Problem sending with MercuryE
Then your problem is not Mercury.
Either your firewall or ISP is blocking outbound connections to port 25 or the receiving server is rejecting your connection on account of your IP address.
Easy fix is use MercC to relay via your ISP's SMTP smarthost.
<p>Then your problem is not Mercury.</p><p>Either your firewall or ISP is blocking outbound connections to port 25 or the receiving server is rejecting your connection on account of your IP address.</p><p>Easy fix is use MercC to relay via your ISP's SMTP smarthost.</p><p> </p>
I wasn't able to find an answer to my problem on this forum, although it should not be uncommon. I cannot send mail with MercuryE. The DNS are manually and correctly set.  A log extract:
E 20091012 204828 4ad372a8 Processing of job MO0008B0 incomplete or failed.
T 20091012 204828 4ad372a3 Job MO0008B5 processing complete.
T 20091012 204828 4ad372a5 Job MO0008B3 processing complete.
T 20091012 204828 4ad372a6 Job MO0008B2 processing complete.
T 20091012 204828 4ad372a7 Job MO0008B1 processing complete.
E 20091012 204828 4ad372a1 Processing of job MO0008B7 incomplete or failed.
T 20091012 204828 4ad372aa Job MO0008AE processing complete.
T 20091012 204828 4ad372a9 Job MO0008AF processing complete.
T 20091012 204828 4ad372a4 Job MO0008B4 processing complete.
T 20091012 204828 4ad372a8 Job MO0008B0 processing complete.
T 20091012 204828 4ad372a1 Job MO0008B7 processing complete.
T 20091012 205015 4ad372ab Begin processing job MO000013 from postmaster@[<my correctly set fix ip>]
T 20091012 205031 4ad372ac Begin processing job MO000011 from postmaster@[<my correctly set fix ip>]
T 20091012 205031 4ad372ad Begin processing job MO000012 from postmaster@[<my correctly set fix ip>]
T 20091012 205031 4ad372ae Begin processing job MO000015 from postmaster@[<my correctly set fix ip>]
T 20091012 205031 4ad372af Begin processing job MO000017 from postmaster@[<my correctly set fix ip>]
T 20091012 205031 4ad372b0 Begin processing job MO000018 from postmaster@[<my correctly set fix ip>]
W 20091012 205036 4ad372ab Error connecting to primary server '209.85.223.91'.
W 20091012 205052 4ad372ae Error connecting to primary server '209.85.223.91'.
W 20091012 205052 4ad372ad Error connecting to primary server '209.85.223.91'.
W 20091012 205052 4ad372af Error connecting to primary server '209.85.223.91'.
W 20091012 205052 4ad372b0 Error connecting to primary server '209.85.223.91'.
W 20091012 205052 4ad372ac Error connecting to primary server '209.85.223.91'.
W 20091012 205058 4ad372ab Error connecting to alternate server '209.85.210.52'.
My internet connection is via a cable modem, but my ISP always designates the same IP address. The same IP address is set in the 'Identify myself as' field too.
I attempt to send a simple email message to my own accounts on gmail, gmx etc. - no success... What can be the problem?
I managed to connect via telnet to some server on port 25, so I guess my ISP is not blocking it, but not to the servers which are resolved as gmail, gmx...?
