spam help
This appears to be mostly a Mercury settings issue so I've moved it to the Mercury support forum.
There are various ways to stop spam and using reputable DNSBLs and SpamHalter are two good ones. You can consider using Graywall as well - it will delay good mail a bit but stops a lot of trash.
In Mercury make sure that relaying has been restricted. Go to MercuryS configuration, Connection control and verify that at least "Use strict local relaying restrictions" is clicked. "Only authenticated SMTP connections may relay mail" gives the highest protection.
In  MercuryS configuration, General you should normally not have "Accept mail for invalid local addresses" checked.
Finally make sure that all the spam that is tagged by blacklists or SpamHalter are moved to a spam control account by a global rule.
Any spam message addressed to you that is not caught by an anti-spam measure will simply end up in your mailbox, and will not cause any bounce notification. To be quite sure not to send replies to spam you may want to avoid using autoreplies, though.
<p>This appears to be mostly a Mercury settings issue so I've moved it to the Mercury support forum.</p><p>There are various ways to stop spam and using reputable DNSBLs and SpamHalter are two good ones. You can consider using Graywall as well - it will delay good mail a bit but stops a lot of trash.</p><p>In Mercury make sure that relaying has been restricted. Go to MercuryS configuration, Connection control and verify that at least "Use strict local relaying restrictions" is clicked. "Only authenticated SMTP connections may relay mail" gives the highest protection.</p><p>In  MercuryS configuration, General you should normally not have "Accept mail for invalid local addresses" checked.</p><p>Finally make sure that all the spam that is tagged by blacklists or SpamHalter are moved to a spam control account by a global rule.</p><p>Any spam message addressed to you that is not caught by an anti-spam measure will simply end up in your mailbox, and will not cause any bounce notification. To be quite sure not to send replies to spam you may want to avoid using autoreplies, though.</p><p>/Rolf </p>
 I am running Mercury32 4.72 via
At one point I started getting spam to a mailbox and it was benign till the flood gates opened 2 weeks ago... The spammers are from china and send 100+ emails per hour to two email addresses of mine. I deployed Zen.Spamhaus and SpamCop to filter the mail,,, 2 to 6 still get through an hour...
 I got a warning from my ISP and I think it is due to the traffic I recieve from the spammer but I need to know if somehow I am being used as the spammer... people are telling me I am being used to bounce mail but i can't see it because all the mail is addressed to me... Please have a look at the headers I posted and if anyone can advise please do... My isp has been alerted I received a letter and I think my ISP was alerted by me as I was sending off reports to admins and such via Spamcop...
at this point I have all mail forwarded to Gmail so the spam does not flow through my ISP to my server,,, but I would like to receive mail again here...
 XXXXX@ is my mailbox and mail.themoddepot.com is the mercury server...
[quote]
  1. Received: from spooler by mail. (Mercury/32 v4.72); 5 Nov 2009 23:59:14 -0500
  2. X-Envelope-To: <XXXXX@>
  3. X-SPAMWALL: Passed through antiSPAM test by Spamhalter 4.5.1.411 on mail.themoddepot.com (15)
  4. X-SPAMWALL: probability - 100.0%
  5. X-SPAMWALL: SPAM detected!
  6. Return-path: <annabelle.reyes_da@iuc.gnosjoregionen.nu>
  7. Received: from 41aw712 (220.72.234.198) by mail (Mercury/32 v4.72) ID MG000173;
  8.    5 Nov 2009 23:59:08 -0500
  9. Message-ID: <000701ca5e95$0ca81300$ae78a432@iuc.gnosjoregionen.nu>
  10. Reply-To: "Annabelle Reyes" <annabelle.reyes_da@iuc.gnosjoregionen.nu>
  11. From: "Annabelle Reyes" <annabelle.reyes_da@iuc.gnosjoregionen.nu>
  12. To: <XXXXX@>
  13. Subject: get Hydrocodone and vicodin online easily..
  14. Date: Thu, 05 Nov 2009 21:55:58 -0600
  15. MIME-Version: 1.0
  16. Content-Type: text/plain;
  17. format=flowed;
  18. charset="windows-1250"
  19. reply-type=original
  20. Content-Transfer-Encoding: 7bit
  21. X-Priority: 3
  22. X-MSMail-Priority: Normal
  23. X-Mailer: Microsoft Office Outlook, Build 11.0.5510
  24. X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2800.1807
  25.
