[quote user="peterelliott11"]Right then, still doing it.Here is the details out of the Mercury.Ini file
[MercuryC]
Host : smtp1.mail.com
Failfile : C:\MERCURY\Mercury\FAILURE.MER
HELO : Peter Elliott
Poll : 30
Scratch : C:\MERCURY\scratch
ReturnLines : 15
Timeout : 30
ESMTP : 1
SMTP_Username: peter.j.elliott:XXXBLANKEDXXX.com#mail.com
SMTP_Password: XXXBLANKEDXXX
POP3_Auth : 0
POP3_Host : pop1.mail.com
Logfile : C:\MERCURY\Logs\MercuryC\~y-~m-~d.log
Log_Verbose : 1
Session_logging : C:\MERCURY\Sessions\MercuryC
Session_logmode : 1On SMTP username, when I check the details in MercuryC after I shut it down and restart it, the #mail.com disappears and I have to re-enter it before the server sends messages out.
However, the entry remains in the .INI file regardless, it's as if the program is 'forgetting' everything after .com[/quote]
I believe that Mercury/32 treats the # as a special comment character in the file. Everything after the # is treated as a comment and so not used in the username. I tested this and sure enough the #mail.com is trimmed from the username string. That said I believe that most ISPs that use special characters in a username will generally allow you to use another character for the # (say like an underscore) that would perform the same task.
