[quote user="feim"]
Hi from Argentina. Sorry for my english.
Since a few days I have some problems with my accounts configurations. I have configured the pop3 and smtp fine, but when I change the user or close Pegasus, when I come back the pop3 and smtp configuration changed. Instead pop3.feim.org.ar appear 127.0.0.1.
I disable the firewall and antivirus, but the problem persist.
Any idea? Thanks,
Leonardo
Does your ISP require to have specific software installed to be able to use mail. 127.0.0.1 means (mostly) connect to a program running on the local computer.
[quote user="feim"]<p>Hi from Argentina. Sorry for my english.</p><p>Since a few days I have some problems with my accounts configurations. I have configured the pop3 and smtp fine, but when I change the user or close Pegasus, when I come back the pop3 and smtp configuration changed. Instead pop3.feim.org.ar appear 127.0.0.1.</p><p>I disable the firewall and antivirus, but the problem persist.</p><p>Any idea? Thanks,</p><p>Leonardo</p><p>&nbsp;[/quote]</p><p>Does your ISP require to have specific software installed to be able to use mail. 127.0.0.1 means (mostly) connect to a program running on the local computer.</p><p>&nbsp;</p>
Han van den Bogaerde - support@vandenbogaerde.net
Member of Pegasus Mail Support Group.
My own Pegasus Mail related web information:
http://www.vandenbogaerde.net/pegasusmail/