  26. Purchase Rx~Medicationz Online!.. NO_Prescription_Required!
  27. Browse Our Website Today! -> http://easyonlinerxmedznow.com
  28.
[quote]
 Received: from spooler by mail.themoddepot.com (Mercury/32 v4.72); 6 Nov 2009 02:19:30 -0500
X-SPAMWALL: Passed through antiSPAM test by Spamhalter 4.5.1.411 on mail.themoddepot.com (19)
Return-path: <b.trevino_sq@firstnet.se>
Received: from 6kdxma3 (204.236.103.132) by mail.themoddepot.com (Mercury/32 v4.72) ID MG0002D1;
   6 Nov 2009 02:19:21 -0500
Message-ID: <000701ca5ea8$a26c1770$ae78a432@firstnet.se>
Reply-To: "Brittany Trevino" <b.trevino_sq@firstnet.se>
From: "Brittany Trevino" <b.trevino_sq@firstnet.se>
To: <XXXXX@>
Subject: Adult bedtime magic make it long and strong
Date: Fri, 06 Nov 2009 00:16:10 -0600
MIME-Version: 1.0
 format=flowed;
 reply-type=original
X-Priority: 3
Purchase RxMedications Online!.. N0_Prescription_Needed!
Browse 0ur_Selection Today! -> http://themybetterrx.com
XXXXX@t is my mailbox mail.themoddepot.com is my mercury server...
<!--end code block-->
&lt;p&gt;Hello,&lt;/p&gt; &lt;p&gt;&amp;nbsp;I am running Mercury32 4.72&amp;nbsp;via &lt;/p&gt; &lt;p mce_keep=&quot;true&quot;&gt;&amp;nbsp;&lt;/p&gt; &lt;p&gt;At one point I started getting spam to a mailbox and it was benign till the flood gates opened 2 weeks ago... The spammers are from china and send 100+ emails per hour to two email addresses of mine. I deployed Zen.Spamhaus and SpamCop to filter the mail,,, 2 to 6 still get through an hour...&lt;/p&gt; &lt;p mce_keep=&quot;true&quot;&gt;&amp;nbsp;&lt;/p&gt; &lt;p&gt;&amp;nbsp;I got a warning from my ISP and I think it is due to the traffic I recieve from the spammer but I need to know if somehow I am being used as the spammer... people are telling me I am being used to bounce mail but i can&#039;t see it because all the mail is addressed to me... Please have a look at the headers I posted and if anyone can advise please do... My isp has been alerted I received a letter and I think&amp;nbsp;my ISP was alerted by me as I was sending off reports to admins and such via Spamcop...&lt;/p&gt; &lt;p&gt;at this point I have all mail forwarded to Gmail so the spam does not flow through my ISP&amp;nbsp;to my server,,, but I would like to receive mail again here...&lt;/p&gt; &lt;p mce_keep=&quot;true&quot;&gt;&amp;nbsp;&lt;/p&gt; &lt;p&gt;Thanks&lt;/p&gt; &lt;p&gt;&amp;nbsp;&lt;a href=&quot;mailto:XXXXX@themoddepot.com&quot; mce_href=&quot;mailto:XXXXX@themoddepot.com&quot;&gt;XXXXX@&lt;/a&gt; is my mailbox and mail.themoddepot.com is the mercury server...