[quote user="blallen58"]
here is a copy of the log file:
T 20090317 114334 840 Begin processing job MO000004 from postmaster@ecbhlme.org
E 20090317 114334 840 530 5.7.0 Must issue a STARTTLS command first. 9sm2166941yxs.6
[/quote]This suggests that you do not have the security settings correct[quote]
T 20090317 142642 6ac Begin processing job MO001E26 from postmaster@localhost
E 20090317 142647 6ac 550 5.7.1 Unable to relay[/quote]This will be a problem. Email addresses with a domain part of "localhost" will get rejected. You need to have a proper domain part.
[quote]T 20090317 142647 6ac Begin processing job MO000002 from postmaster@ecbhlme.org
E 20090317 142657 6ac 550 5.7.1 Unable to relay[/quote]As well as authenticating correctly, you will need to set up your Gmail account to relay mail for the given addresses.[quote]
T 20090317 160734 6ac Established ESMTP connection to 192.168.10.15
T 20090317 160734 6ac Begin processing job MO001E2D from postmaster@localhost
T 20090317 160734 6ac MAIL FROM:<postmaster@localhost> SIZE=370
T 20090317 160734 6ac 250 2.1.0 Sender OK
T 20090317 160734 6ac RCPT TO:<ballen@ecbhlme.org>
T 20090317 160734 6ac 250 2.1.5 Recipient OK
T 20090317 160734 6ac Job MO001E2D from postmaster@localhost processed OK.
T 20090317 160807 6ac Established ESMTP connection to 192.168.10.15
T 20090317 160807 6ac Begin processing job MO001E2F from postmaster@localhost
T 20090317 160807 6ac MAIL FROM:<postmaster@localhost> SIZE=363
T 20090317 160807 6ac 250 2.1.0 Sender OK
T 20090317 160807 6ac RCPT TO:<ballen@ec.rr.com>
E 20090317 160812 6ac 550 5.7.1 Unable to relay
If you go into the MercuryC config menu & enable session logging you will get a transcript of the actual exchange of messages between the client and server, which is usually a lot more helpful than the General Log. (Also remember to turn it off after troubleshooting as it eats disk space fairly rapidly.)
