Thomas ,
Thanks again.
I'm not sure I fully grasp the difference between folders and trays even after reading through the relevant Pegasus help topic. I'll play around with adding folders and/or trays and see if I can figure it all out.
Can you elaborate on what you mean by "delete any tray stucture" . I'mnot sure what this means. Do you mean the order in which folders are
listed?
If you use trays to store folders then the trays will be lost and you just get a listing of the folders. The tray structure is only in the hierarch.pm.
<p>Thomas ,</p><p>Thanks again.</p><p>I'm not sure I fully grasp the difference between folders and trays even after reading through the relevant Pegasus help topic. I'll play around with adding folders and/or trays and see if I can figure it all out.
</p><p>[quote user="Thomas R. Stephenson"]</p><blockquote>Can you elaborate on what you mean by "delete any tray stucture" . I'm
listed?</blockquote><p>If you use trays to store folders then the trays will be lost and you just get a listing of the folders.&nbsp; The tray structure is only in the hierarch.pm.</p><p>&nbsp;</p>[/quote]