&lt;/p&gt; &lt;p&gt;[quote]&lt;/p&gt; &lt;ol class=&quot;dp-py&quot;&gt; &lt;li class=&quot;alt&quot;&gt;&lt;span&gt;&lt;span&gt;Received:&amp;nbsp;from&amp;nbsp;spooler&amp;nbsp;by&amp;nbsp;mail. (Mercury/32&amp;nbsp;v4.72);&amp;nbsp;5&amp;nbsp;Nov&amp;nbsp;2009&amp;nbsp;23:59:14&amp;nbsp;-0500 &amp;nbsp;&amp;nbsp;&lt;/span&gt;&lt;/span&gt;&lt;/li&gt; &lt;li class=&quot;&quot;&gt;&lt;span&gt;X-Envelope-To:&amp;nbsp;&amp;lt;XXXXX@&amp;gt; &amp;nbsp;&amp;nbsp;&lt;/span&gt;&lt;/li&gt; &lt;li class=&quot;alt&quot;&gt;&lt;span&gt;X-SPAMWALL:&amp;nbsp;Passed&amp;nbsp;through&amp;nbsp;antiSPAM&amp;nbsp;test&amp;nbsp;by&amp;nbsp;Spamhalter&amp;nbsp;4.5.1.411&amp;nbsp;on&amp;nbsp;mail.themoddepot.com&amp;nbsp;(15) &amp;nbsp;&amp;nbsp;&lt;/span&gt;&lt;/li&gt; &lt;li class=&quot;&quot;&gt;&lt;span&gt;X-SPAMWALL:&amp;nbsp;probability&amp;nbsp;-&amp;nbsp;100.0% &amp;nbsp;&amp;nbsp;&lt;/span&gt;&lt;/li&gt; &lt;li class=&quot;alt&quot;&gt;&lt;span&gt;X-SPAMWALL:&amp;nbsp;SPAM&amp;nbsp;detected! &amp;nbsp;&amp;nbsp;&lt;/span&gt;&lt;/li&gt; &lt;li class=&quot;&quot;&gt;&lt;span&gt;Return-path:&amp;nbsp;&amp;lt;annabelle.reyes_da@iuc.gnosjoregionen.nu&amp;gt; &amp;nbsp;&amp;nbsp;&lt;/span&gt;&lt;/li&gt; &lt;li class=&quot;alt&quot;&gt;&lt;span&gt;Received:&amp;nbsp;from&amp;nbsp;41aw712&amp;nbsp;(220.72.234.198)&amp;nbsp;by&amp;nbsp;mail (Mercury/32&amp;nbsp;v4.72)&amp;nbsp;ID&amp;nbsp;MG000173; &amp;nbsp;&amp;nbsp;&lt;/span&gt;&lt;/li&gt; &lt;li class=&quot;&quot;&gt;&lt;span&gt;&amp;nbsp;&amp;nbsp;&amp;nbsp;5&amp;nbsp;Nov&amp;nbsp;2009&amp;nbsp;23:59:08&amp;nbsp;-0500 &amp;nbsp;&amp;nbsp;&lt;/span&gt;&lt;/li&gt; &lt;li class=&quot;alt&quot;&gt;&lt;span&gt;Message-ID:&amp;nbsp;&amp;lt;000701ca5e95$0ca81300$ae78a432@iuc.gnosjoregionen.nu&amp;gt; &amp;nbsp;&amp;nbsp;&lt;/span&gt;&lt;/li&gt; &lt;li class=&quot;&quot;&gt;&lt;span&gt;Reply-To:&amp;nbsp;&quot;Annabelle&amp;nbsp;Reyes&quot;&amp;nbsp;&amp;lt;annabelle.reyes_da@iuc.gnosjoregionen.nu&amp;gt; &amp;nbsp;&amp;nbsp;&lt;/span&gt;&lt;/li&gt; &lt;li class=&quot;alt&quot;&gt;&lt;span&gt;From:&amp;nbsp;&quot;Annabelle&amp;nbsp;Reyes&quot;&amp;nbsp;&amp;lt;annabelle.reyes_da@iuc.gnosjoregionen.nu&amp;gt; &amp;nbsp;&amp;nbsp;&lt;/span&gt;&lt;/li&gt; &lt;li class=&quot;&quot;&gt;&lt;span&gt;To:&amp;nbsp;&amp;lt;XXXXX@&amp;gt; &amp;nbsp;&amp;nbsp;&lt;/span&gt;&lt;/li&gt; &lt;li