Yes I did.....but I must tell you after I signed off the forum and shut down computer
due to a couple of office meetings I had and then coming back and turning computer back on
everything was normal....I don't get it at all. In essesnce we're back to normal but never thought I
would have to that in order to regain the send faction, As mentioned I received okay all along.
Thanks for reading AND your support for being there. Maybe i should think about changing
the password workings.
<p>Yes I did.....but I must tell you after I signed off the forum and shut down computer</p><p> due to a couple of office meetings I had and then coming back and turning computer back on</p><p>everything was normal....I don't get it at all. In essesnce we're back to normal but never thought I</p><p>would have to that in order to regain the send faction, As mentioned I received okay all along.</p><p>Thanks for reading AND your support for being there. Maybe i should think about changing&nbsp;</p><p>the password workings.
</p><p>&nbsp;</p>
