SMTP Server Connection control settings
Hi!
Is it save to use the following settings for SMTP server connection control:
Do not permit SMTP relaying of non-local mail - Active
Use strict local relaying restrictions - Active
Authenticated SMTP connections may relay mail - Active
Only Authenticated SMTP connections may relay mail - NOT Active
Up to now I had the last option active but now I want to use SharpWebMail to have a web access to my mail accounts and I do not know how to tell SharpWebMail to use a user + password to authenticate itself. So I disabled this option.
Is there a security issue why I should not do this?
I need the 3rd option since external users must be able to send mails...
Konrad
<p>Hi!</p><p>Is it save to use the following settings for SMTP server connection control:</p><p>Do not permit SMTP relaying of non-local mail - Active</p><p>Use strict local relaying restrictions - Active</p><p>Authenticated SMTP connections may relay mail - Active </p><p>Only Authenticated SMTP connections may relay mail - NOT Active</p><p> </p><p>Up to now I had the last option active but now I want to use SharpWebMail to have a web access to my mail accounts and I do not know how to tell SharpWebMail to use a user + password to authenticate itself. So I disabled this option.</p><p>Is there a security issue why I should not do this?</p><p>I need the 3rd option since external users must be able to send mails... </p><p>Thanks,</p><p>Konrad </p>
[quote user="Konrad Hammerer"]
Hi!
I've run like this for years without problems.  As long as you do not allow any remote IP addresses to relay you should not have any problem with this setup.  Check out what IP addresses are allowed to relay very carefully.
Konrad
[quote user="Konrad Hammerer"]<blockquote><p>Hi!</p><p>Is it save to use the following settings for SMTP server connection control:</p><p>Do not permit SMTP relaying of non-local mail - Active</p><p>Use strict local relaying restrictions - Active</p><p>Authenticated SMTP connections may relay mail - Active </p><p>Only Authenticated SMTP connections may relay mail - NOT Active</p><p>Up to now I had the last option active but now I want to use SharpWebMail to have a web access to my mail accounts and I do not know how to tell SharpWebMail to use a user + password to authenticate itself. So I disabled this option.</p></blockquote><p>I've run like this for years without problems.  As long as you do not allow any remote IP addresses to relay you should not have any problem with this setup.  Check out what IP addresses are allowed to relay very carefully. </p><blockquote><p>Is there a security issue why I should not do this?</p><p>I need the 3rd option since external users must be able to send mails... </p><p>Thanks,</p><p>Konrad </p></blockquote>[/quote]