class=&quot;alt&quot;&gt;&lt;span&gt;Subject:&amp;nbsp;get&amp;nbsp;Hydrocodone&amp;nbsp;and&amp;nbsp;vicodin&amp;nbsp;online&amp;nbsp;easily.. &amp;nbsp;&amp;nbsp;&lt;/span&gt;&lt;/li&gt; &lt;li class=&quot;&quot;&gt;&lt;span&gt;Date:&amp;nbsp;Thu,&amp;nbsp;05&amp;nbsp;Nov&amp;nbsp;2009&amp;nbsp;21:55:58&amp;nbsp;-0600 &amp;nbsp;&amp;nbsp;&lt;/span&gt;&lt;/li&gt; &lt;li class=&quot;alt&quot;&gt;&lt;span&gt;MIME-Version:&amp;nbsp;1.0 &amp;nbsp;&amp;nbsp;&lt;/span&gt;&lt;/li&gt; &lt;li class=&quot;&quot;&gt;&lt;span&gt;Content-Type:&amp;nbsp;text/plain; &amp;nbsp;&amp;nbsp;&lt;/span&gt;&lt;/li&gt; &lt;li class=&quot;alt&quot;&gt;&lt;span&gt;format=flowed; &amp;nbsp;&amp;nbsp;&lt;/span&gt;&lt;/li&gt; &lt;li class=&quot;&quot;&gt;&lt;span&gt;charset=&quot;windows-1250&quot; &amp;nbsp;&amp;nbsp;&lt;/span&gt;&lt;/li&gt; &lt;li class=&quot;alt&quot;&gt;&lt;span&gt;reply-type=original &amp;nbsp;&amp;nbsp;&lt;/span&gt;&lt;/li&gt; &lt;li class=&quot;&quot;&gt;&lt;span&gt;Content-Transfer-Encoding:&amp;nbsp;7bit &amp;nbsp;&amp;nbsp;&lt;/span&gt;&lt;/li&gt; &lt;li class=&quot;alt&quot;&gt;&lt;span&gt;X-Priority:&amp;nbsp;3 &amp;nbsp;&amp;nbsp;&lt;/span&gt;&lt;/li&gt; &lt;li class=&quot;&quot;&gt;&lt;span&gt;X-MSMail-Priority:&amp;nbsp;Normal &amp;nbsp;&amp;nbsp;&lt;/span&gt;&lt;/li&gt; &lt;li class=&quot;alt&quot;&gt;&lt;span&gt;X-Mailer:&amp;nbsp;Microsoft&amp;nbsp;Office&amp;nbsp;Outlook,&amp;nbsp;Build&amp;nbsp;11.0.5510 &amp;nbsp;&amp;nbsp;&lt;/span&gt;&lt;/li&gt; &lt;li class=&quot;&quot;&gt;&lt;span&gt;X-MimeOLE:&amp;nbsp;Produced&amp;nbsp;By&amp;nbsp;Microsoft&amp;nbsp;MimeOLE&amp;nbsp;V6.00.2800.1807 &amp;nbsp;&amp;nbsp;&lt;/span&gt;&lt;/li&gt; &lt;li class=&quot;alt&quot;&gt;&lt;span&gt;&amp;nbsp; &amp;nbsp;&amp;nbsp;&lt;/span&gt;&lt;/li&gt; &lt;li class=&quot;&quot;&gt;&lt;span&gt;Purchase&amp;nbsp;Rx~Medicationz&amp;nbsp;Online!..&amp;nbsp;NO_Prescription_Required! &amp;nbsp;&amp;nbsp;&lt;/span&gt;&lt;/li&gt; &lt;li class=&quot;alt&quot;&gt;&lt;span&gt;Browse&amp;nbsp;Our&amp;nbsp;Website&amp;nbsp;Today!&amp;nbsp;-&amp;gt;&amp;nbsp;http://easyonlinerxmedznow.com &amp;nbsp;&amp;nbsp;&lt;/span&gt;&lt;/li&gt; &lt;li class=&quot;&quot;&gt;&lt;span&gt;&amp;nbsp;&amp;nbsp;&amp;nbsp;&lt;/span&gt;&lt;/li&gt;&lt;/ol&gt; &lt;p&gt;[/quote]&lt;/p&gt; &lt;p&gt;[quote]&amp;nbsp;&lt;/p&gt; &lt;p&gt;&amp;nbsp;Received: from spooler by mail.themoddepot.com (Mercury/32 v4.72); 6 Nov 2009 02:19:30 -0500 X-Envelope-To: &amp;lt;&lt;a