[quote user="Alar.Pandis@mtk.ut.ee"]
Forgot. ASSP is working together with Mercury/32.
Alar.
And against you, it would seem.
Mercury will not change the headers, only add a Recieved: line.
ASSP is my prime suspect, you should turn off ASSP and see if that solves the problem (of growing Ref header).
A valid message body must not have any single line greater than 1000 characters, so once the line exceeds this, it is no longer a valid message, which would explain why Merc can not process it correctly.
[quote user="Alar.Pandis@mtk.ut.ee"]<p>Forgot. ASSP is working together with Mercury/32.
Alar.</p><p>[/quote]</p><p>And against you, it would seem.</p><p>Mercury will not change the headers, only add a Recieved: line.</p><p>ASSP is my prime suspect, you should turn off ASSP and see if that solves the problem (of growing Ref header).</p><p>A valid message body must not have any single line greater than 1000 characters, so once the line exceeds this, it is no longer a valid message, which would explain why Merc can not process it correctly.
