Betreft: how to fix this Error
hello Phons van Oploo
I already have a folder named "To Publicity" which is giving me problem while i try to save sent copies on it. I think Thomas means changing the name of "To Publicity to something else
kalu
<p>hello Phons van Oploo I already have a folder named "To Publicity" which is giving me problem while i try to save sent copies on it. I think Thomas means changing the name of "To Publicity to something else</p><p>Thanks</p><p>kalu </p>
Hi everyone
I have a folder on pegasus mail named "To Publicity"
1) i do right click it and - check for consistency. It says "no problem were detected in this folder"
2) I do right click the folder and - Reindex folder it says "Folder succefully re-indexed.......bla bla"
and when ever i send a message and save a copy to to problematic folder it pops up this message
 http://www.imageno.com/7ncdi4tg9kf4pic.html
i have deleted the FOL01.... file copied the content to new "To Publicity" folder but yet the same messages bugging my head
i hope some of you might have faced the same problem i would appreciate if you could share or suggest me how to fix this issue.
<p>Hi everyone </p><p>I have a folder on pegasus mail named "To Publicity"</p><p>1) i do right click it and - check for consistency. It says "no problem were detected in this folder"</p><p>2) I do right click the folder and - Reindex folder it says "Folder succefully re-indexed.......bla bla"</p><p>and when ever i send a message and save a copy to to problematic folder it pops up this message</p><p> http://www.imageno.com/7ncdi4tg9kf4pic.html</p><p>i have deleted the FOL01.... file copied the content to new "To Publicity" folder but yet the same messages bugging my head</p><p>i hope some of you might have faced the same problem i would appreciate if you could share or suggest me how to fix this issue.</p><p>Thanks </p><p> </p>
hello everyone.
is my case, so severe that there is no cure for it ?
please show me the way. how to solve this problem.
Thanks in advance
kalu
<p>hello everyone. is my case, so severe that there is no cure for it ?</p><p> :(</p><p>please show me the way. how to solve this problem.</p><p>Thanks in advance</p><p>kalu </p>
I have a folder on Pegasus mail named "To Publicity"
Sounds to me like you have a messed up hierarch.pm and there is a folder with the same name not showing.  To test this change the name of the folder you can see to something else and then see what happens when you do the copy self.
<blockquote><p>I have a folder on Pegasus mail named "To Publicity"</p><p>1) i do right click it and - check for consistency. It says "no problem were detected in this folder"</p></blockquote><p>Sounds to me like you have a messed up hierarch.pm and there is a folder with the same name not showing.  To test this change the name of the folder you can see to something else and then see what happens when you do the copy self.</p><p> </p>
Hi Thomas R. Stephenson Thankyou for the reply
Do you mean changing the problematic folder in this case "To Publicity" to something else.
i will give it a try . thanks
kalu
<p>Hi Thomas R. Stephenson Thankyou for the reply </p><p>Do you mean changing the problematic folder in this case "To Publicity" to something else.</p><p>i will give it a try . thanks</p><p>kalu </p>
Hello Kalu,
I suppose, Thomas means: "Change the name of the folder 'To Publicity'."
<P>Hello Kalu, I suppose, Thomas means: "Change the name of the folder 'To Publicity'." </P>
