Thanks for your comments.
"Might simply be that the path is too long" does seem to be the case. Also, long file names seem to be ok with a shorter path.
This was a means to an end of trying to use MailStore for archiving. A different program has been suggested, in another post, that is compatible with PMail without having to save to disc first. I will trial that first in case I don't need to worry about this particular problem.
Terry
<p>Thanks for your comments.</p><p>"Might simply be that the path is too long" does seem to be the case. Also, long file names seem to be ok with a shorter path. </p><p>This was a means to an end of trying to use MailStore&nbsp; for archiving. A different program has been suggested, in another post, that is compatible with PMail without having to save to disc first. I will trial that first in case I don't need to worry about this particular problem.</p><p>Terry