Thanks for your help
&lt;p&gt;Hello,&lt;/p&gt;&lt;p&gt;I wasn&#039;t able to find an answer to my problem on this forum, although it should not be uncommon. I cannot send mail with MercuryE. The DNS are manually and correctly set.&amp;nbsp; A log extract:&lt;/p&gt;&lt;p&gt;E 20091012 204828 4ad372a8 Processing of job MO0008B0 incomplete or failed. T 20091012 204828 4ad372a3 Job MO0008B5 processing complete. T 20091012 204828 4ad372a5 Job MO0008B3 processing complete. T 20091012 204828 4ad372a6 Job MO0008B2 processing complete. T 20091012 204828 4ad372a7 Job MO0008B1 processing complete. E 20091012 204828 4ad372a1 Processing of job MO0008B7 incomplete or failed. T 20091012 204828 4ad372aa Job MO0008AE processing complete. T 20091012 204828 4ad372a9 Job MO0008AF processing complete. T 20091012 204828 4ad372a4 Job MO0008B4 processing complete. T 20091012 204828 4ad372a8 Job MO0008B0 processing complete. T 20091012 204828 4ad372a1 Job MO0008B7 processing complete. T 20091012 205015 4ad372ab Begin processing job MO000013 from postmaster@[&amp;lt;my correctly set fix ip&amp;gt;] T 20091012 205031 4ad372ac Begin processing job MO000011 from postmaster@[&amp;lt;my correctly set fix ip&amp;gt;] T 20091012 205031 4ad372ad Begin processing job MO000012 from postmaster@[&amp;lt;my correctly set fix ip&amp;gt;] T 20091012 205031 4ad372ae Begin processing job MO000015 from postmaster@[&amp;lt;my correctly set fix ip&amp;gt;] T 20091012 205031 4ad372af Begin processing job MO000017 from postmaster@[&amp;lt;my correctly set fix ip&amp;gt;] T 20091012 205031 4ad372b0 Begin processing job MO000018 from postmaster@[&amp;lt;my correctly set fix ip&amp;gt;] W 20091012 205036 4ad372ab Error connecting to primary server &#039;209.85.223.91&#039;. W 20091012 205052 4ad372ae Error connecting to primary server &#039;209.85.223.91&#039;. W 20091012 205052 4ad372ad Error connecting to primary server &#039;209.85.223.91&#039;. W 20091012 205052 4ad372af Error connecting to primary server &#039;209.85.223.91&#039;. W 20091012 205052 4ad372b0 Error connecting to primary server &#039;209.85.223.91&#039;. W 20091012 205052 4ad372ac Error connecting to primary server &#039;209.85.223.91&#039;. W 20091012 205058 4ad372ab Error connecting to alternate server &#039;209.85.210.52&#039;. &lt;/p&gt;&lt;p&gt;My internet connection is via a cable modem, but my ISP always designates the same IP address. The same IP address is set in the &#039;Identify myself as&#039; field too.&lt;/p&gt;&lt;p&gt;I attempt to send a simple email message to my own accounts on gmail, gmx etc. - no success... What can be the problem? &lt;/p&gt;&lt;p&gt;I managed to connect via telnet to some server on port 25, so I guess my ISP is not blocking it, but not to the servers which are resolved as gmail, gmx...?&lt;/p&gt;&lt;p&gt;Thanks for your help &lt;/p&gt;
Turn on session logging (temporarily) for MercE, which will give a transcript of the outgoing SMTP session.
&lt;p&gt;Turn on session logging (temporarily) for MercE, which will give a transcript of the outgoing SMTP session.&lt;/p&gt;&lt;p&gt;&amp;nbsp; &lt;/p&gt;
just to add that the mercury.exe instance is in the exclusion list of my windows firewall, and that I set the ip address, dns etc. fix in the network settings.
here is what I get.
21:47:38.015: --- Mon Oct 12 21:47:38 2009 ---
21:47:38.015: Connect to '209.85.218.60', timeout 60.
21:47:52.656: --- Mon Oct 12 21:47:52 2009 ---
21:47:52.656: Connect to '209.85.218.60', timeout 60.
21:48:14.656: 15: Peer connect failure
21:48:14.656: --- Mon Oct 12 21:48:14 2009 ---
21:48:14.656: Connect to '209.85.223.79', timeout 60.
[quote user=&quot;dilberts_left_nut&quot;]&lt;p&gt;Turn on session logging (temporarily) for MercE, which will give a transcript of the outgoing SMTP session.&lt;/p&gt;&lt;p&gt;[/quote]&lt;/p&gt;&lt;p&gt;here is what I get. &lt;/p&gt;&lt;p&gt;21:47:38.015: --- Mon Oct 12 21:47:38 2009 --- 21:47:38.015: Connect to &#039;209.85.218.60&#039;, timeout 60. 21:47:52.656: --- Mon Oct 12 21:47:52 2009 --- 21:47:52.656: Connect to &#039;209.85.218.60&#039;, timeout 60. 21:48:14.656: 15: Peer connect failure 21:48:14.656: --- Mon Oct 12 21:48:14 2009 --- 21:48:14.656: Connect to &#039;209.85.223.79&#039;, timeout 60. &lt;/p&gt;
[quote user="dilberts_left_nut"]Can you connect to these by telnet?
no.
&lt;p&gt;[quote user=&quot;dilberts_left_nut&quot;]Can you connect to these by telnet? [/quote]&lt;/p&gt;&lt;p&gt;no. &lt;/p&gt;
