No Response from Web tools for Mercury/32
When a user logs in the program will count the number of messages in the Inbox and add up the size. If there are a lot of messages this could, depending on the speed and load of the server, take some time, but that should anyhow not be a very long time.
There is a slightly newer version of the program available here in case that could help.
(If you double-click the log listbox to the right the contents will be copied to a file in the same directory as the program.)
<p>When a user logs in the program will count the number of messages in the Inbox and add up the size. If there are a lot of messages this could, depending on the speed and load of the server, take some time, but that should anyhow not be a very long time. </p><p>There is a slightly newer version of the program available <a href="http://83.140.29.200/HTTPServer.zip" target="_blank" mce_href="http://83.140.29.200/HTTPServer.zip">here</a> in case that could help. </p><p>(If you double-click the log listbox to the right the contents will be copied to a file in the same directory as the program.)</p><p>/Rolf </p>
Hey Rolf --
Was wondering if you could help with this one. i have no trouble connecting with most of the users of the system through Web Tools, but there is 1 user who gets a blank response when he logs in.
Nothing is displayed, nothing is returned to the browser at all. i have confirmed this through a variety of different methods, so i can confirm that no bytes are returned after logging in.
I looked for a HTTPserver log file, but couldn't find one. in the log window it shows the connection, but nothing else.
I will note that this user has a lot of mail in his account (~22,000 messages) but that really shouldn't affect web tools, right?
Any guidance here would be most helpful. thanks.
Air YT
<p>Hey Rolf -- </p><p>Was wondering if you could help with this one. i have no trouble connecting with most of the users of the system through Web Tools, but there is 1 user who gets a blank response when he logs in.</p><p>Nothing is displayed, nothing is returned to the browser at all. i have confirmed this through a variety of different methods, so i can confirm that no bytes are returned after logging in. </p><p>I looked for a HTTPserver log file, but couldn't find one. in the log window it shows the connection, but nothing else.</p><p>I will note that this user has a lot of mail in his account (~22,000 messages) but that really shouldn't affect web tools, right?</p><p>Any guidance here would be most helpful. thanks.</p><p>Air YT </p>