href=&quot;mailto:XXXXX@themoddepot.com&quot; mce_href=&quot;mailto:XXXXX@themoddepot.com&quot;&gt;XXXXX@&lt;/a&gt;&amp;gt; X-SPAMWALL: Passed through antiSPAM test by Spamhalter 4.5.1.411 on mail.themoddepot.com (19) X-SPAMWALL: probability - 100.0% X-SPAMWALL: SPAM detected! Return-path: &amp;lt;&lt;a href=&quot;mailto:b.trevino_sq@firstnet.se&quot; mce_href=&quot;mailto:b.trevino_sq@firstnet.se&quot;&gt;b.trevino_sq@firstnet.se&lt;/a&gt;&amp;gt; Received: from 6kdxma3 (204.236.103.132) by mail.themoddepot.com (Mercury/32 v4.72) ID MG0002D1; &amp;nbsp;&amp;nbsp; 6 Nov 2009 02:19:21 -0500 Message-ID: &amp;lt;&lt;a href=&quot;mailto:000701ca5ea8$a26c1770$ae78a432@firstnet.se&quot; mce_href=&quot;mailto:000701ca5ea8$a26c1770$ae78a432@firstnet.se&quot;&gt;000701ca5ea8$a26c1770$ae78a432@firstnet.se&lt;/a&gt;&amp;gt; Reply-To: &quot;Brittany Trevino&quot; &amp;lt;&lt;a href=&quot;mailto:b.trevino_sq@firstnet.se&quot; mce_href=&quot;mailto:b.trevino_sq@firstnet.se&quot;&gt;b.trevino_sq@firstnet.se&lt;/a&gt;&amp;gt; From: &quot;Brittany Trevino&quot; &amp;lt;&lt;a href=&quot;mailto:b.trevino_sq@firstnet.se&quot; mce_href=&quot;mailto:b.trevino_sq@firstnet.se&quot;&gt;b.trevino_sq@firstnet.se&lt;/a&gt;&amp;gt; To: &amp;lt;&lt;a href=&quot;mailto:XXXXX@themoddepot.com&quot; mce_href=&quot;mailto:XXXXX@themoddepot.com&quot;&gt;XXXXX@&lt;/a&gt;&amp;gt; Subject: Adult bedtime magic make it long and strong Date: Fri, 06 Nov 2009 00:16:10 -0600 MIME-Version: 1.0 Content-Type: text/plain; &amp;nbsp;format=flowed; &amp;nbsp;charset=&quot;windows-1250&quot; &amp;nbsp;reply-type=original Content-Transfer-Encoding: 7bit X-Priority: 3 X-MSMail-Priority: Normal X-Mailer: Microsoft Office Outlook, Build 11.0.5510 X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2800.1807&lt;/p&gt; &lt;p&gt;Purchase RxMedications Online!.. N0_Prescription_Needed! Browse 0ur_Selection Today! -&amp;gt; &lt;a href=&quot;http://themybetterrx.com/&quot; mce_href=&quot;http://themybetterrx.com/&quot;&gt;http://themybetterrx.com&lt;/a&gt;&lt;/p&gt; &lt;p mce_keep=&quot;true&quot;&gt;&amp;nbsp;&lt;/p&gt; &lt;p mce_keep=&quot;true&quot;&gt;&amp;nbsp;&lt;/p&gt; &lt;p&gt; [/quote]&lt;/p&gt; &lt;p mce_keep=&quot;true&quot;&gt;&amp;nbsp;&lt;/p&gt; &lt;p&gt;&lt;a href=&quot;mailto:XXXXX@themoddepot.com&quot; mce_href=&quot;mailto:XXXXX@themoddepot.com&quot;&gt;XXXXX@t&lt;/a&gt; is my mailbox mail.themoddepot.com is my mercury server...&lt;/p&gt;&lt;!--end code block--&gt;
