[quote user="Bidul63"]
I have a Mercury Transport System (V 1.48) for Novell NetWare.
Is it possible to modify the SMTP port to 26 (default value is 25) ? How I can do this, what are the modification to do in Mercury.ini ?
Not possible, the port 25 is fixed in the program. You can change the port on Mercury/32 though and you can use Mercury/32 as a front-end to Mercury.
[/quote]Thank for your answer.
Bidul63.
[quote user="Bidul63"]<blockquote><p>Hello,</p><p>I have a Mercury Transport System (V 1.48) for Novell NetWare.</p><p>Is it possible to modify the SMTP port to 26 (default value is 25) ? How I can do this, what are the modification to do in Mercury.ini ?</p></blockquote><p>Not possible, the port 25 is fixed in the program.&nbsp; You can change the port on Mercury/32 though and you can use Mercury/32 as a front-end to Mercury.
</p><blockquote><p>&nbsp;Thank for your answer.
</p><p>&nbsp;Bidul63.</p></blockquote>[/quote]
