resize preview mode.
Ttsar, I have also experienced this problem. It appears to be related to HTML messages. I have found that by disabling BearHTML, at lot of these types of problems go away (see my currently active post on Pmail and BearHTML).
Thanks., SJS.
<P>Ttsar, I have also experienced this problem. It appears to be related to HTML messages. I have found that by disabling BearHTML, at lot of these types of problems go away (see my currently active post on Pmail and BearHTML).</P> <P>Thanks., SJS.</P>
hi Pmail-experts !
I'm using Pegasus mail 4.41 and I'm using the preview-mode for my mailbox.
It happens very often that resizing the right-bottom window results in a extra-line (sometimes there are 2, 3 .extra horizontal rules..) on my screen
I suppose this is a minor bug...
Could this be solved ?
<p>hi Pmail-experts !</p><p>I'm using Pegasus mail 4.41 and I'm using the preview-mode for my mailbox. It happens very often that resizing the right-bottom window results in a extra-line (sometimes there are 2, 3 .extra horizontal rules..) on my screen </p><p>I suppose this is a minor bug... Could this be solved ? </p>
Am I the only pegasus user with this ?
could somebody check this out plz ?
<p>Am I the only pegasus user with this ?</p><p>could somebody check this out plz ? </p>
[quote user="tsar"]
No reply generally means nobody understood the question or they have never seen the problem.  I my case I've never seen anything like this.
[quote user="tsar"]<blockquote><p>Am I the only pegasus user with this ?</p><p>could somebody check this out plz ? </p></blockquote><p>No reply generally means nobody understood the question or they have never seen the problem.  I my case I've never seen anything like this.  </p>[/quote]
[Quote] I my case I've never seen anything like this.  [/Quote]
ok... but did you try to resize this preview mode ?
<p>[Quote] I my case I've never seen anything like this.  [/Quote]</p><p>ok... but did you try to resize this preview mode ?  </p>
