl=nl&tl=en under 'SMTP setting'. Succes and have a nice trip. </P>
Hi Phons,
Thanks for your suggestion. I will attempt those changes (GMail) in a week's time when I have more free time, and I will let you know the result.
Regards, Ron Hulme.
<P>Hi Phons,</P> <P>Thanks for your suggestion. I will attempt those changes (GMail) in a week's time when I have more free time, and I will let you know the result.</P> <P>Regards, Ron Hulme.</P>
Hi Phons,
I have now made the GMAIL changes that you suggested, and it seems to work OK. (I do not understand the need to enable IMAP, but I have done it anyway.)
Many thanks for your help.
There is one small problem remaining -- The recipient of an e-mail SMTP'd via GMail gets the impression that my DEMON e-id is no longer valid, because my DEMON e-id is overwritten in the "FROM" header by my GMail e-id.  Is there any way of avoiding this problem?
Regards, Ron Hulme.
<P>Hi Phons,</P> <P>I have now made the GMAIL changes that you suggested, and it seems to work OK. (I do not understand the need to enable IMAP, but I have done it anyway.)</P> <P>Many thanks for your help.</P> <P>There is one small problem remaining -- The recipient of an e-mail SMTP'd via GMail gets the impression that my DEMON e-id is no longer valid, because my DEMON e-id is overwritten in the "FROM" header by my GMail e-id.  Is there any way of avoiding this problem?</P> <P>Regards, Ron Hulme.</P>
Yes, go into the GMail account and add the alternate email address.  Settings | Accounts | Send mail as:
<blockquote>There is one small problem remaining -- The recipient of an e-mail SMTP'd via GMail gets the impression that my DEMON e-id is no longer valid, because my DEMON e-id is overwritten in the "FROM" header by my GMail e-id.  Is there any way of avoiding this problem?</blockquote><p>Yes, go into the GMail account and add the alternate email address.  Settings | Accounts | Send mail as:</p><p> </p>
