AW: Problem receiving mail: violation of STD53?
There was a problem, however!
This turned out to be a problem on the server with some of the mails were under root ownership. Now been sorted.
Ellie
<p>There was a problem, however! </p><p>This turned out to be a problem on the server with some of the mails were under root ownership. Now been sorted.</p><p>Thanks</p><p>Ellie </p>
Hello all,
 I am having the following problem with receiving mail and the error message is copied below. When the mail is accessed using the webmail (Horde) utility, there are currently 2 messages in the inbox. (The webmail figure bizarrely shows 3, but only 2 are seen). They are not large mails, both being under 200 kb.
What would cause the following message?
[*] Connection established to 204.244.125.10
>> 0058 +OK Hello there. <8981.1240167172@localhost.localdomain>
<< 0031 USER email@xxxx.com
>> 0024 +OK Password required.
<< 0014 PASS XXXXXXX
>> 0016 +OK logged in.
<< 0006 STAT
>> 0014 +OK 3 438049
<< 0006 LIST
>> 0055 +OK POP3 clients that break here, they violate STD53.
<< 0008 UIDL 1
>> 0024 +OK 1 UID25-1239911524
<< 0009 TOP 1 1
>> 0047 -ERR Can't open the message file - it's gone!
Many thanks in advance.
Ellie
&lt;p&gt;Hello all,&lt;/p&gt;&lt;p&gt;&amp;nbsp;I am having the following problem with receiving mail and the error message is copied below. When the mail is accessed using the webmail (Horde) utility, there are currently 2 messages in the inbox. (The webmail figure bizarrely shows 3, but only 2 are seen). They are not large mails, both being under 200 kb.&lt;/p&gt;&lt;p&gt;What would cause the following message? &lt;/p&gt;&lt;p&gt;[*] Connection established to 204.244.125.10 &amp;gt;&amp;gt; 0058 +OK Hello there. &amp;lt;8981.1240167172@localhost.localdomain&amp;gt; &amp;lt;&amp;lt; 0031 USER email@xxxx.com &amp;gt;&amp;gt; 0024 +OK Password required. &amp;lt;&amp;lt; 0014 PASS XXXXXXX &amp;gt;&amp;gt; 0016 +OK logged in. &amp;lt;&amp;lt; 0006 STAT &amp;gt;&amp;gt; 0014 +OK 3 438049 &amp;lt;&amp;lt; 0006 LIST &amp;gt;&amp;gt; 0055 +OK POP3 clients that break here, they violate STD53. &amp;lt;&amp;lt; 0008 UIDL 1 &amp;gt;&amp;gt; 0024 +OK 1 UID25-1239911524 &amp;lt;&amp;lt; 0009 TOP 1 1 &amp;gt;&amp;gt; 0047 -ERR Can&#039;t open the message file - it&#039;s gone!&lt;/p&gt;&lt;p&gt;Many thanks in advance.&lt;/p&gt;&lt;p&gt;Ellie &lt;/p&gt;
I can not say why is there  "0047 -ERR Can't open the message file - it's gone!", but after "<< 0006 LIST" command I can say you:
 This message is explicit, it says :
         "if LIST doesn't have argument then report that client violate STD53"
This should be no problem.
&lt;P&gt;Hello, &lt;/P&gt; &lt;P&gt;I can not say why is there &amp;nbsp;&quot;0047 -ERR Can&#039;t open the message file - it&#039;s gone!&quot;, but after&amp;nbsp;&quot;&amp;lt;&amp;lt; 0006 LIST&quot; command&amp;nbsp;I can&amp;nbsp;say you:&lt;/P&gt; &lt;P&gt;&amp;nbsp;This message is explicit, it says : &amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; &quot;if LIST doesn&#039;t have argument then report that client violate STD53&quot;&amp;nbsp;&lt;/P&gt; &lt;P&gt;This should be no problem. &lt;/P&gt; &lt;P mce_keep=&quot;true&quot;&gt;&amp;nbsp;&lt;/P&gt;
